Have to figure out my eyewear
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
The last two times I have commuted 15 miles with temps in the low 20's, I used my balaclava but had to remove my eye wear (clear safety glasses) because they were fogging up so bad. I only have the issue when I have the balaclava covering both my nose and mouth. If I pull it down to expose my nose and mouth I don't have the problem, but then my face gets too cold.
What sorts of eye wear are less prone to fogging? I heard mentioned "Visorgogs" in the commuting forum. Anyone used those or have another good option?
Quoted: 287 Post(s)
Liked 266 Times
Quoted: 676 Post(s)
Liked 13 Times
I also thought about getting a different balaclava/face mask that has breathing holes in the front. Not sure how much difference that would make.
impressive member
Bikes: c'dale supersix, jamis trilogy, spec. tricross
i havenever ound it necessary, down to -20F for an hour plus, to use anything more than my good fitting Rx cycling glasses (transitions so theyre clear at night) by using a balaclava and a neck gaiter that i move around to vent versus insulate variably as necessary, i
ve eliminated the need for cumbersome goggles. the other key is TWO caps, snug to my brow that go UNDER the glasses and create a barrier between my brow and the frames) and one over, with a brim to minimize airflow over the top of the glasses.
Grow a beard, a big santyclaus kinda beard. Eat soup, pretzels with mustard, and drink frothy beer. It works for yoopers, it will work for you.
If I am doing anything close to cardio my glasses or goggles will fog up. On the coldest of cold days I need to moderate speed, keep the effort low, and stay cool. On those days I wear a thin neoprene guard over my neck, chin, and nose. It has mesh over the mouth for breathing and a notch for the nose. And I wear ski goggles with the vents totally opened; I remove the foam that covers the vents. I wear this get up when the air temp gets below -10 F or so.
Anything above that temp and I go with no eyewear. I keep my non-tint oakleys coated with cat crap and within reach if I encounter a snow storm.
Bikes: Specalized Tri-Cross
I'd also say ski goggles. And smear some cat crap into any eye wear you use under 50 degrees.
In the words of Einstein
"And now I think I'll take a bath"
Quoted: 7 Post(s)
