Fire as paint remover?
#51
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
I have a frame I am seriously considering stripping, but it has a lot of chrome. Would a heat gun affect the chrome? The transitions from paint to chrome are over 12" in length so the chrome's gonna get heated up on this frame. But I recall the last time I stripped a frame with gel stripper; it was a mess and it didn't do a great job, either. Looking for a different approach this go around.
DD
DD
I would depend on the temp. The exhaust caused some discoloration to the chrome on my exhaust tips.
I do not know at what temperature chrome will turn blue but I would be cautious using an open flame or a hi-temp heat gun.
Best, Ben
Voltaire
Voltaire
#52
Quoted: 4560 Post(s)
Liked 2,802 Times
DD
DD
#53
I have recently been researching stripping and restoring cast iron cookware and one of the methods presented was building a large fire and letting it burn down until you have a nice pile of hot coals. you then bury the skillet in the hot coals and let sit overnight. Once cooled off, pull the skillet out in the morning and wash, dry and begin the seasoning process.
Be where your feet are.......Lisa Bluder
#54
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Stuart Black
Likes For cyccommute:
#55
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
and, condescension is a real buzz kill
Likes For Mr. 66:
#57
Quoted: 1083 Post(s)
Liked 687 Times
Let me clarify. The frame was above the fire, not in the coals. I heated one section at a time for about 1 minute, then removed it to scrape the paint in that section. Each section worked was roughly 6 inches long. The total process, section by section, took about an hour.
#58
Passista
Quoted: 867 Post(s)
Liked 721 Times
If fire is good for removing a dork disk, why wouldn't it work to strip paint?
Likes For Reynolds:
#59
Liked 687 Times
So based on that knowledge, it should be possible to know how you affected the properties of the steel, assuming that you carefully measured and controlled the temperature, the exact length of time it was subjected to that heat, and carefully controlled the quenching process.
Otherwise I personally wouldn't trust that frame, but it might be fine for a neighborhood knock-about or or grocery-getter that doesn't get much stress placed on it. I wouldn't get too far from home with it.
#62
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
#63
Quoted: 331 Post(s)
Liked 332 Times
One thing I have discovered of late - if you want to remove powder-coat - fire is definitely the way to go!
#64
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 639 Times
Insert Schwinn Varsity humor here.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
#65
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
#66
Quoted: 2588 Post(s)
Liked 4,824 Times
DD
#67
#68
Quoted: 1188 Post(s)
Liked 1,154 Times
I had originally used the Aircraft paint stripper on other frames, but it turned dark in color for some reason and stopped working so threw it way. The 2 strippers I used on this, prior to fire, were The Kwik-Strip in the Blue can and the Jasco in the red can. I mentioned this in post #1 but here is a photo.
#69
Randomhead
Liked 3,699 Times
when I'm fixing a frame I burn the paint off with my torch in the affected area and then mechanically remove what's left. It really doesn't heat up the frame that much.
Probably why my asthma never gets better.
Likes For unterhausen:
#71
Bikes: 1973 Colnago Super, Litespeed Classic , Automoto , Pinarello Gavia TSX,Eddy Merckx Corsa Extra,Eddy Merckx EMX-5 , 1982 Moser SL, Concorde TSX, Vitus 979 KAS. Diamant SLX,60's Meteor
Quoted: 235 Post(s)
Liked 947 Times
Just paint it and ride it . If it makes some weird creaking noises then you worry, until then go for it.
#72
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i have a chrome fork i had dechromed and some canti bosses brazed on. the base nickel plating is still intact and only oxidation is where the plating was ground off to braze the bosses. iow's, even with all that heat being centralized and the plating surrounding the bare areas, the plating looks untarnished. but, it's probably gonna fail because it got hot
#73
I like cats.
I picked up a Velo Orange Mojave bottle cage for $5 at the swap today. There was a bare metal one that someone scooped out from under me and I got the stainless, powder coated black version. What can I expect cosmetically from throwing it into a charcoal chimney or a smokeless fire pit for a bit? I can weld stainless if a joint breaks, so I'm not too worried about that.
#74
Quoted: 765 Post(s)
Liked 660 Times
My favorite part about this forum is reading a post in which someone describes a (at least new to me) solution to a common problem, and I think to myself "Wow! What a great idea!" This is not one of those times.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
#75
Quoted: 966 Post(s)
Liked 1,629 Times
I have used a butane lighter to heat up and remove decals on a frame before using paint stripper. I have also used a Heat Gun at low temp to remove paint on a fork. I have also used a cotton ball saturated with alcohol to produce a low temp fire and remove small sections of paint on a bicycle.
