Aero Wheels add 1.5 to 2 mph?
Legs; OK! Lungs; not!
Bikes: ''09 Motobecane Immortal Pro (Yellow), '02 Diamondback Hybrid, '09 Lamborghini Viaggio, ''11 Cervelo P2
Liked 9 Times
I'm not trolling or looking to start some flame war, but I guy I ride with (who has been racing for almost 40 yrs) says Aero Wheels add 1.5 to 2.0 mph. What say the Oracle of BF?
The Weird Beard
I have seen in other threads that aero wheels at least double your speed. I read it on BF, honest :-)
Seriously though, I assert that it is a negligible gain outside of a controlled environment, and a placebo effect.
Bikes: Colnago C59 Italia Di2
I cruise at 20mph, for the same power output do you really think those wheels will add 10% to my speed? You really think standard wheels soak up 10% of my speed in the first place?
No mate.
In the TDF this year, a few seconds separated the top 2 riders after 3 weeks of riding. Aero wheels are used to give you the best chance of being the one that is a few seconds up after that sort of distance. They dont have engines built into them.
No mate.
fuggitivo solitario
good ones will save you about 15 watts over box sections, that's assuming you are going at 25mph, and the wind is going pretty much parallel to you
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
My own personal testing has shown about 3% power savings going from moderately aero clinchers (relatively low spoke count, not box section) to 46mm tubular wheels. Not huge, but measurable.
Bikes: Ever changing..as of 2-24-09: 2003 Giant TCR Team Once, Sampson titanium, 1992 Paramount Series 3, 2003 Cervelo P3, 70s Raleigh Record fixed gear, 70s Fuji SL-12 commuter, mid 90s Klein MTB. Plus two or three frames lurking, plus 5 wife/kids rides
The difference from a road bike in the drops to a TT bike with full aero gear might be close to that..but not wheels alone.
Here's data from two recent 15k time trials. First one was on the road bike, no aero gear, Kinlin 27mm tall rims (not aero). Totally flat course, very slight wind:
Total Elapsed Time 00:23:06
Distance, mi 9.07
Work, kJ 381
Temperature, °F --
Average Power, Watts 275
Average Cadence 85
Average Speed, mph 23.57
Average Heart Rate --
Ride Time (Time Moving) 00:23:07
Second TT: 15k, slightly rolling course, moderately windy, full TT bike, deep section wheels (Hed Jet 60 front, PX 101 rear), everything but the aero helmet: I went .6 mph faster with 20 watts less average. You could go plug those numbers in to the analytical cycling web page and estimate the total CDA reduction. It's substantial, but mostly due to the body position.
Total Elapsed Time 00:22:28
Distance, mi 9
Work, kJ 418
Temperature, °F --
Average Power, Watts 255
Average Cadence 88
Average Speed, mph 24.16
Ride Time (Time Moving) 00:22:29
Distance, mi 9.07
Work, kJ 381
Temperature, °F --
Average Cadence 85
Distance, mi 9
Work, kJ 418
Temperature, °F --
Average Cadence 88
well hello there
Quoted: 503 Post(s)
Liked 336 Times
What kind of testing did you do? Same route, same conditions, different wheels?
Bikes: Litespeed Liege, Motorola Team Issue Eddy Mercxk, Santana Noventa Tandem, Fisher Supercaliber Mtn. Bike
Quoted: 14 Post(s)
Liked 11 Times
sure high end zipps with ceramic hubs could give you that much of a boost, but it will cost you $$$
Quoted: 1186 Post(s)
Liked 289 Times
20W savings at a power of 300W would be 6.7% power savings which should translate into roughly 6.7/3=2.2% speed improvement. So if you were going 24MPH you could improve to 24.5MPH. Definitely worth it for a TT. A 2 MPH improvement would be 8% and require about 24% extra power or 75W. Impossible from a set of wheels.
Bikes: Surly Cross-Check, '85 Giant road bike (unrecogizable fixed-gear conversion
I read in Bicycling magazine a story about actual wind tunnel tests. They found that a $200 aero helmet gives you more speed than $2000 aero rims.
It's ALL base...
I think they might be worth that 1-2mph on a good, long 7-8% downhill.
Edit to add: I see the above gain on 38mm aero wheels compared to Open Pros. You might see even more, depending on wheel depth.
Quoted: 2952 Post(s)
Liked 3,106 Times
20W might be the difference between hanging on and getting dropped.
Basically. Nothing formal, just whenever I use the wheels on courses where I get consistent speed for power results, that's about the bump I get. Note that 3% power savings does not equal 3% faster...
30 YR Wrench
Bikes: Waterford R-33, Madone 6.5, Trek 520
Maybe without a rider on the bike. Otherwise, the rider-his/her body type, clothing, style of helmet and position on the bike would likely negate the added benefit, if it even exists....
The benefit is not so much from the frontal area of rim passing through the air, as it is the extra rim depth making less spoke constantly moving through the air.
Ninja!
this is what zipp claims
https://www.zipp.com/_media/pdfs/support/aero_edge09.pdf
they say you can save a minute with the 303s in a 40k time trail.
Headset-press carrier
Bikes: Kona with Campy 8, Lynskey Ti with Rival, Bianchi pista, Raleigh Team Frame with SRAM Red, Specialized Stump Jumper, Surley Big Dummy
Why would hard core racers and pros bother if they did not make a difference?
You may have to realize you full power potential. ideal weight and adaptive endurance before it makes a difference for you. That state of fitness is supposedly being able to do a 25 mile TT ~1 hour.
And even if the above conditions are not met, no LBS or online retailer will stop you from getting aero wheels.
pan y agua
Quoted: 1452 Post(s)
Liked 731 Times
I don't think so. I have 303's 404's and 808's, as well as a disc and a tri spoke. With just some rough observation, Disc and the tri spoke might be close to half a mile an hour above 25mph, then its down from there, more like .2 to .25 mph.
You could get lost and die.
You could hit a tree and die.
Sua Ku
Bikes: Trek 5200, BMC SLC01, BMC SSX, Specialized FSR, Holdsworth Criterium
Will they make you faster? yes.
Will that be 1.5 to 2mph? - depends, but unlikely.
They may make the difference between 58 mph and 60mph (which I cruise at on most rides) but not 20mph and 22mph (where most of you probably ride).
