1999 Cannondale Silk Path Headshok bearing size & number?
Quoted: 823 Post(s)
Liked 1,395 Times
I have a 1999 Cannondale Silk Path 500 hybrid. The upper headset sealed bearing has seized and does not move more than 10 degrees. What size and model number sealed bearing should I get to replace it? Everything else is good.
Thanks!
Thanks!
Quoted: 823 Post(s)
Liked 1,395 Times
Never mind - I wound up getting a set of what I hope are the correct bearings off eBay, and hopefully all the Headshoks used the same units. FWIW, the ones I bought are B543-2RS, 39.7x50.8x7.14 mm. Fingers crossed!
