Women shoes with cleat covers
Quoted: 106 Post(s)
Hi all.
Im trying to get my wife some cycling shoes. She may want to start using cleats in the future but I thought getting her a shoe with a more rigid sole (vs the running shoes she uses now on platform pedals).
Any benefit of wearing dedicated bike shoes without cleats?
If yes, they use to have shoes that were "cleat ready" but also came with a cover.
Any suggestions?
Any suggestions?
Quoted: 6196 Post(s)
Liked 4,811 Times
You might look through the websites of all the companies that sell cycling shoes. I think some or many make shoes specifically for cycling that don't have a cleat. Or at least they use to.
Basically, you are on the correct path... a more rigid sole so there isn't any annoying flex.
I use spd pedals and shoes with my road bike. Their design tends to make it easier to walk in those shoes without a cover on them. And for certain all the spd type shoes I have bought come with covers to go over the mount for the cleat if one doesn't want to use cleats.
Quoted: 106 Post(s)
I wonder how would pedaling with the SPD cleat compatible shoe (with no cleat) be on a flat pedal.
(I also use SPD with my road bike - is easier to walk around)
Quoted: 2496 Post(s)
Liked 739 Times
I don't think it matters to an SPD shoe whether or not cleats are installed. My old Shimano MT41 shoes came with textured inserts so the sole of the shoe was flat until the insert was removed. My newer Giro Rumble shoes have cleats. Cleat covers fit over the cleats and are to keep the cleat from scratching floors. I do not think it does any harm to a shoe to simply not install cleats if you don't need them. Yes, absolutely, the rigid construction of a cycling shoe is of benefit, with, or without, cleats.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,648 Times
I would recommend getting mountain bike shoes which are all pretty rigid with two hole mountingfor spd pedals. Those shoes are easy to walk around it even with the cleat attached - compared to many road shoes. The there are combination flat pedal on one side and spd on the other, so she can choose whether to clip in or not. Was looking at Amazon last night and some of those pedals are as cheap as $30, but I went spend more for better quality. They have shoes as well.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Liked 4,811 Times
Even with the cleats on my shoes, the cleats just barely, if at all touch the surface I walk on.
But I'm not sure if those other shoes you are talking about are spd or spd-sl.
Likes For Iride01:
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
Hi all.
Any suggestions?
Any suggestions?
Liked 739 Times
I'd disagree that on a SPD shoe that they are just to keep from scratching the floor. When the cleat is not installed, there isn't anything that might scratch the floor. The mounting holes are well below the depth of the tread on the shoe. The covers are there to keep mud and grime out of the holes and mechanism of the mount for the cleat. Presumably just in case you later wish to put cleats on them.
Quoted: 1944 Post(s)
Liked 2,164 Times
SPD touring shoes (no cleats) with rubber soles can be used with toe clips and straps, or half clips on quill road pedals. Not as solid a connection, but “generally” stay put.
John
John
Liked 739 Times
I know that for women's cycling shoes with shoe covers, there are several options to suit different preferences and riding styles.
Personally, I can recommend the Shimano SH-RP2W women's road cycling shoes.
In fact, these are entry-level road bike shoes designed for comfort and efficiency. Therefore, even beginners will be quite comfortable.
Compatible with 3-bolt mounting systems commonly used for road bikes.
You can use them with optional spike pads for protection.
Likes For Yan:
Mtb shoes
5-10 mountain bike shoes an pedals with little pins we both have them , nice an firm an never have to worry about un-clipping !!!
70 YO
Pedals
70 YO
Pedals
Quoted: 1401 Post(s)
Liked 1,886 Times
QUOTE=dvai;23131031]Hi all.
Any suggestions?[/QUOTE]
yes - the benefit can be a stiffer sole - better for power transfer - and can prevent injury to foot (plantar fascia and related)
and they can also save your good tennis / running shoes which are often more expensive than low-to-mid level bike shoes
as mentioned in prev post by Yan @Yan - Shimano low end mountain bike shoes are a good option
Pearl Izumi, Bontrager, Specialized, etc also offer these types of shoes
the sole plug should be in the shoe when cleats are not used - they provide additional surface area and sole rigidity when attached
attached pics above
top two pics are Pearl Izumi shoes (Trans Alp models - can’t recall specific models)
third pic from top is an older Shimano CTxx shoe … CT40 or CT71 … can’t recall specific model … they were offered with laces, laces and velcro straps, and speed pull closures (depending on model)
bottom pics are a more recent Shimano MT7 shoe … this shoe is a level above the CT model shoes … stiffer sole with BOA enclosure etc
attached pics above
Quoted: 200 Post(s)
Liked 65 Times
Hi all.
Any suggestions?
Any suggestions?
