Need help with and Ironman tires and brakes
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
I have this 1989 Centurion Ironman I bought last year. It is one of my favorites. The problem I'm having is i
wanted to switch tires to a 28 or 25 mm tire from 23 mm. The original calipers were changed fro Suntour GPX
to Shimano 105s. I thought no big deal but it seems like neither 28s or 25s will fit without hitting the top of
the caliper on the rear brake. I think the front will fit but not the rear. I can't imagine Shimano 105s having this problem
Any recommendations? Here is a photo
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,926 Times
How is the clearance on the fridge itself? BTW you'll need a little room for deflection or whatever you want to call it when you put weight on the bike and the tire gets a bit bigger and you squash the bottom. Do you have a different caliper you can tryout?
Too bad they stole the GPX calipers, I'm not not a huge fan of DP brakes.
Sugar "Kane" Kowalczyk
Quoted: 1949 Post(s)
Liked 2,010 Times
My son’s 89 expert has 6500 calipers and there is room for 25s but probably not 28s because of the bridge but I never tried.
Quoted: 1562 Post(s)
Liked 1,734 Times
There is still a big gap between the brake shoes and the rim. Adjust the brake to take away that slack, and see if it clears.
I had a '87 Ironman and there was plenty of room even with 28mm tires. I am very surprised that the '89 model is this tight.
Likes For icemilkcoffee:
Quoted: 677 Post(s)
Liked 460 Times
and they both have plenty of clearance
Liked 2,010 Times
Was that ‘87 a Master? I think that year’s Master was like the ‘86 Classic which has plenty of room. My ‘87 Expert — not so much.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Put down the release levers. That series of brake shows lower when the release lever is up.
You should be able to fit 25mm tires.
Quoted: 4560 Post(s)
Liked 2,802 Times
Yeah, my '89 Ironman Expert with Suntour GPX group barely clears Conti GP Classic 700x25 tires. There's a raised center tread that makes the tire taller than usual, probably close to 700x28. Usually I just ride until the tire wears enough to stop scraping the brake bridge.
I'm planning to try some Conti Ultra Sport 3 in 700x28 on at least one road bike. If it scrapes the rear brake bridge I'll probably use a moto tool to file down the bridge just enough to clear some room.
Quoted: 254 Post(s)
Liked 182 Times
If it’s just the caliper and not the bridge that’s in the way, an inelegant solution would be an upside down drop bolt to raise the caliper. Apparently they used to sell some that were made for shimano dual pivot brakes but they’re probably hard to find: https://www.sheldonbrown.com/dpdropbolt.html
Likes For AeroGut:
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 976 Times
Interesting maybe the geometry including the brake bridge changed slightly over the years but this is just my guess
Quoted: 3810 Post(s)
Liked 6,702 Times
Two words: 650b conversion
Quoted: 677 Post(s)
Liked 460 Times
It's strange I have an 87 Expert and 87 Master that have 25s on them and have room where I could put 28s on them.
I also had an 89 Expert just like this one that had a 4 cm larger frame and it had 28s on it. Maybe I'll just put the old
23s back on it
23s back on it
Quoted: 1143 Post(s)
Liked 1,740 Times
Not something I would do on the normal, I've ground down a spacer to a wedge shaped. This can gain (or lower) a mm or two when tightening the caliper to the brake bridge.
Quoted: 677 Post(s)
Liked 460 Times
Quoted: 4408 Post(s)
Liked 1,562 Times
Quoted: 677 Post(s)
Liked 460 Times
Quoted: 677 Post(s)
Liked 460 Times
I picked this bike up for a good price but wasn’t thrilled that some of the stock Suntour gpx parts were swapped. The wheels and hubs were switched to Bontrager Racelite and the brake calipers to Shimano 105s and the freewheel swapped to Shimano but the bike rides really nice but I’d like a little bigger tires
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 698 Times
You may not want to get on a higher quality frame that can take 32s. You might actually add this one to your for sale listing. I just set up a Trek 412 with wonderful feeling 35s, but most of my fleet is 32s. Perhaps a full Reynolds 531 that can take at least a 32 is in your future. You seem to have a knack for finding them.
Liked 1,562 Times
Bianchi Goddess
Liked 2,926 Times
Stopping is overrated.
I don't mind stopping one bit but considering we had centerpull brakes for decades before we had side pull and people weren't constantly dying because the brakes did not provide enough stopping power. Look at how cheap the brakes were on a Murray or Huffy "10 Speed" in the '70s and '80s and they were never labeled as death machines by the CPSC.
Dual Pivot brakes are like 'brifters', they provide an unnecessary improvement in performance.
Likes For Bianchigirll:
Steel is real
Quoted: 670 Post(s)
Liked 976 Times
Liked 1,562 Times
And what about when you have stop very quickly in a emergency, single pivot weren't enough efficient apparently because 33 years Shimano introduce them with in1990 Dura Ace BR 7403, 2 years later Campy introduced the Record dual pivot brakes. Unnecessary improvement ? Debatable especially in an emergency stop or under rain. Maybe a comparison between stopping distances between a single pivot brakes and dual pivot brakes,will show the dramatic improvement in stopping.I think when you ride a road bike fast the goal is to stop when needed and not get into accident. The brifter thing is another debate,after Shimano ceased the production of the ST 7801 brifers,I stopped myself interesting to the new Dura Ace groupsets.
robertj298 There are lots of GPX calipers on ebay.
Steel is real
Quoted: 670 Post(s)
Liked 976 Times
