Low sprocket min GRX-812
I have a Jamis Regnegade S2 1x11 with a GRX-812 RD. Specs are:
GRX 812 specs:
Top sprocket: Max. 11T/Min. 11T
Low sprocket: Max. 42T/Min. 40T
Total capacity: 31T
It currently has a 11T-40T cassette. I'm looking at a set of build wheels for the road with a 11T-30T cassette. Would this be pushing the Low Sprocket Min too much? Would it just result in poor shifting or would it actually be dangerous? I'm guess I don't really get the minimum spec since there is probably a sprocket close to 30T somewhere in current cassette and everything works fine.
Thanks in advance,
George
GRX 812 specs:
Total capacity: 31T
Thanks in advance,
George
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
The low sprocket rating of 40-42 teeth is because of the angle the derailleur is designed to travel & be a moreorless consistent distance from the relevant cog.
Too close & the derailleur will shift by simply crashing the chain into the next cog or dragging it away.
Too far & the angle necessary to derail the chain won't be enough. Shifting will be vague & inconsistent.
There is little safety risk in installing a cassette too small, but at best it'll shift like garbage. Even if you get half the cassette to "sort of work ok" the B-screw adjustment will only be appropriate for one side of the cassette or the other. The other half stands a good chance of not working at all.
The key to smooth, reliable shifting is the derailleur "floating" a consistent & proper distance iaway the cogs. So that the chain is guided over until it self selects the cog you desire. This is the function of the B-screw adjustment. The angle of the parallelogram, spring tension, cog stack, & other factors are specially selected to this end.
