Brompton like frame sets?
There are lot’s of Brompton clones and Brompton modifications. People like how it folds but want more, like disk brakes, generic cassette/derailleur/hubs, thicker tires, bigger rims, different forks, different OLD rear triangle etc etc. I wander why asian producers do not offer a Brompton like frame sets like Fhnon?Offer a frame and separately few versions of fork/rear triangle/handlebars. Let people buy the rest and assemble the bike they want.
Bikes: 2013 Wilier Gran Turismo, 1983 Trek 760, 80's Colnago Super, 90's De Rosa SLX, 2009 Waterford 22 Series Singlespeed, 85 Medici Pro Strada, De Rosa Alumino frameset, Dave Molten Fuso frameset, 70's beater Peugeot PX10, Zizzo Liberte, 2022 Yoeleo R12
Quoted: 122 Post(s)
Liked 199 Times
Have you checked Aliexpress? There are many frames, forks, parts for folding bikes and minivelos made of steel, aluminum or carbon.
Ti parts yes, but I didn’t see listing with main frame made of metal. Also not sure about handlebar stem made of metal.
Quoted: 800 Post(s)
Liked 247 Times
All parts of the Brompton frame are available in titanium including the stem on ebay or aliexpress.
And there are several types of rear frame, with the original OLD or 135mm OLD, with or without disc brakes calipers mounting points.
Of course, you never know in advance the quality of the parts you will actually receive and the price of a complete frame when you add the prices of all parts isn't really cheap.
Quoted: 122 Post(s)
Liked 199 Times
CEBEP, is this what you are looking for? The knockoff steel frame components for a Brompton? Check out the SungDa Outdoor Shop on Aliexpress.
Quoted: 800 Post(s)
Liked 247 Times
The problem is that to go to wider 50mm tires like the Big Apple, either you must accept smaller diameter wheels (ETRTO305 with 50x305 tires, even with these wider tires the overall wheel diameter is smaller than the original 35x349 diameter) or must accept to have a bigger folded size with 50x355 tires.
Quoted: 800 Post(s)
Liked 247 Times
If you talk about the Kinetics 20" mod, it makes the folded Brompton higher and longer.
It remains one of he smallest 20" folding bike but its bigger than original, as big as a Birdy 3. This because the folded rear wheel comes against the frame tubes and bottom bracket box. If the wheel diameter is increased by let say 50mm, then the rear triangle length must be increased by about 25mm and the folded length and height are increased by about 50mm too.
So a part of the Brompton advantage is lost.
After my Birdy I really miss disk brakes and a bit more cushy ride on Brompton
Quoted: 800 Post(s)
Liked 247 Times
Yes, I understand that even if in practice, good caliper brakes like the Ridea for Brompton provide sufficient braking.
The drawback of disc brakes is that they will always increase the weight, to have the real power of disc brakes, hydraulic disc brakes are needed (I have TRP disc on my Ti Birdy, they are lightweight but cannot compete against the cheap Shimano Deore of my Birdy 3) and even higher end, very expensive hydraulic disc brakes, weight more than lightweight rim brakes like the Ridea (and its possible to mount eebrakes that weight less and provide top notch braking).
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
Likes For tcs:
Palmer
Liked 1,826 Times
Quoted: 463 Post(s)
Liked 567 Times
57-306
You can try going bigger than 50mm wide tires on 305 rims. You can try, for example, 57-305 which is only marginally shorter than 37-349, but substantially cushier.
