Reynolds Ouzo expansion plug crappiness.
Quoted: 1166 Post(s)
Liked 443 Times
I am reasonably mechanically inclined and for the life of me I am about to scream "total crap!!" when I talk about the expansion plug system that came with my Reynolds Ouzo pro fork. Even when you tighten it as tight as you can get it and install it at the correct depth, the preload cap piece will not be able to be fully tightened down. I have cleaned the inside of the steer tube and the plug itself with alcohol to minimize slipping. After snugging up the preload what seems to ALMOST be enough, the preload cap just turns and turns. When you take everything back apart and check, it becomes obvious that the inner plug is moving. The problem, I think is the plug design. there are slits cut every 90 degrees and the plug piece is held together with an O ring. Well the O ring is not needed because the lower part of the plug does not separate fully. It's slits are cut only part way through. This causes the "expansion" plug to be more of a "V" shaped expanding plug. Bad, bad, bad design! No matter what is done this thing expands out in a "V" shape - not what you need! The top nut preload piece WOULD POSSIBLY BE a good design but I will never know due to this slippage. I will get about one decent ride in before I have to do some heavy braking on a downhill and the fork oscillation during heavy braking will accentuate the fact that the preload was never fully tightened originally, VERY FRUSTRATING! When I do the brake test and apply my front brake and rock back and forth I can almost make the knocking go away but really it is subtly still there. I am using an ACROS headset that is high quality and I don't believe it is the culprit.
Please help! I have made sure that the top cap is not touching the steer tube (there is a sufficient gap). Please suggest an alternative brand of 1-1/8" expansion plug that will just plain work and give me my sanity back!
Quoted: 2026 Post(s)
Liked 1,096 Times
Profile Designs expansion plugs have always worked well for me.
A little North of Hell
Quoted: 71 Post(s)
plugs, inserts and expanders, oh my...
Zero problems with mine, and I have three of them. I run mine with a small spacer above the stem.
Make sure it is adjusted to the proper length before inserting and tightening the 5mm bolt.
Do a search for plugs, inserts and expanders in this forum, lots of info.
https://www.reynoldscycling.com/uplo...stallation.pdf
Quoted: 86 Post(s)
forget the expansion plug. loosen pinch bolts until stem easily slides up an down on the steerer. then just push down on the stem, hard, while keeping the handlebars straight and tightening one of the pinch bolts. if still too loose, try again. or if too tight, ease up a bit on 'push down on the stem' bit.
you can even fashion a windlass with a bit of string and a stick to aid in keeping the stem tight enough, if that's a problem. i know it works, because i've done it on the side of the road a few times with just the stuff i found there.
Liked 443 Times
Liked 443 Times
Quoted: 1530 Post(s)
Liked 718 Times
Yeah, the kind where the expanding bits are all one bit of metal with slits in it is crap. What you want is one with the separate wedges, where the spring or o-ring really does hold it together, preferably covering at least the height of your stem's steerer clamp. Also, if the design tries to combine the clamping and preload adjustment into a single operation, it's almost certainly gonna suck hard.
This Deda one looks like a beauty: https://www.universalcycles.com/shop...s.php?id=29439
Liked 443 Times
