Front shock leak?
Front shock leak?
Hi
I just bought a used bike and the front left fork shock has a leak and needs to be completely rebuilt. costing about $200. right now the front end is supported by just the right fork.
My question is if I ride until both sides fail, will the rebuild be more expensive? should I not ride it until it's rebuilt?
tks
tks
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
buy a new fork.
Avoid Bucklos, and any other super-cheap chinese forks, unless you have a death wish.
Liked 739 Times
PS.. $200 for a complete fork rebuild is not unreasonable at all... and yes, the longer you ride it, the more it will cost due to increased wear rates created by lack of lube, dirt getting past bad wipers, and worn bushings...
Likes For maddog34:
Liked 739 Times
Fox suspension is well worth rebuilding.
Likes For maddog34:
Clark W. Griswold
Quoted: 4369 Post(s)
Liked 4,009 Times
Yeah get it rebuilt and NO NEVER wait until it totally fails, maintain your bikes and the parts on it and they will last longer and work better. Don't run things to the point of failure unless it is some wallymart BSO type thing but that is a whole different story. Fox Forks are good are worth rebuilds and maintenance and all of that. I have a 36 Factory on one of my bikes and it is fantastic. There is probably not a product from them that isn't worth a rebuild if not totally damaged and beyond repair.
