Brakepads, cool-fin or not
Quoted: 13 Post(s)
It's time to change brakepads on my CX.
I have Shimano SM-RT56-S rotors.
Rear-brake... I had my bike in for "annual tune up" som time ago.. and they changed it.. to J02A-resin,.. with cool-fin
Front... i changed my self the last time... (first time on that bike).. and it was original J02A.... the shop was sold out, but the guy said it's not a big deal... so i got the G01S in stead.... and it has been ok.
I have heard that with my rotors.. (and since i don't rolling down the Alps and things like that"... it's no really need for cool fin
(so i guess the guy that took the last service.. put on a pad with cool fin... just to get mor money.... (not too big difference but..)
So one simle queistion.
Cool fin or not.
Cool fin or not.
Tell everyone about your high speed descents? do you have a lot of them?
Already have aluminum hub discs , with a steel outer ring..? they dissipate heat, also..
Quoted: 13 Post(s)
The rotors says resin-pads only.
There is some decsents both gravel and asphalt.. and somtimes a little bit rougher (like (not to steep) slalom-slope).....
I did'nt get what you ment with --Already have aluminum hub discs , with a steel outer ring.--... so I hope the pictures wil help.
Quoted: 13 Post(s)
This graph shows how much ups and downs i go...
Descents on asphalt i brake-loose-brake-loose-brake... as i feel like, same on gravel...
When its more rough i tend to hold the brakes more to ride as slow i can to feel safe
yours are not ones where the disc is riveted on closer to its edges..
stainless steel does not dissipate heat any where like aluminum will.
so until you replace the disc, the fins added to the pad backing is all you can do.
hydraulic discs heat the brake fluid, unless the heat can be shed some other way..
I just ride around town, disc brakes in winter rainy season ... there, I don't need anything special..
you mostly complaining they used what they had in stock when you came in,
and wished you could have saved a couple bucks on the work done?
Quoted: 13 Post(s)
I don't complain...
I just want to know if there is any point for me, with my kind of riding (no winter, no rain)... to buy pads with fins...
There is not that big a different in price, but a buck here and and buck there.....
btw...
it was to different places with the service (this summer)... and the place i bought the pads back in the fall of 2016..
And my english is noth that good, and google translate was not much help...
What did you mean with heat-things you said.
... and is it any point to change the rotors?.. is the rotors i got a cheap version?
btw...
So what's the cost difference? (look it up)
my BB7 pads aftermarket from Kool stop are quieter than the factory stock.
Quoted: 1221 Post(s)
Liked 629 Times
You're current setup is fine. If you never notice brake fade, just run what you think is cheap. My mtb has your same setup and I've never had a problem where I live. I don't have cooling fins, I have cheaper discs. All deore.
Quoted: 13 Post(s)
J02A about 20 usd
G01S abou 9 usd
have not checked non-shimano pads.
.... on my preferd online shop.
For me personally... non of the prices is "frightning"... my bikes are my kids.... (and you can't put price on them...un til a sertain point off course)
G01S abou 9 usd
Well, assuming that you have right now 160mm, going to 180mm would make sense if you would go downhill a lot. However, you have currently as far as I understand no fading issues, so it is not needed.
If you're not noticing fade you don't need any additional heat management so the fins will do nothing for you. The big obvious sign to recommend fins/icetech rotors is when the rotor is discolored.
Quoted: 13 Post(s)
I don't complain...
btw...
btw...
As others have said, if you don't experience fading, no need to upgrade. If you need more braking power in general, get larger rotors and get some that are allowed for metallic pads. Metallic pads conduct heat better in addition. Larger rotors give you more braking power and heat dissipation surface.
Some over-engineering never hurts.
I prefer larger rotor in front to have a front bias when braking, like 180f/160r. or 204f/180r. YMMV.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Cool fin or not.
Cool fin or not.
See:
https://docs.google.com/spreadsheets...it?usp=sharing
For everything you could want to know about Shimano disc rotors/pads. Pad differences are defined in rows 73-81
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Brake fade is one of the scariest moments in cycling.
Not finding out the limits of my brakes is worth the extra money to me and "No need" isn't a good enough reason not to get finned pads.
Everyone needs to make their own choice. That's mine.
-Tim-
-Tim-
Quoted: 13 Post(s)
A stupid question. by fading.... you mean that is worning out-process.
I understand the word fade gramaticly in a way... but not 100% sure in this case.
I usually do simple things like pad-change self... but the the ine time it was an overall checku-up of everything..... I feel its ok to do that annualy....
day-to-day maintence.... i usually manage to do.
Quoted: 13 Post(s)
- Soli Deo Gloria -
Liked 736 Times
Fade is typically caused by heat after repeated, hard stops or prolonged braking.
The brakes work fine but then you squeeze the lever (or step on the pedal in a car) and it doesn't stop as well. You squeeze harder and nothing more happens. Worse case is you squeeze the lever as hard as you can and there is nothing.
All friction surfaces have a temperature range in which they operate. Race car brakes operate at a very high temperature but don't function well when cold. Street car brakes function well at lower temperatures but will fade if heated beyond their temperature range due to repeated hard stops like a race car.
Other things can cause fade - off gassing is when the friction material gives off gasses which form a layer between the rotor and pad. This is a problem in automotive brakes. I've not heard of this in cycling. Usually it is heat.
-Tim-
-Tim-
-Tim-
-Tim-
One of the "innovations" we got with flat mount, at least on Shimano calipers, is that the surface area of the brake pad is now substantially smaller compared to post-mount pads like the J02A. So having good heat dissipation on those is more important than ever. This is not a concern for the OP, but I just thought I'd mention it since this is one of the things driving the designs of Shimano's latest rotors with all the fancy vents and vanes to help cool them.
biketampa
19
01-16-17 10:09 AM
unterhausen
16
08-18-14 06:56 AM
Noonievut
15
07-15-14 02:52 PM
