Bent and straight forks
Old 07-07-22, 09:18 AM
  #51
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times in 2,284 Posts
Watch this fork flex. Imagine how much more it flexes when mostof the rider's weight is on it. Imagine 205lb Gugie vs 160lb Jan Heine.
From Rene Herse blog.
@JohnDThompson, do you have a link to Jan's straight vs curved fork testing? I could not find it.
gugie is offline
Likes For gugie:
Old 07-07-22, 11:09 AM
  #52
steelbikeguy
steelbikeguy's Avatar
Quoted: 1829 Post(s)
Liked 3,376 Times in 1,580 Posts
to save John the trouble of digging it up, I did check the index of articles. It's in issue #23, volume 6, number 3.
The key results are on page 25....
edit: although this is just fork flex in general. Was there an article on straight vs curved? Might have to look again.
Steve in Peoria
steelbikeguy is offline
Old 07-07-22, 12:02 PM
  #53
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times in 1,617 Posts
Originally Posted by Chr0m0ly
A bent fork accepts the force as a deflection. A straight fork is trying to compress. It takes more force to compress a tube than to bend it too the side.
Right.
Flexing absorbs energy.
But both forks take the same input/impact force. The curved fork absorbs some of the force and transfers the rest to the headset and into your arms.
The straight fork doesn't flex and transfers essentially all of the force into your headset and your arms.
Forks with elastomers or something have other means of absorbing some of the impact.
You could do an experiment where you measure the resultant force at the top of the head tube from a given input force on the fork dropouts to verify this.
I don't know if it's enough to make a difference in hand feel or headset life, but it exists.
DiabloScott is offline
Old 07-07-22, 12:11 PM
  #54
gugie
gugie's Avatar
Originally Posted by JohnDThompson
IIRC, it was Colnago's marketing department that promoted straight-blade forks in the late 80s to early-90s. I suspect it was done mostly to eliminate a manufacturing step (raking the fork blades) and thereby sightly reduce the cost of production, more than anything else. With carbon fiber forks, this isn't an issue, so the blade shape choice is simply cosmetic.
Jan Heine did a comparison of straight and curved fork blades and decided that curved blades offer slightly better shock absorption than straight blades, but were otherwise quite similar.
Originally Posted by DiabloScott
Right.
And yes, no straight vs curved fork blade comparison that I can find from Jan.
Flexing stores energy (it's a spring), less heat losses (essentially zero in this case)
Straight forks do flex.
I don't have any straight bladed forks, if anybody wants to take a short video replicating the one from Rene Herse I posted above we'd have proof in a picture (video, actually)
From my ancient and half forgotten understanding of first princpals of mechanics of solids and materials that are used in forks, everything else being equal, a curved fork will flex the same as a straight fork. My spidey sense tells me this is a simplfiication, but it's "close enough" that most people wouldn't notice a difference.
gugie is offline
Old 07-07-22, 12:26 PM
  #55
gearbasher
gearbasher's Avatar
Quoted: 453 Post(s)
Liked 908 Times in 383 Posts
Here's a test on Sheldon Brown's site
https://www.sheldonbrown.com/rinard/..._forktest.html
If I'm reading it right, the straight blade Colnago fork has the same deflection as the Merckx and Schwinn Paramount (Waterford).
gearbasher is offline
Likes For gearbasher:
Old 07-07-22, 12:29 PM
  #56
steelbikeguy
Looking through the BQ glossary of article.... https://www.bikequarterly.com/glossary/ ... I didn't find anything new.
Looking through issue #23 again, the article on fork flex does show an illustration comparing straight to curved forks, but it's an argument that curved flexes more, but without any data.
Steve in Peoria
