Not a Noob, but......
Rider
Bikes: Trek Madone 5-Series Campy 10
This question may make me sound like one. What is the protocol when installing a new chain?
Clean off the packing grease and lube it? Or ride it until you need lube?
Constant tinkerer
The original grease is the best thing the chain will ever have. Leave it completely alone, just install it. Clean/lube it once it gets dirty or noisy.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12790 Post(s)
Liked 7,698 Times
I leave factory gunk on, but typically add lube within 50 miles, frequently oil over the factory gunk right away.
Quoted: 5793 Post(s)
Liked 2,594 Times
+1,000
I like to believe I make a pretty decent chain lube, but always leave the original lube in place on my own chains, though I do add fresh lube immediately while the chain is still clean.
You may add fresh lube immediately or hold off at your option. If the outside is sticky, you can help the chain stay cleaner by dampening a rag with mineral spirits or naphtha and wiping down the outside.
FB
Chain-L site
FB
Chain-L site
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Since I live in a place where dust and sand are more of a problem then water, I clean the chain before I install, apply a dry lube which is far less messy, and never clean the chain again. In my experience and contrary to what most people will tell you, lohump, dry lubes don't have to be added after every ride, they last longer than 50 miles and they don't cause excessive wear. I lubricate my chains less often than every 6 weeks...often only after a rare rain ride...and don't change chains more often 4000 or 5000 miles.
Clean the chain and save yourself the headache further later.
Stuart Black
Stuart Black
Bikes: All 70s and 80s, only steel.
Seal beach has moist, salty sea air. Unless the OP is riding by the beach a lot, dust or sand may not be the main issue. OP, if you do follow cyccommute's advice about stripping the factory wet lube and adding a dry, wax-based lubricant, beware that you'll need to be vigilant in (a) rinsing saltwater off the chain with fresh water and (b) wiping moisture away from the chain with a rag. If you fail to do this, then chain will begin to corrode and rust, and then the rust will migrate to the insides of the links, and it will then be getting chewed up by those particles rather than road grit.
Liked 4,222 Times
Stuart Black
Stuart Black
The same could be said of any lubrication in those conditions. Dry lubricants aren't water soluble so they do provide some protection. They just happen to not pick up as much grit as oil based lubricants. Grit, especially beach sand which has a high percentage of quartz in it, is highly abrasive. More so than any rust that could form. You are correct that vigilance is the key but that holds for any lubricant in a salt environment.
I ride a new chain for at least 1000 miles before I remove it to clean and relube it. https://www.sheldonbrown.com/brandt/chain-care.html
lohump, As I understand it the chains are run through their 'packing grease' while the grease is hot allowing it to penetrate the hard to reach places. It's the best lubrication they'll ever have. On the road bikes I leave them alone for quite awhile, on the mountain bike I'll run a rag soaked in WD40 over the surfaces while back pedaling and then use a dry lube before the chain is actually used.
Brad
Brad
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
If you feel like you have to preface a question with, "Not a Noob, but...," then you're a noob. No shame in it. We're all noobs to something around here.
Rider
Wow....You posted an opinion based on nothing. But you are correct. There are some things I've never done and never will. And thanks for your opinion on lubing a new chain!
