Time to rescue a stuck, jungle junker. The 1986 Jim Merz Allez!
#76
Port
Quoted: 996 Post(s)
Liked 1,929 Times
Here we go again...
Likes For Rocket-Sauce:
#77
www.theheadbadge.com
Quoted: 2432 Post(s)
Liked 4,439 Times
-Kurt
Likes For cudak888:
Likes For thinktubes:
#79
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1272 Post(s)
Liked 3,658 Times
Okay I’ll give the hacksaw thing a try. Still super leery about it but why not. If that doesn’t work I’m 100% absolutely going lye and there is nothing anyone can do to dissuade me
There were 135 Confentes, but only one...Huffente!
Likes For AdventureManCO:
#81
The Huffmeister
Liked 3,658 Times
Funny story about the Wilton. Got it from my father-in-law, who got it out of a dumpster where he was working at the time, on a govt contract. It was
technically ‘Govt property’ but the gov wanted a bunch of stuff gone, so - garbage. Tons of really useful stuff - trash. The govt ordered a bunch of stuff thrown out and technically they weren’t allowed to save any of it but he couldn’t let a perfect good vise go, so he snuck it out
He told me that one time they ordered work gloves for the team, and it came to $400, and went through the govt contract to place the order. Someone down the govt line accidentally got the decimals wrong, and it was invoiced for $40,000 instead of $400. There was no system in place for issuing a correction, or talking to any particular cog in the machine about the mistake that was made in hopes of explaining the mistake. Most expensive pairs of work gloves ever made, apparently. He told me this stuff happened all the time, and was just jaw-dropping the stuff and the waste he saw.
Thanks taxpayers!
Thanks taxpayers!
#82
Quoted: 2360 Post(s)
Liked 2,879 Times
Likes For squirtdad:
#83
The Huffmeister
Liked 3,658 Times
#85
The Huffmeister
Liked 3,658 Times
Oh and by the way Kurt, don’t you dare think I was too enveloped in the seatpost debacle to miss this gem.
I only hope that you were not so enveloped in the debacle yourself to miss mine
#86
Bikes: a couple
Quoted: 563 Post(s)
Liked 868 Times
In Jr High, circa 1975, We were learning about mineral acids, I heated test tube of dilute(I want to say nitric acid, but I'm not sure of that) acid and managed to get some on my clothes. I forgot until my mother washed them and they literally fell apart whereever the acid landed
#87
Bikes: A few too many
Quoted: 1365 Post(s)
Liked 2,186 Times
Forge on!
Best, Ben
Voltaire
Voltaire
#88
Liked 4,439 Times
I will nevertheless re-read more throughly for your sick burn. 😂
-Kurt
#89
The Huffmeister
Liked 3,658 Times
#90
Liked 4,439 Times
Sounds like both of our BFTool powers are unlocking for our respective projects.
And by that, I don't mean "BikeForums."
-Kurt
P.S.: Did you mean the seatpost saga as a whole in your earlier post? If so, I've been watching every minute of your agony with great interest
-Kurt
#91
The Huffmeister
Liked 3,658 Times
Expect FAR MORE BB pictures to come!
#92
Quoted: 1150 Post(s)
Liked 1,780 Times
I've gotten good with my friendly Sawzall. The last one I took out was stuck 8" deep. I put the frametube horizontal in the stand, and just held the tool so the blade parallel to the post with no extra weight than gravity, a couple of beers, and press the trigger, you have that out in minutes. I also used some all-tread rod, a couple of washer, a socket and a nut to create internal slide-hammer to aid my process.
#93
Liked 4,439 Times
#94
SE Wis
Quoted: 2752 Post(s)
Liked 3,412 Times
Likes For dedhed:
#95
The Huffmeister
Liked 3,658 Times
Come on now! You were the one who suggested I invert the frame so that the BB was at the top. You bringing it up was all the permission I needed.
But let's be honest, I never need permission if we're talking BBs. At this point, its just a given
#96
Quoted: 884 Post(s)
Liked 2,316 Times
#97
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,303 Times
Wow that is a nice Skokie saw blade handle! If ever there was a good blade handle for a job like this then that is the one. With a sharp and well-oiled blade...
I had already typed this post before seeing dedhed's saw blade handle, and have had good luck using the Sawzall myself, so:
How long before we give the Sawzall a try, so as to relieve the fierce interference between the seat tube and the oversized post?
I so wish that I could have used it on the one pictured below, but the oversized post was steel unfortunately.
The few cautions/notes on Sawzall (or really any saw/blade use) are:
First assess the post length and the post ID so as to select a long and slender enough blade to reach the entire length of it.
Then assess and add the saw's stroke length, so that the blade tip never catches on the post or seat tube opening.
Make sure that the teeth near the blade's tip are sharp, as they will need to be.
Fashion a sharp probe from a bent-tip spoke to test the cut for full penetration to bare steel (the sharp tip "grabs" aluminum but not steel).
Insert oiled blade into the post, clocked away from the slot in the seat tube's lug.
Have cold beer at the ready for after-work celebration.
Drink cold water first so you won't feel so hurried. Be extra attentive/sober whenever using powered tools (I once distantly observed a hot-headed dude drill a well-deserved hole right through his Subaru's expensive A/C condenser while apparently drilling mounting holes for fog lights into his bumper brackets, the ozone layer has been recovering ever since)!
Relax while working and imagine how much time and effort you are saving versus having to work a saw manually! Re-apply oil periodically and keep plenty of slack in your power cord. Don't be "that guy" who borrowed/stole my extended-length drill bits without permission to "modify" and "improve" his Subaru... ...I'm still able to laugh about that after all of the past 32 years.
Again be sure to assess the saw's blade stroke with respect to the tip of the reciprocating tool itself and the tip out at the far end of the blade, (both relative to the ends of the aluminum seatpost).
The post needs to be cut completely through, starting from it's very bottom end (but only just up to the approximate height of the slot in the seat tube lug, and no further). This will prevent the saw blade tip from ever threatening the seat tube lug opening as long as you tilt the saw so as to do all cutting using the teeth near the tip of the blade (why the teeth near the tip need to be sharp).
It has been found to be impossible to cut into a seat tube ID with the teeth out near the tip of the blade, unless the blade is leaned toward the edge of the seat tube opening.
Higher-grade aluminum may challenge a blade's required degree of sharpness.
Taller-section blades may need to be slenderized using a bench grinder to fit within the post ID.
Ideally, one would practice first on a disposable frame and post, just to be more at ease with positioning the frame, handling the saw and manipulating the moving blade.
Once the slot is continuous with no aluminum bridge remaining, moderate torque on the un-slotted post stub will impart a sort of twisting along the post such that the two narrow faces of the cut try to move up and down within the seat tube, and the post is free. This last step should be relatively easy but is further eased by use of WD40.
Once again we are not trying to cut into the seat post itself above the height of the bottom of the seat lug slot.
#98
Quoted: 1965 Post(s)
Liked 2,059 Times
I'm very fond of the Jim Merz SE Allez and hope patience rules in this stage of that bikes restoration. Besides, the paint looks ok.
#99
Liked 4,439 Times
-Kurt
#100
SE Wis
Liked 3,412 Times
https://www.ebay.com/itm/37462649017...MaAlJqEALw_wcB
