Is it possible to tell 1/8 vs 3/32 cog just from image?
Hello,
lets say the seller doesn't know and has no chains nearby to check and can't measure thickness. Is it possible to tell if the cog is for 1/8 or 3/32 chain just from the image? Is there a difference in teeth shape or something?
For example this, there is 18 stamped, does this mean 1/8? Were old Dura-aces or Campagnolos usually 1/8 or 3/32? Do they have distinct markings?
Bianchi Goddess
Quoted: 2969 Post(s)
Liked 3,060 Times
Is it a Uniglide cog or a fixed gear/ track / Pista cog? Is it really 18 or a blurry 16? Check some of the reference sites and see if Dura Ace ever came in 3/32 fixed cog sizes. It always possible it's a typo and should be 16 for the teeth.
Sugar "Kane" Kowalczyk
It is a fix, at least stated in ad. 16 teeth. Now I think it can be a blurry 16... So, old fixed type cogs were usually 1/8?
Quoted: 4882 Post(s)
Liked 4,049 Times
That cog could be either. Dura Ace came about in the '70s. I started my fix gear journey then on 3/32nds chains and sprockets.
Ask the seller if he has calipers and could he measure. Post it here (and quote me). I'll run back and measure mine. (I have both.)
Quoted: 822 Post(s)
Liked 3,074 Times
possible match?
looks very similar to this 1/8 track cog on feebay;
https://www.ebay.com/itm/Shimano-Dur...-/302239888748
Ok, thanks for your input. The seller said that chainwhip fits it so it should be 3/32. I said that I want to buy it. If I get it I will get back here to confirm
Liked 4,049 Times
OP, the Dura Ace cogs are nice but not remotely rare or exotic. If the seller doesn't know what he's selling and isn't willing to find out, pass this up and go elsewhere. If you widen your search, consider also looking for Eurasian Imports cogs. Just as good and preferred by many (including me). Made in USA despite the name.
Also, you could just assume the cog is 1/8". If it is not, it will work just fine on an otherwise all 1/8" drivetrain. I'm surprised that hasn't been said already on this thread. I don't. I stick to 1/8" everywhere on the theory that 1/8" is the hardest to throw off the cog or chainring, therefore the setup that allows the most chain slack. A real advantage if you ride rough roads; not smooth velodromes, use road cranksets with their often greater eccentricity and/or do quick on-the-road wheel flips in gassed state at the tops of hard climbs.
(The reason we no longer ride 1/8" chains is exactly because they are too hard to throw off. The derailleur system is really just one that throws chains off and organizes the landing.)
Likes For 79pmooney:
in Europe I had very little success finding 16t 3/32 cogs. From USA there would be higher shipping cost and customs...
Liked 4,049 Times
Thanks for information! I bought it, should be 3/32. I need a cog for fixie that I will sell. My other fixie also has 16t 3/32. Also, both chains are already shortened for 16t cog, so 3/32 cog is the simpliest solution.
Edit: if you ever are at a place of starting a fix gear from bare bones, consider 1/8". One of the pluses is that common 1/8" chain has pressed in pins that protrude a real amount. The wonderful plus if that is that you can drive those pins out and back in multiple times without danger of chain breakage. Also true of the early 3/32" chains and some to this day. I have seen perhaps one modern 1/8" chain with little protrusion but there are lots with plenty. Ordering 1/8" sight unseen is 99.5% likely to be a chain with those easy to drive links. A simple chain riveter is all you need. And if you make a mistake and cut it short, no big deal. My favorite is the Izumi chain from Japan. Moderate price, $25 US, very reliable. Popular on the velodrome for those not wanting to spend big bucks, both because they work well and their competitors don't fear them breaking and taking them out.
Sorry, I didn't notice the Finland. So Europe is much more 1/8" friendly? I'd like that. Now with internet, a bit more money in my pockets and the 1990s/00s boom here in fix gears, everything is easy to get but for my first 20 years of fix gear, I had none of that. The two different widths meant half the choices in tooth number, available condition, etc. because there was simply so little to be had unless you lived near a velodrome. (I would have a much easier time of it if I was running in cycling circles but I was per-occupied on other fronts in my life and only at times knew folk with knowledge of where unusual bike stuff could be found.)
Again, thanks for information about 1/8 chains
Likes For Jantaras:
Likes For Reynolds 531:
I am potato.
Quoted: 1829 Post(s)
Liked 1,705 Times
I know it is too late. But for what it's worth: Dura-Ace track components, for a short time experimented with 10mm pitch instead of the usual 1/2 inch all other bicycle chains in the world use. If the chain fits weird, you have a rare historical artifact. I only mention the unlikely possibility because it seems the seller doesn't know what he is selling thus you don't know what you are buying.
The number in question looks like a 10 to my eye.
Liked 4,049 Times
So: if I can manage to remember, I'll hunt up what Dura Ace cogs I've got and see if the "LF"/1/8" and "MP"1/8" holds true.
I also saw and noticed a little thing that bugs me. The lettering is stamped very close to the threads. Completely hidden by the lockring. I have to count the teeth anytime it is on a wheel. EAI (Eurasian Imports) cogs have the lettering further out and visible on 16 tooth and above.
Quoted: 2625 Post(s)
Liked 3,174 Times
Liked 3,174 Times
I am potato.
Liked 1,705 Times
I have no idea it's value. I just know I couldn't sell it.
Phyllo-buster
Quoted: 2300 Post(s)
Liked 2,066 Times
LF = June 1987
Quoted: 4567 Post(s)
Liked 6,548 Times
Likes For merziac:
