2011 Madone 5.5 Project Bike
Old 12-01-22, 09:01 AM
sastma
I an opportunity to pickup a 2011 Madone 5.5 frame for $100 thinking it would be a fun project bike. I have 2006 Madone 5.2 and thought I could put the Ultegra components on from that bike on the newer frame. Any thoughts? Are they compatible?
I would also need to get a new BB and thought a Token BB3274 would be a good choice. What are your thoughts on that BB? Any experience with that?
BTW the 06 Madone is being replaced due to a car vs bike incident. Everyone survived but the frame.
Thanks for your Suggestions!
T
sastma is offline
Old 12-01-22, 10:00 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 3789 Post(s)
Liked 2,935 Times in 1,797 Posts
Glad to hear that riders didn't suffer in the incident (and I rarely call a bike crash an accident). Been there and did that a few times myself (walking home with the bike on one's shoulder gives one a lot of time to reconstruct the incident and see how they contributed to the crash).
While I have worked in Trek shops I never bothered to do the homework of comparing model year versions and how much remained the same or were deferent WRT swapping over parts. The BB shell, head tube and steerer, brake caliper spec, cable routing and adjusters could all be deferent enough to not play nice. Also know that in 2001 tire widths and the frame clearances were pretty tight. If you are hoping to run 28mm tires or wide rims do that check before spending $. I will also suggest having the 2001 frame and fork inspected by someone who knows about carbon and its failure modes before your $ leaves your hands. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 12-01-22, 01:13 PM
Lombard
Sock Puppet
Lombard's Avatar
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 747 Post(s)
Liked 649 Times in 433 Posts
Aren't these BB90 frames?
Lombard is offline
Old 12-01-22, 01:17 PM
sastma
That is correct
sastma is offline
Old 12-01-22, 01:46 PM
Shadco
Resident PIA
Shadco's Avatar
Bikes: Gunnar Roadie, Look 765 Optimum
Quoted: 134 Post(s)
Liked 232 Times in 117 Posts
Dont think 2001 frame details don’t matter since the newer frame is a 2011 frame.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shadco is offline
Old 12-01-22, 02:18 PM
KCT1986
Quoted: 175 Post(s)
Liked 138 Times in 104 Posts
Senior moment?
KCT1986 is offline
Old 12-01-22, 02:39 PM
KCT1986
Quoted: 175 Post(s)
Back on topic..
With Trek the changes would mainly be to the BB, seatpost and headtube areas. Trek seems to tweak these parts of the frame regularly.
2011 was still in the middle of the 10 speed era for Shimano race level groups. Not much had really changed that would affect fitment of parts. Derailleurs were the same, Shimano Shadow RD weren't in road groups yet. Brakes were still the same since wheels mainly still used rims in the 20-22mm outside width. Compact cranks were just beginning to appear so 53/39 or so, was still expected.
So, if the frame came with fork, headset and seatmast, most parts should be OK. You seem to have the BB figured out.
KCT1986 is offline
Likes For KCT1986:
Old 12-01-22, 03:51 PM
oldbobcat
oldbobcat's Avatar
Quoted: 350 Post(s)
Liked 283 Times in 214 Posts
28 mm tires will definitely clear the 2011 frame, but if you're using narrower 2006-era rims, they'll be happier with 25s or 26s.
oldbobcat is offline
Old 12-01-22, 03:54 PM
Andrew R Stewart
Originally Posted by KCT1986 View Post
Senior moment?
Yes, my reading issues have been around since before kids got all sorts of "labels" when in school. Still most of my reply holds water. Andy
AndrewRStewart
Old 12-01-22, 04:10 PM
Lombard
Sock Puppet
Lombard's Avatar
Quoted: 747 Post(s)
And that brings up an issue. If your old Madone was a 2006, it probably has those infamous paired spoke wheels. I had those on my 2007 Pilot and the rear wheel developed cracks at 4000 miles. Check the rear wheel spoke holes with a magnifying glass. They are well known for cracks. If you are very lightweight, then maybe they're OK. If so, they're 14mm internal width and the 28mm tires will go on just fine.
Lombard is offline
Likes For Lombard:
Old 12-01-22, 04:54 PM
Shadco
Resident PIA
Shadco's Avatar
Quoted: 134 Post(s)
Yeah and my grammar sux.
Shad
67'er
Shadco is offline
Old 12-01-22, 06:21 PM
Buzzkill53120
Bikes: Trek Domane SLR 2019, Trek Trek Madone 5.1 (2011), Trek 1400 (1991)
Quoted: 41 Post(s)
Liked 59 Times in 27 Posts
If the BB has bearings installed, check their part number before buying BB parts. I have the same model year madone and I had to install oversized bearings after couple of years. No problems after that. The oversized bearings have a diameter of 0.1mm larger for a snug fit. Trek at one time would rework the BB shell to bring it back into tolerance, however I believe they’ve given that practice up.
Buzzkill53120 is offline
Old 12-02-22, 10:21 AM
sastma
Thanks all for the suggestions and thoughts. I'm gonna give it a go.
It will be interesting to see how the old components interchange the new frame. Couple of the grommets are missing but I think I can 3D print some replacements (not seeing those parts readily available).
Great suggestion on wheels. I do want to try 28s for some long rides.
Will be fun to see how a newer BB works out.
sastma is offline
Old 12-02-22, 10:35 AM
Lombard
Sock Puppet
Lombard's Avatar
Quoted: 747 Post(s)
Once you try 28s, trust me, you will never want to go back to 25s.
Lombard is offline
Likes For Lombard:
Old 12-02-22, 01:45 PM
biker128pedal
biker128pedal's Avatar
Bikes: 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C being made an all arounder.
Quoted: 219 Post(s)
Liked 330 Times in 204 Posts
I’d buy buy and try one first on the front and rear. It may be close to the fork crown up front. Should fit tube rear. Then go mullet.
PS. With time the tire will stretch and expand about 1 mm width each side.
biker128pedal is offline
Old 12-02-22, 04:22 PM
jp911
Bikes: Trek Madone 5.2 Dura Ace, Niner RLT9 aluminum, Santa Cruz 5010 CC, Niner Air 9 rigid 29er, Trek Farley alloy
Quoted: 70 Post(s)
Liked 50 Times in 35 Posts
The only other oddball item on a Madone of that generation is the seat mast (not a seat post). There were different mast lengths and you could also trim them, depending on your needs (there's up and down adjustment, but it's not as much as a typical seat post). If your inseam is more than a few inches longer than the previous owner, you might need to find a longer mast.
jp911 is offline
Old 12-03-22, 11:19 AM
sastma
I got lucky with the seat mast. That mast cost $150 by itself new. My frame came with one.
sastma is offline
