ISO/WTB Suntour Ultra 7 freewheel
Bikes: 1975 Motobecane LeChampion (silver lilac), 1974 Motobecane Grand Jubile (red/black); 1975 Motobecane Team Champion (orange); 1982 Pinarello Professional (Exorcist Green); 1974 Raleigh Professional MkIV mink blue, 1974 Motobecane Grand Record blk/red
Quoted: 103 Post(s)
Liked 750 Times
I am looking for a Suntour Ultra 7 freewheel, preferably with a 28T - either 13-28 or 14-28. English or ISO thread. Thanks for looking!
Andy
Andy
Quoted: 786 Post(s)
Liked 520 Times
Unless you are looking specifically for a Suntour, ultra 7 became the standard spacing for most 7s freewheels.
-j
-j
Edumacator
Quoted: 2439 Post(s)
Liked 3,128 Times
What were the 8 speed free wheels spaced?
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Likes For clubman:
Edumacator
Liked 3,128 Times
Which, with friction wouldn't really matter, I presume.
Likes For jdawginsc:
Phyllo-buster
Liked 2,054 Times
Not knowing the OP's shifters, we're flying blind. I'll assume he knows what he wants.
I'm also assuming that 7 speed Ultra is the same as the Alpha model freewheels? Inquiring minds...
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
@75Iechamp I could probably fix you up.....I have a bunch of good NWN bodies, spacers for Ultra-7, and a heap of cogs. Get back to me a first ,and perhaps, a second choice for your ideal tooth count by position. I will get back to you with what I can provide and a shipped price. PM or Quick Reply as you wish.
FWIW, I run Ultra-7 on frames spaced at 126 mm.
Dean
Dean
Roll Me Up and Smoke Me When I Die
Likes For Dean51:
lurking nightrider
7-speed cog spacing varied between manufacturers. The spacing on a 7-speed Suntour would not be identical to, let's say, a Regina America 7-speed.
"If there hadn't been women we'd still be squatting in a cave eating raw meat, because we made civilization in order to impress our girl friends. And they tolerated it and let us go ahead and play with our toys." Orson Welles
Likes For LittleGinseng:
Quoted: 5888 Post(s)
Liked 3,471 Times
The 7s work on 126 OLD but freewheel bodies do not have a uniform width (they vary a bit by manufacturer). That means that if installing a 7 speed freewheel on a bike for the first time, you may have have to tweak the drive side spacers a bit (and perhaps redish the wheel a tad) so that the chain doesn't rub the stay. If that is a problem, a quick fix is to insert a 1 mm spacer on the drive side and call it a day. Yes the wheel won't be perfectly centered but you'll still be able to ride it just fine.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Freewheel Body Widths
Some Guestimated charts that I found online:
From Sheldon Brown RIP
Real life examples. I checked a milk crate full of freewheels and found the widths all over the place. Note: many freewheels have a 1mm to 2mm recess in the rear so you can measure that and subtract it from the width.
IRD used to publish the actual widths of their freewheels. The body widths on their most recent version, the Cyclone Mk 1 run wide and the 5 speed FWs use a 6 speed body minus the outer sprocket so you may as well buy their 6 speed! Rather ingenuous...
IRD Cyclone Mk 1 7 speed FW.
To muddy the water further, there was no REAL standard for the "D" width dimension on hubs. Suntour specified "More Than 36mm" "D" width. Some 7 speed FWs are almost 36mm wide!!! A 2mm recess gives you 34mm from the hub shoulder to the end of the axle. Ideally you should have about 4mm of clearance from the end of the FW body to the end of the axle.
Where this becomes a problem is when shifting off of the small sprocket, the chain can catch on the inside bottom of the seat stay. A fast and dirty fix is to add some spacers to the end of the axle but that throws the wheel dish off plus the wheel is no longer aligned with the dropouts.
A better solution is to file some clearance on the bottom of the seat stay. We did that on a lot of the better bikes that we sold plus I did it on all of the frames that I built.
Attn: Pastor Bob pastorbobnlnh
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Likes For oneclick:
Quoted: 103 Post(s)
Liked 750 Times
Found one, thanks all!
