Does anyone make a 2 speed on a CX frame?
Bikes: Trek Antelope, Surly Crosscheck, Jamis Nova Sport, Nashbar CX1 Cyclocross
I've been looking at a few CX frame commuters.
The Nashbar CX single speed and the Mercier Kilo WT.
My commute is only 7 miles, about half bike trails through Springfield & Eugene. I have two short climbs, one is up a bike bridge over the Willamette. The other is about a 200 yard steep climb that i can take in my normal cruising gear if i really hammer on it. Problem is i've got a little knee issue and it's sore for the rest of the day if i put that much torque on it.
Anyway, a full spectrum of gears is wasted on me, but i was thinking something like a two speed hub on a cx bike would be just the ticket. Does such a thing exist?
Bikes: 1993 NOS Mt Shasta Tempest, Motobecane Fantom Cross CX, Dahon Speed D7, Dahon Vector P8, Bullitt Superfly
Maybe you could put a 3-speed internal hub on one of those bikes.
I think the sturmey archer hubs have a reputation of being extremely reliable. I'd recommend asking the question about how to install on the bicycle mechanics forum.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
My commute is mostly flat but with either half a mile of 8-15% or a quarter mile of 12-20% grade just before I get home. When I feel like taking the single speed, I just walk the hill at the end. Our machismo culture has conditioned us to think of things like that as shameful, but it's actually quite a reasonable option. I got over my pride by thinking of it like a run-up in a cyclocross race. Now I'll even do this with a geared bike if I'm feeling tired.
My Bikes
My Bikes
Quoted: 5888 Post(s)
Liked 3,471 Times
Drop bar bikes with 3 speeds were popular at one time, Pre War Raleigh Record Ace RRA | Three Speed Hub
Soma sells 700c wheels built around 3 speed hubs and bar end shifters.
Dirt junkie.
Bikes: Surly Ice Cream Truck, Peacock Groove road bikem, Salsa Fargo
Liked 6 Times
I like these Sturmey-Archer 2 speed kickshift hubs. You can either get it with a coaster brake or not. So, you get a couple of choices in gearing without worrying about cables or shifters or any of that noise. They seem well built, as well.
Found this. Seems like it's been out of production for awhile: Save up to 60% off new track and singlespeed bikes, Cycles Mercier Road Bicycles | Five Speed Wide Tire Fits Track Bikes - Kilo WT - Save Up To 60% Off Brand new Bicycles
Dirt junkie.
Liked 6 Times
At the end of the day, if people want more gearing they will generally go with the 3 speed IGH or just stick a rear der on there.
Quoted: 1364 Post(s)
Liked 1,678 Times
DancesWithSUVs
Quoted: 7 Post(s)
I've read a few reviews on some of the 2spd hubs out there,and they're not very promising. I rode a bike once with the SA kickback/coaster;was a PITA shifting gears every time I used the brake in traffic(it didn't have a front brake). Shimano,SRAM,and Sturmey-Archer all make 3spd hubs that have proven reliable.
Note,if you're going to add a hub to a single speed bike,check the frame's rear spacing first. Many SS's use 120mm rear spacing,this will limit the choice of hubs you can use.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
Why not just use a 1x8, or 9, or N ?
simple pragmatic easy to care for gearing ?
Quoted: 1062 Post(s)
Liked 665 Times
My situation is similar. Most of the terrain in my locale is pretty flat, but there are a few hills. Three-speed Sturmey Archer IGH's have served me well. A lower gear is also nice in a strong headwind, or if my bike is loaded with groceries. Is it really better than a 1xN derailer system? Probably not, just a personal preference when all is said and done. I rode a 1x7 this winter, and didn't die of shame.
About building a wheel, it's not really all that bad. I'm not a pro bike mechanic, but have worked on a lot of mechanical things. My first wheel build was not my best, but was good enough to get me around safely for a couple years, and then I spent a few bucks on a new rim and gave it another try. Today, a few wheels later, I'm pretty confident that I can build a good wheel for non competitive daily use, so long as I don't try weird cross patterns etc. The IGH's are not dished, which I think makes life a bit easier because the tensions are equal on both sides.
GATC
GATC
Dirt junkie.
Liked 6 Times
I used to have a bike with a 2 speed kickshift/coaster brake. I did not like the brake... But the kickshift worked great. My primary commuter is a singlespeed, and sometimes I wish I could put a kickshift hub on it. But I don't think they make them for 135 spacing.
Liked 665 Times
Note in edit: I"m leaving this here, but @fietsbob has better memory than me, see below.
Our local ... LBS has kick back 2 speed coaster brake hubs in fat bike Which have wide frames , so the axle width to fit a wider frame is possible..
additionally, There is the 2 cog duplex freewheel from (California) White industries , and freewheel hubs to make a derailleur 2 speed ..
and you can change the cassette to be a straight block which has the cogs only becoming larger 1 tooth at a time ..
and there is the potential to fit a Patterson metro crank https://pattersonbike.com/ and have the 2 speeds there and 1 cog on the back.
white eno hub will compensate for the lack of a chain tension adjustable type dropout see Eric's Eccentric Eno , here https://www.whiteind.com/eno/
the 2 speed freewheel is Here: https://www.whiteind.com/new-page
I use my 3 speed a lot . my middle gear is about 58", but you can make the gear range you like with the cog and chainring pick.
NB internal gear hubs are Planet types , there is 1gear fixed in the center of the axle . It's not an axle interchangeable with derailleur bike Hubs.
you have the Eugene bike works Co Op to help you fit stuff https://plus.google.com/117811738019...04/about?hl=en
Liked 665 Times
My middle gear is about the same. That means it's geared a lot lower than the typical Schwinn and department store 3-speeds sold in the US before ten-speeds became the thing. My entire commute has an overall elevation change of about 100 feet (to the top of a bike bridge), and I don't think there are any hills in town that are taller than about 50 - 75 feet at most. The whole area was scrubbed clean by glaciers during the ice age.
If I moved somewhere with more hills, naturally I'd reconsider my whole gearing strategy. But one thing about commuter bikes is that they are definitely horses for courses. My horse is practically designed around my commute.
@fietsbob, thanks for the reminder about the planet gear. I forgot about that, or was thinking about my 1 speed Bendix.
