Please, what remover for this freewheel?
Old 09-12-22, 08:51 AM
OTS
Quoted: 152 Post(s)
Liked 237 Times in 139 Posts
OK I'm stumped.
I have a box full of removers and ARGGGGH!
Please, how to I get this off?
Nothing I have seems to fit.
Thoughts?
OTS is online now
Old 09-12-22, 08:52 AM
OTS
Quoted: 152 Post(s)
Is this an ATOM FR-4?
I just found tried an FR-4 and I can't get it over the axle nut and I can't get the axle nut off.
OTS is online now
Old 09-12-22, 09:11 AM
OTS
Quoted: 152 Post(s)
I got it, it is an FR-4
OTS is online now
Likes For OTS:
Old 09-12-22, 10:05 AM
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1955 Post(s)
Liked 3,661 Times in 1,679 Posts
That's the deal with the atom. There are super thin walled atom removers. One of my favorite freewheels is an atom. 14-34 6 speed just made for touring. I love it.
52telecaster is offline
Likes For 52telecaster:
Old 09-12-22, 10:34 AM
oneclick
Quoted: 1106 Post(s)
Liked 1,328 Times in 784 Posts
Grab the freewheel-end outermost locknut with either a set of locking pliers or a bench vice with a grooved jaw. Use a good cone spanner on the flats of the other side cone (not the locknut), and if you have a good enough grip on the fw side you should be able to get it off.
When you re-build a rear wheel, if possible lock the fw side cone with a thin locknut and use a shorter spacer between that and the outer, dropout-facing locknut. It's important that the fw-side cone is locked VERY tight; otherwise should it loosen it will recess inward and destroy the hub.
If there is no thin locknut holding that cone in position, it's the outer one that does, and then IT is damm tight instead. With a thin locknut doing the job you can tighten the outer locknut just enough so it doesn't move by itself when the wheel comes off, but is easy to remove to take the fw off - and the axle stays in place.
oneclick is offline
Likes For oneclick:
Old 09-12-22, 11:12 AM
OTS
Quoted: 152 Post(s)
Got it thanks everyone.
OTS is online now
Old 09-12-22, 12:23 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3588 Post(s)
Liked 3,400 Times in 1,934 Posts
Zeus and Phil freewheel removers will fit that model, and slip over the locknut. The problem is finding one, as they've been out of production for decades. They do turn up on the used market fairly often, e.g. eBay or swaps.
File Type: jpg
File Type: jpg
JohnDThompson is offline
Old 09-12-22, 04:14 PM
oneclick
The Zeus won't fit. It has points about .855" dia, the Atom has points .865"; and the Zeus has lands at .810" while the Atom has them at .775".
The Zeus won't fit an Atom FW, its lands are too shallow for the inner points on the fw splines.
The Atom won't fit a Zeus FW, its points are too large for the fw lands.
The Zeus will fit a Zeus FW (of course), but it also fits a Regina Extra.
The Atom won't fit the Regina.
(I tried all the above.)
oneclick is offline
Old 09-13-22, 06:19 AM
JohnDThompson
Old fart
Have you tried Phil?
File Type: jpg
File Type: jpg
Old 09-13-22, 02:59 PM
oneclick
No, don't have one. Does it fit Zeus/Regina?
oneclick is offline
Old 09-13-22, 03:15 PM
randyjawa
randyjawa's Avatar
Quoted: 1372 Post(s)
Liked 1,751 Times in 938 Posts
Pretty sure that I have a couple of those - no name splined 2...
randyjawa is offline
Old 01-13-23, 12:58 PM
JohnDThompson
Old fart
Interesting. I just tried it here, and you're right, the Zeus tool won't fit a splined Atom freewheel. But the Phil and Bicycle Research tools do fit:
I don't have a splined Regina to test, but I do have a Zeus freewheel. All three tools fit, although the Bicycle Research felt a little sloppy. I know the Phil works well to remove Zeus freewheels, because that's what I used before I got the Zeus tool.
I guess the moral of the story is to have a variety of tools available.
Likes For JohnDThompson:
