A couple of Peugeot U08 questions
Hello everyone,
My apologies if these are over-asked questions on here. I'm finally getting a chance to work on the old Peugeot I picked up a couple of years ago. I had the bike shop remove the old cottered crankset because I didn't have the right tools to remove it without the possibility of causing damage to something else. I plan to take out the neglected bottom bracket parts and replace them with a cartridge and a Stronglight cotter less crank. Now, if I bought this: https://www.ebay.com/itm/175088430217 , what size would I need to order this: https://velo-orange.com/collections/...e-alloy-cups-1
Also, the bike currently has a set of Japanese-made steel rims on it. I want to keep the original freewheel, so what should I look for in the realm of alloy rims? The bike has its original MAFAC Racer brakes, if that makes a difference.
Thank you,
-William
Thank you,
-William
Quoted: 261 Post(s)
Liked 346 Times
Square taper cranks are pretty universal. If it's has French threaded on the bottom bracket description then it will probably work as French bikes have a unique thread.
Quoted: 261 Post(s)
Liked 346 Times
Also keep in mind that you need a longer spindle in order to run those vintage cranks. It looks like the one that is up there has a short spindle which is used with modern cranks.
Quoted: 2323 Post(s)
Liked 4,990 Times
So, I was lucky with mine and had some alloy wheels off an old Fuji I used on mine. Those steel rims with the Mafac brakes are just scary.
Check out Velomine for some nice cheap alloy rims that can use a freewheel. Just not sure if the threading is the same off the top of my head.
Wheels like this:
https://www.velomine.com/index.php?m...ath=87_172_176
Wheels like this:
Steel is real...and comfy.
Wheels like this:
Wheels like this:
Assuming they'll accept a French thread freewheel. Might be worth asking about. It's kind of funny to think that I only paid $40 for the bike.
I hate to ask what may seem like odd questions, but I'm kind of new to dealing with upgrading a French bike. My other French bike is a Gitane TdF that I bought from its original owner. It was well cared for, so all I've had to do was basic maintenance on it. This poor Peugeot was quite neglected, and I'm trying to make it better than new.
Quoted: 809 Post(s)
Liked 1,023 Times
UO-8's are great bikes WilliamK1974 and I would also be tempted to upgrade the crank to a more serviceable square taper crank, in fact I did that with an Astra (French) bike that I had. However, if the crank is good, perhaps you might consider greasing the bottom bracket and putting it back together. Then spend your time and money on wheels, which will be worth spending money on.
You could stick with the original freewheel. You can rebuild it or send if off to the Freewheel Spa if you want an expert to recondition it. The Freewheel Spa
How about a picture, when you get a chance. We don't get tired of seeing UO-8's.
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 259 Post(s)
Liked 269 Times
170mm is likely the length of the crank arms. The length of the spindle I hear is dependent on the crankset. Sorry I don't know what is required for that particular one you have linked though.
Likes For rgvg:
That sealed bottom bracket comes in different spindle lengths from ranging from 103mm to 122mm. The question I was trying to ask was if that crankset is a 170mm, does that mean it requires a 170mm spindle? Or is 170mm the length of one of the crank arms from the center of the hole out to the center of the pedal hole. If it's the former, the Velo Orange French thread BB isn't going to work, so I would likely need to seek out a different crankset.
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,478 Times
If your bike has the original Normandy hubs then your freewheel will most likely have French threads and you will need to find a rear wheel with a hub that also has French threads. You mention that the steel rims are Japanese, so perhaps you have replacement wheels, in which case your freewheel may have English threads. Best to post a photo of the freewheel and the rear hub so that we can see what you have, or you can remove the freewheel and measure the threads.
Brent
Brent
If memory and a quick google serve, to reuse the Peugeot cottered crank cups for a Stronglight cotterless crankset, you need a 122mm long spindle and the spindle must be stamped with a "5" . It is possible a stronglight or other French spindle might not have the "5". It took me a while going through the boxes at the co-op to find one that would work. There was a cheap french threaded cup and cone bottom bracket labeled "action" being sold, but it seems to have disappeared.
feros ferio
Quoted: 1393 Post(s)
Liked 1,326 Times
https://www.bikeforums.net/classic-v...ast-night.html
Quoted: 809 Post(s)
Liked 1,023 Times
That bikes looks great @WilliamK1974 . Thanks for the link. Yellow was not a popular color so it stands out in two ways. Steel is real refers to the frame, although our 3 speed members may appreciate steel rims, I would use this opportunity to upgrade the wheels.
That yellow looks close to Rustolum Sunburst yellow. Or Testors hobby paint yellow. That is if you're inclined. It will still ride nice.
I am disappointed to hear that this Peugeot may displace your Schwinn. If that is the case, I believe that it will go on to someone that will apricate it.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
At a minimum, you could start by replacing just the front wheel with one that has an aluminum rim. That's where most of your effective braking is, and you don't have to find one with a rare axle spacing.
RUSA #7498
Originally Posted by noglider
Likes For ThermionicScott:
If I don't care too much about originality but am more concerned about utility, could I put in a French-thread BB with the right spindle length and then put some kind of square taper triple chainring crank on it? With the hilly terrain around here, having some lower gears would make for a better ride. Downside would be finding a set like that which would be threaded for the bike's Lyotard pedals, but that's an acceptable trade-off. I'll save all of the old parts in case I ever sell the bike.
Likes For pfaustus:
You're pretty adamant that I need to do the wheels before the crank, but I'm dealing with a very neglected, hard to turn, crunchy feeling BB. At least with its current wheels, it can be used even if they're not perfect, but without a functioning BB and crank, it's not going far except downhill.
Liked 2,568 Times
All I was trying to say is that when it comes to the wheels, there are options besides waiting for a perfectly matched set that works with your Peugeot's rear spacing. For example, I relaced the front wheel on my old 3-speed to an aluminum rim (Sun CR18) and left the rear wheel completely stock with its steel rim. Stopping is improved so much that I may leave the bike like that indefinitely.
Oh, by all means, go ahead and fix the bottom bracket and crank.
Likes For WilliamK1974:
Yes. But, French threaded bottom brackets can be difficult to find. What I wrote before is how to convert the bottom bracket cups that came on the bike to square taper. Frankly, unless you already have a crank threaded for french thread pedals, pure utility demands tossing the ones that came on the bike.
I wish someone on here would reply who has done something like this and could show me what they did. That would sure be easier than re-inventing the wheel, and I'm very much a "show me" kind of learner.
Thank you,
-Bill
Likes For TPL:
Quoted: 1608 Post(s)
Liked 2,216 Times
The spindle length is dependent on which crank you choose to use. The Stronglight 93 uses a 118 spindle with the French cups, as an example. I would think that combination is one of the more likely ones to be able to find. The price might make you swallow.
There are other options, of course, but the solution needs to be a configuration that support a good chain line while still fitting onto the frame. A spindle that is too short could cause the inner ring to rub on the chain stay. One that is too long may cause issues with shifting either in the back or with the front derailleur. There is some tolerance but not much more than a couple of mm.
Cups first to determine spindle bearing distance. Spindle length to accommodate the location of the chain set.
Sheldon Brown's Threaded Bicycle Bicycle Bottom Bracket Crib Sheet
