Ti bike for large rider (6/4 vs. 3/2.5)
Bikes: Bianchi, Colnago
I have worn out my Colngao Master, over 30,000kms, and a some rust has helped to finish the job. I am 6'2", and about 200lbs. I am a strong rider, Cat. 3, seldom race, enjoy hill climbs (self-punishment), long rides 100 miles, and maybe a time trial once or twice a year.
Is there any real difference between the two grades of Titanium. I am looking at the Vortex vs. Tuscany, and the Merlin 6.4 vs. 3-2.5. Price is not an issue, although I won't spend the extra if I don't need too, I will if a non-pro will notice a big difference in the two rides, if not, there is no sense in wasting money.
and I have heard ti is a bad material for heavy riders. it has more flex than steel and so when you put a big fellow on it like yourself it might feel kind of squishy : )
Originally Posted by brianallan
how is it worn out, and is it for sale!
Don't Believe the Hype
Bikes: 1999 Steelman SR525, 2002 Lightspeed Ultimate, 1988 Trek 830, 2008 Scott Addict
Quoted: 21 Post(s)
I ride a Lightspeed Ultimate, which is 6/4 in the bottom bracket area and 3/2.5 in all other places.
I can definitely tell a difference between the 6/4 in the bottom bracket area and the relative flex of 3/2 in the Lightspeed Classic. I really felt the difference when trying both models with comparable wheels, tires, psi, seatpost, etc.
I am 185lbs and have seen and heard the same thing from others.
(i am cat5)
(i am cat5)
Bikes: Giant TCR2
In terms of stiffness, 6/4 is 7-8% more stiff than 3/2.5. That's not even noticeable. However, 6/4 is quite a bit stronger (maybe 20%) which allows for the frame to be designed differently to take this into account, providing a more stiff ride. So it won't necessarily come down to which material will work best for a larger rider, but more to which frameset will work best. The only way to tell is with some test rides.
(i am cat5)
(i am cat5)
Former grouch, now happy
Example:
Aluminum: stiff (Klein and Cannondale); compliant/whippy: Vitus, old Alan
Stiffness is largely a function of tubing diameter and shape. Most newer Ti frames, particularly in the larger sizes, have an oversized down tube, which is one of the key design elements that will lend greater stiffness.
Spectrum Ti Super | Landshark Roadshark | Serotta Colorado | Gunnar Crosshairs | Trek 9800 | Santana fillet brazed tandem | K2 Easy Roller | Dawes (BD) Bullseye 1x1
Industry Maven
Bikes: Thylacines...only Thylacines.
I think I'm qualified to respond to this one.
There is no right or wrong material for your height, weight or abilities. It's how the bike is designed to take into account these factors. You don't ride a tube, you ride a frame, so a frame of either material will be fine if it's designed right.
I'm completely biased of course, but I don't understand why you'd want to spend such a huge chunk of change on an off-the-shelf bike, when for the same price you can get custom. The problem is exacerbated when it comes to us big guys too (I'm 6ft 3ins, 205lbs) - most off the shelf bikes in our size have atrocious geometry that is far from optimal. I know this because it was one of the contibuting factors of me starting this business!
What is your budget for the frame and forks or complete bike? You mention you only race every once and a while, so is this going to be your only bike?
Originally Posted by Thylacine
[Commercial post]
I can't imagine this; you must have paid some tribute to Joe.
Up and comer
Check out the Douglas frames from Colorado Cyclist (www.coloradocyclist.com). They have 3/2.5 & 6/4 frames that are virtually identical to the Litespeeds, made in the USA, & are about half the price.
As for the difference, I'd say go for 6/4 if you can afford it. If you get a 3/2.5, you'll spend a long time thinking, "maybe I should have gotten the stiffer, better one..."
Budget is not an issue, and this is not my only bike, I have a cyclecross bike that doubles as a trainer and touring bike. I have a Cat. 3 licence, I just don't like racing crits and circuit races. I have all the components, I currently have Record 9sp Carbon. The only new purchases will be the new Carbon Cranks, BB, Headset, Seatpost, and Front Derailer, all stuff that wont transfer due to the differences in the bikes.
If I don't like the ride of the Ti bikes, then I will probably just get a C50, or President, but I have always wanted a Ti bike.
Mufflerman
Talk to Tom Kellog at Spectrum cycles https://www.spectrum-cycles.com/ He will design the bike for you and Merlin will build it. Give him a call he's a super guy and won't steer you wrong.
Longing for a Tail Wind
I am 6'3" and 250 and ride and '05 Litespeed Tuscany. One of the reasons I chose it was a discussion from this website (See link) about the relative merits of 3/2.5 vs 6/4 titanium: https://www.bikesportmichigan.com/rev...uscany03.shtml
I think the technology might be there for extruding 6/4 titanium now though, I don't know. Do I think my bike is flexy? Maybe, but it sure is comfy. I previously owned an aluminum TREK, so I was looking for more compliance.
