A really simple way to clean disc brake lining
Guest
Posts: n/a
Need: prevent midge’s Florida Water and paper towel
Specific means is: Crack the Braking lining, individual pour out a little Florida Water, Braking lining rubbing one another, and dry with paper towel, add a little more Florida Water, repetitive operation 3-4 times, clean the Braking lining with paper towel(Touch Florida Water), set up Braking lining, It is done!
Bike ≠ Car ≠ Ped.
Never heard of Florida Water... Is this it? https://en.wikipedia.org/wiki/Florida_Water
And, you're talking about the pads themselves, yes? Will this remove oils and decontaminate the pads, too?
Liked 12 Times
Or 2 squirts of brake clean......
![](https://www.3m.com/product/images/brake-cleaner-08880-300.jpg)
Doesn't Florida water have lemon/orange in it.....as in citrus oil?If it does,it will clean them but the oil will come to the surface when they warm up and glaze the rotors.
To remove a contaminate like metal or sand particle from a disc brake pad, use a pick or needle to dislodge. For heavy oil contaminate, discard the pad. To remove glazing or light finger oil contaminate, rub the pad across clean medium grit sand paper, 600 grit for example. Most bike pad compounds are held together with organic binders which can degrade with brake cleaner saturation, for that reason I don't recommend brake cleaner or Acetone, and really there is no reason to use a liquid cleaner in the first place; definitely don't use a product on the pad surface which can leave a residue. If debris is heavily deposited around the caliper and pad, use compressed air to break free, and only from a source with an oil/water separator filter installed in-line.
For optimum braking performance pad material needs to transfer to the brake rotor, the rotor should only be wiped off if muddy, and only water used if necessary.
Guest
Posts: n/a
It is not made in Florida, i do not how to translator in english, but is a toilet water, smell sweet, Older people or young people all use it for avoid mosquitos , or flies, but one day i found a people said he use it to clean braking lining, very useful, and other people said they try and useful, so share to more people, i do not whether it sale on abroad
