Upgrade Rear Cassette
Follow the Broom Wagon
Bikes: Scott CR1
I'm currently on a 2008 105 equipped bike (I think CS-5600), and am running the standard 53/39 crank to 11/25 cassette. I'm not having any problems with this set-up at all - the problem is more to do with the engine and getting up hills.
I'm thinking of changing the cassette to an 11/28 to see if this will help me at all. I think that this is the cassette used often in a compact set-up.
What I would like to know is if the Ultegra CS-6700 will be able to be used in conjunction with the 105 system that I currently have (105 front/rear derailleur and shifters/brakes). After the last service, I changed the chain to Ultegra, so I may have already answered my question, but need some help from the BF tifosi out there.
Thanks in advance.....
It'll work.
You may need a longer chain. GENTLY shift to the large chaingring/large cog combination. If you need a longer chain it'll be obvious.
ah.... sure.
Bikes: Specialized.... schwinn..... enough to fill my needs..
If you're really having problems with hills... I'd suggest looking into a Compact 6700 Crank. Keep the standard for when you get stronger?
Maximus
I have 2 cassettes (DA and 105) with the same cog combos that you mentioned.
I use both without problems. However I have compact rings (50, 34).
Bikes: '10 BMC Pro Machine, 02 Fisher Sugar 2+
I'm running an 11-28 with an Ultegra standard crank, 105 FD, and Ultegra RD and will be keeping that gear ratio with my new bike. I did go with a SRAM cassette because I like the cog spacing better than the Shimano cassettes. SRAM upper 3 cogs are 22-25-28 while Shimano are 21-24-28.
Carastrophe
Bikes: BMC PR01
i had an 11/25 cassette and changed to an Ultegra 12/27. front is standard 53/39 crank. No problems on exisiting chain and did not even had to adjust the RD. It just fit in.
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
+1 on switching to a compact crank if the hills are giving you trouble. That's about twice the expense of a new cassette, though. Since the 5600 series of 105 has been discontinued, you might find a pretty good deal on a new/old compact crankset.
I'd advise going to a 12-27 cassette rather than an 11-28, unless you really need the 11 tooth cog. The spacing would be more comfortable IMO.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
Bikes: Scott CR1
Thanks KD. Is this a more cost effective solution to what I proposed?
Thanks Smooth. This is an option that I hadn't thought of. Obviously, the SRAM cassette works with the other Shimano components that I am currently running. As mentioned in a previous post, will the chain length possibly need to be altered?
Carastrophe
Bikes: BMC PR01
Thanks Caracella. Did this make a great difference with you? I like the 11 cassette for the descent. I seem to max out at about 64km/h even when pedaling furiously downhill on the steepest section of my normal ride, so if I can keep the 11, I'd like to. Here is the downhill section I am talking about - https://www.mapmyride.com/route/au/sy...28858091174627
My drivetrain is a soup. DuraAce Cranks, 105 RD, Ultegra cassette, SRAM chain.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
I'm currently on a 2008 105 equipped bike (I think CS-5600). I'm thinking of changing the cassette to an 11/28 to see if this will help me at all.
If you want to be sure that it will work without problems maybe consider an 11-27 rather than an 11-28 cassette.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Bikes: '03 Trek Fuel 100, '09 Fuji Cross Comp, '09 Fuji Team Issue/RC
Btw, if the crank is changed to a compact, what else is needed to change? Bottom bracket?
