What 135mm disc brake hub for my CX bike?
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
My Soma Double Cross DC accepts both disc & rim brakes, It also accepts both 130mm and 135mm spacing. The rear drop-outs are 132.5mm and the frame is steel.
Currently the bike has 130mm Shimano 105 road hubs and canti brakes.
I want to build a new wheel set that has 135 spacing and will later accept a disc brake. For now, I'll continue to use the canti brakes. The rims will have machined sidwalls for rim brakes.
What 135mm disc brake hub for my CX bike? I would like to keep the cost of the hub moderate, in the $100 to $150 range.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
shimano XT, SLX or deore are all good.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Quoted: 910 Post(s)
Liked 288 Times
Will the Shimano MTB hubs accept a ten speed road cassette?
Liked 5 Times
yep, they do.
you got a couple bikes for the race? old wisdom was the wider the gap between cogs ,
the less it would pack up with mud to the extent of not shifting.. or moving..
then the factorys had 9 and 10 speed stuff to sell so that is what they put under the racers, they paid.
2 bikes seems to be the minimum to actually finish , in foul weather ..
the spare bike cleaner an important team member.
Quoted: 910 Post(s)
Liked 288 Times
It will see some un-paved road and easier single track. Some commuting, too.
I need a new wheel set and have decided that the upgrade to disc brakes needs to start with this new addition.
Quoted: 910 Post(s)
Liked 288 Times
Single-serving poster
Depending on how fancy you're gonna get with the number of pawls and teeth the hubs can get expensive... the very least it should have double-seals. This means no deore or deore 4xx... you can get a hope hub for that price... they're ok i've heard but the freewheel is really loud.