Hopped up on goofballs
https://www.spectrum-cycles.com/624.htm
FWIW - I am 6'2", 200lbs and ride a 2004 Litespeed Teramo (3/2.5). I don't race, but I do have to chase my faster buddies from time to time. I haven't noticed much flex in the frame.
Bikes: Giant TCR2
I believe Tom Kellogg has noted that what he wrote there is kind of old news now...there have been improvements, such as seamless 6/4 tubing. I mean, he is pushing 6/4 frames a lot now...take a look at the new Merlin Works line.
Get the stick.
Bikes: 12 Y.O. Litespeed MTB, IRO Jamie Roy fixie, Custom Habanero Ti 'Cross, No name SS MTB, Old school lugged steel track bike (soon)
The idea that Ti bikes are flexy is a reputation that has it's roots in the first generation Ti frames. The first Ti bikes, like really old Merlins, were made of aircraft hydraulic Ti tube, which I assume was available in small diameters with relatively thick walls. If you've seen one of those old bikes, they are very similar to steel frames in terms of tube diameter used-like ~1" diameter main tubes . As a result, they were roughly 1/2 half the stiffness of a comparable steel frame. Thus the reputation.
Current Ti frames use tube diameters that much larger, and as a result can be very stiff. My frame uses larger diameter tubes than many aluminum bikes. Keep in mind that for geometrically similar parts, ie the same physical size and shape steel is stiffer than Ti which is stiffer than aluminum. Thus, a 4 lb Ti frame, using the same tube diameters, will be stiffer than a 4 lb aluminum frame.
I'd say don't worry too much about the alloy used. Test ride the bikes. Also remember that lots of things besides the frame can make a bike feel stiff or flexable....like wheels, bar and stem.
Thanks for all the comments. I can't wait to ride one on Monday and make a decision.
Peloton Shelter Dog
I ride a Cannondale Six13 for more competitive rides and an Ibis Titanium Road (3/2.5 butted Ti) the other half of the time, particularly for longer rides. But I weigh 165lbs. If I were 200lbs I'd seriously lean to the CF/Six13 type of bicycle - simply because I'd be a bit skittish about Ti being too mushy. That may be one reason you don't see much Ti in the pro peloton. Floyd Landis reportedly generates TWELVE HUNDRED WATTS in a sprint. I would guess a Merlin might feel like a wet noddle under that much wattage. And the bigger/heavier you are, the more crucial this factor becomes.
I'm only throwing this out there because you're a strong rider - a Cat 3 racer who's 200lbs - and it's a significant point to consider. I also realize that there's nothing quite as nice as a Ti bicycle - but in my opinion the comfort/responsiveness does come at a price in performance terms. I can feel it in my riding (I get to 'A-B' these bikes on a daily basis). Particularly on hills/sprints. But I often PREFER the feel of the Ibis Ti, especially on rougher roads/longer rides. Love the Cdale, but nothing is quite like Ti.
Bottom line is that the Ibis Ti Road gives up SOME performance to the Cannondale (or insert name of favorite CF racing bike HERE _____) - but I'd say it's that 5% edge. But every now and then that 5% is VERY nice to have on your side, all that 'it's all in the motor, why don't YOU Lose 5 lbs off your butt' stuff aside. Um... I already DID lose the 5lbs, and I've been working on my motor for a long time now.
Industry Maven
Originally Posted by H1449-6
I don't see a red star next to your name. Is it possible that you have posted 2,600 plus mostly commercial messages on this board, and have a link to your company in your signature, all without paying a measly $25?
However, if someone has a question about material or ride qualities or whatever, I like to contribute - especially considering I'm 34, the same height and weight as the OP, AND I've been riding roadbikes all my life. The fact that I'm in a good position to contibute is just a bonus as far as I'm concerned. It's like you get the benefit of consulting a pro consultant, minus the bill. Everybody wins.
Don't like what I have to say? Simple - don't read it.
Baby it's cold outside...
Bikes: Trek 5000, Rocky Mountain Wedge, GT Karakoram K2, Litespeed Tuscany
I'm 5'11 & 200 Lbs. I ride a 2003 Tuscany (3/2.5) and it is stiff enough for me and my big pipes... As others have said here, frame design is more important than actual material in this case.
The Tuscany is a fine machine, and you will not be dissapointed
Bikes: Litespeed, Medici, Gary Fisher
...skittish about Ti being too mushy. That may be one reason you don't see much Ti in the pro peloton.
For the orig poster, there are plenty of frames from Litespeed, Merlin, Seven, Serotta, Hab., etc. that will probably fit the bill ... or several, several BILLs (as in Ben Franklin that is).
Titanium didn't seem to bother Robbie McEwan, a very strong sprinter...
In 2002 he rode a Litespeed and won:
2 stages of Paris Nice
2 stages in the Giro d'Italia
2 stages of the Tour de France
Green jersey in the Tour de France
-Trek 5000* -Project Litespeed* -The Italian Job* -Rocky Wedge* -The Canadian Connection*
