Wahoo Kickr stock 11 speed 11-28 cassette
Old 10-26-20, 09:00 AM
Fendertele
Fendertele's Avatar
Bikes: Trek Domane SL5
Quoted: 25 Post(s)
Liked 41 Times in 28 Posts
My bike has an 11-34 cassette. Will my chain work on the stock cassette without adjustment?
Fendertele is offline
Old 10-26-20, 09:07 AM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 464 Times in 365 Posts
You'll be fine. It is as if you never use any gear larger than the 28 on your bike.
zacster is offline
Old 10-26-20, 11:26 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
The only problem may be if your current 11x34 cassette and chain have been used together for many miles. The old chain could mesh poorly with the new cassette under a lot of load. Probably worth the modest cost to get a new chain with a quick link and dedicate it to the trainer.
HillRider is offline
Likes For HillRider:
Old 10-26-20, 12:25 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
You may have to adjust a click or 2 on the barrel adjuster. That's quite "normal" due to slight manf. tolerance between different cassettes.
Bill Kapaun is online now
Old 10-26-20, 01:15 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
Small adjustments to the limits may be needed also, and possibly to the B-screw for crispest shifting.
dsbrantjr is offline
Old 10-26-20, 03:25 PM
zacster
Quoted: 22 Post(s)
Changing chains just to use the trainer is a lot more trouble than it's worth. The last thing I need is an excuse to not use the trainer. I can swap wheel to trainer in about 15 seconds and I even have a Campy setup on the bike but an Ultegra cassette on the trainer and it all works perfectly.
No you shouldn't. If you need to adjust the cable, your trainer cassette isn't positioned properly. Add or subtract spacers at the back of the cassette so that it matches alignment on the small cog between wheel and trainer. Again, if I had to make adjustments to use the trainer I'd be sitting on the couch instead.
Maybe to get the crispest shifting, but this is a trainer not the TdF.
I've been through all this already and even with the non-compatible Campy 10 13-29 and Shimano 10 11-25 I made it work so that it is just a quick wheel swap. With compatible systems it should be a piece of cake (yum, cake) to get it to work with just a wheel swap.
zacster is offline
Likes For zacster:
Old 10-26-20, 03:36 PM
Bill Kapaun
Originally Posted by zacster
......No you shouldn't. If you need to adjust the cable, your trainer cassette isn't positioned properly. Add or subtract spacers at the back of the cassette so that it matches alignment on the small cog between wheel and trainer. Again, if I had to make adjustments to use the trainer I'd be sitting on the couch instead......
There's a difference between may have to and NO you shouldn't.
Apparently, that concept is too much for you?
Adding spacers to the back of the cassette when a click or 2 on the barrel adjuster does the same thing is so stupid you make my ignore list.
Old 10-26-20, 04:11 PM
zacster
Quoted: 22 Post(s)
Yes, and why do you think they supply spacers with trainers? And fixing something permanently is not a better idea than adjusting something every time you use it? There is a very definitive spec for all of the speeds, wheels, hubs, freehubs, etc.. so you don't ever NEED to make adjustments. That's what standards are about. The main problem with trainers is that they need to accommodate the different systems and they do that with spacers. Get the right spacer and there are no problems. And it is not "normal". The tolerances on the cassettes are really tight otherwise indexing wouldn't work.
zacster is offline
Old 11-14-20, 11:37 AM
Fendertele
Fendertele's Avatar
Quoted: 25 Post(s)
Thanks for the feedback. Finally received my Kickr and took the inaugural ride. No adjustment was required.
