AVA "death stem" fact or fiction
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 310 Post(s)
Liked 679 Times
I have modified a couple of these stems on non-collectible older bikes by cutting off the tabs at an angle and replacing the plug with an angled wedge. I am not an engineer, but it seems like this should eliminate the problem of the stress being concentrated in one place at the top of the tabs. Any thoughts on this hack? I suppose it would not fix the problem of a stem being too small or too light for the job.
Likes For albrt:
Quoted: 4806 Post(s)
Liked 3,931 Times
I haven't heard of AVA's breaking but then I took mine off my UO-8 and put on a TT or Cinelli. I did associate those stems with injury and suffered one I will never forget but it was hardly life altering. I impacted my sternum hard on that bolt as a early teen. (Hit a rock I didn't see coming down a fast descent into a free-for-all intersection. Hands lightly on the bars and brakes. Hands got knocked off, I slammed that stem and flew through the intersection with my hands down by the hub. Pretty sure I woke up a few motorists. No stems with protruding bolt heads have graced one of my bikes since.
Quoted: 1829 Post(s)
Liked 3,376 Times
Yeah, these stems are not the greatest. The failure that I've seen mentioned the most is the cracks the start at the slots in the quill.
A quick shot of a slot in an AVA stem that I owned briefly...
When I owned this AVA stem, the thing that caught my attention was the remarkably lack of stiffness in the extension. I attributed this to the fact that the extension is hollow, leaving not a lot of aluminum to handle the bending and torsional loads. This hollow extension also indicated that the stem was cast instead of being forged, resulting in less strength in the aluminum that was there. I wasn't ready to trust that, so it went to someone who liked this bit of French engineering.
In all fairness, it wasn't just AVA that used these square ended slots in their quill. The GB stem on my Raleigh International has them too. One suggested fix is to get rid of the square corners of the slot, since they act as stress risers (i.e. places for the stress to concentrate and promote the formation of cracks). Changing the shape from square to round is one way to deal with this. Here's a shot of my GB stem in its current state.
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
Quoted: 1088 Post(s)
Liked 1,205 Times
I had a broken Ava on a Puch that came to me as a freebie. That was all the evidence I needed. Admittedly, I’m not a purist, and it’s important to me that I’m not worrying about safety or basic function when I ride. The crack started at the slit and had progressed to about half the circumference, so I’m glad I never rode with it.
As steelbikeguy notes,GB stems had the same design flaw. I had a (Schwinn Approved) GB that developed a crack on the corner of the square slot. My death was not imminent, but I did NOT use it for long after I noticed the crack.
Liked 3,931 Times
I liked the old soft metal HBs. Much more likely to bend than break.
Quoted: 310 Post(s)
Liked 679 Times
Here is a picture of a doctored death stem.
It seems to me even if the tip somehow broke off at the location of the old failure point, the stem would still be wedged firmly in the tube. Again, that does not protect you from other potential failures due to the stem being too small, too light, not inserted far enough, etc.
Likes For albrt:
PeopleCode delaminator
I had a early 70s UO-8 with an AVA stem. It broke completely while I was in my driveway and just starting out on a ride.
I ended up in the rhododendrons. Easily could've been much worse.
Cycling is dangerous enough without adding extra risk. Especially unnecessary risk.
Likes For RandolphCarter:
Bikes: 1981 Schwinn, 1964 Frejus , 1972 Peugeot PX 10
Liked 13 Times
AVA "death stem" break found on PX-10
Hello,
Attached is a photo of the crack partially around the circumference of
an AVA stem found on a 1972 Peugeot PX-10 I acquired. The too-shallow
depth of insertion can be seen just above the slot. The stem is also slightly
bent to the side. I suspect the bike fell over with the rider aboard.
Cracked at top of slot and half-way around. Bent, too.
AVA stem removed before anyone got hurt.
Likes For Gashouse:
Quoted: 1641 Post(s)
Liked 831 Times
I think AVA stems are lighter than most other brands because the tube walls are thinner.
The thinner tube wall results in the propensity to crack at the slits machined for the quill wedge.
Chances of cracking can be lessened (but not guarateed) if the top of the slit is drilled out with a round hole diameter wider than the quill slit) that will eliminate the stress risers at the end/corners of the quill slits.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
rootboy, you are still loved.
Likes For SurferRosa:
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I had one on my commuting bike that was probably 40 years old and had no problems. Because of the scary threads on BF, I decided to replace it with a Kalloy. The new one started creaking within a few months and then started allowing the bars to slip. Upon tightening, I apparently damaged the bars because they broke shortly thereafter. End of story is that I am now using the AVA stem again.
-G
-G
I had one break on me. I made a right turn onto a large, high speed avenue and was accelerating hard. When it snapped, I almost fell. I was moving ~15 mph, alongside traffic and had no means of steering. I was, LITERALLY, holding the bars in my hands separate from the bike. I had the presence of mind to stuff it back into the steering tube and regain enough control to stop the bike.
All this happened in less time than it took you to read this.
It broke slightly below the level of the steering tube.
The stem looked something like this and like the one shown above by Gashouse.
Likes For Bad Lag:
Quoted: 1106 Post(s)
Liked 1,328 Times
Not just Ava, and not just cone-wedges
Pic below, left-right, top row first:
Peugeot (red stripe one), but I have seen this with a Mercier badge, don't know the real mfr
Atax
GB
Cinelli
Pivo
Ava
Raleigh but I think this is also a re-brand, is a nice strong stem
Cinelli
Pivo
They all except the Raleigh (which arrived with a nicley rounded top) have had the top-of-the-slot mod, even the useless 1R.
Here are all the hollow ones. Some are closed-back.
A previous poster was worried that the loss of material in the centre of the stem would compromise bending and torsional rigidity/strength; though this is true the best distribution of material for such stresses (absent a non-random distribution) is a tube, and the larger the diameter the better (with a practical limit on the order of 25:1 dia/wall ratio). As the walls of the stem's extension are much thicker, and usually shorter, and often larger in diameter than the walls of the tube I suspect that is not even a sensible (rigidity) factor. The absence of reports of stems - even drilled-for-bake-cable ones - argues against a strength issue.
However, there is also the stress from the stem-bolt, and an open back is much weaker here than a closed one; they are to be preferred:
Some slots are oriented fore-and-aft, some athwart. Here are the Cinell's. In re the 1R (right) they are also a known crack-candidate - right across the front of the clamp through he centre of the badge-hole, the crack starts from one (any) of those grooves on the inside surface of the clamp:
Atax
GB
Cinelli
Pivo
Ava
Cinelli
Pivo
Likes For oneclick:
Quoted: 405 Post(s)
Liked 430 Times
Anyone who's ever had any sort of front end separation will advise not rolling those dice.
Even if you don't die, or spend a week in a coma and 7 years in recovery, it's gonna really, really, REALLY suck. And once the front end comes apart, it's no longer up to you how bad it's gonna suck.
--Shannon
--Shannon
I just purchased an early-eighties Peugeot with the CTA stem. Yesterday the seller took it to a bike shop for shipping and when they went to remove the bars they broke the stem clean off. After reading this thread and looking at the pics from the seller, I think the stem was way too high and obviously something caused the fracture to start. Then the bike shop guy finished it off when he was trying to remove the stuck CTA stem. More to follow when I receive the bike!
Likes For JesseABN:
Liked 3,931 Times
I think the stem on my '69 Peugeot UO-8 was an AVA. And no, I didn't die but I did try to punch a hole in my sternum with that quill bolt. (Came into the free-for-all intersection off a fast descent, hands over the hoods ready to brake. While I was surveying traffic, hit a stone that knocked my hands off the bars. Slammed that sternum and rode through the intersection with my hands down by the QR. No traffic, so no big deal - except that hurt! (The things we do when we're 14.)
Quoted: 5888 Post(s)
Liked 3,471 Times
On bikes I rebuild to ride, I replace the bar and stem with new Nitto stuff.
Likes For bikemig:
Once I get the bike and measure the tube, which I’m thinking will be 22.0 mm, can you point me in the best direction? Going back original is probably not my best bet since I want to actually ride the bike.
Liked 3,471 Times
There are a few threads on this, https://www.bikeforums.net/classic-vintage/1245444-who-sands-nitto-pearl-their-french-steerer.html
https://www.bikeforums.net/classic-vintage/1029984-vo-stems-fit-into-french-steerers.html
señor miembro
Liked 6,488 Times
Likes For JesseABN:
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 228 Post(s)
Liked 294 Times
I had a TTT Status on the Mooney (#716) that got lost to a bad driver, and while that stem didn't break on me, it seems to flex like overcooked spaghetti every time I stood up to honk when climbing, and that just doesn't inspire confidence. I like the TTT ergo bars, but that stem left me unhappy. So my Mooneys have Salsas (don't know if Shafer or QBP era) with the stickers removed, and my townie has an old Tioga T-Bone Prestige. I believe in these more than the stems I've had throughout the past.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
I've found:
-Kurt
- AVAs and Pivos cracked at the expander wedge where they're not relieved,
- A gold-anodized Phillipe-ATAX stem crack at the binder bolt,
- A 1990's-era 3TTT stem cracked at the front of the clamp due to overtightening the 26.0 stem on a 25.0 bar with no shim,
- A Cinelli 1E cracked from the poor fit of the factory knurled nut spreading the aluminum hole where it fits,
- Pretty sure I've come across at least one of those aforementioned button-logo Cinelli 1Rs or XAs that cracked on one side of the button hole.
-Kurt
Likes For cudak888:
Raleigh with modified AVA..
There were some issues on some of the lower end Raleighs
in particular IIRC. The stem diameters were actually incorrect for
the headsets they ended up in (i.e. stem a little on the smaller side.)
I dunno, it was a long time ago.
https://www.bikeforums.net/showthread...eath-Stem-quot
https://www.bikeforums.net/archive/in.../t-833803.html
https://www.bikeforums.net/archive/in.../t-708084.html
I have had the bars they come with fail on one occasion. so I
would never ride very far on the original bars without the
more modern steel sleeve reinforcing at the stem clamp.
Hello there, I just recently got an AVA stem for my Raleigh grandprix mixte, the stem insertion requires a 21.1; when I got the new AVA stem that was supposedly a 21.0.. it did not fit the insertion, but I needed a new stem badly since I got the Raleigh with what could be a retro/vintage mountainbike stem on and was not very pleasing to look at..
We decided to use a grinder to make the stem slimmer to fit in the insertion, it worked and it seems that the stem is in pretty good condition to snap, besides I am very cautious and a gentle rider since most of my bikes are vintage..
I am still to find out how strong the AVA stems are even when it has been modified
Here are some photos of my bike before and after
