Long leg, short torso frames
Georgina Terry has long designed bikes for women, being one, her company has sold a lot of them over the decades...
the shorter top tube requirements (withougt going 75 or 76 degree seat tubes, common approach, got her using 24 " front wheels ...
Bike Friday goes 1 better 20" wheels 8 different frame lengths . all the component picks you desire, etc..
Quoted: 4409 Post(s)
Liked 1,562 Times
The shorter TTs are because of back angle, not torso length.
You don't know what you're talking about. Please stop repeating baloney you've heard and then arguing about it.
Meh... my back angle is that of a multi month international touring cyclist not a racing stud muffin..
I sorted out my fit needs by 50 years of riding, though I had to stop , while serving in the US Navy during the Viet Nam war era
there is just no room to bike on a nuclear submarine..
Liked 1,562 Times
You get that Grandpa Simpson onion-on-the-belt thing a lot, don't you?
Quoted: 12 Post(s)
Hi all,
I am 5'7" (170cm) with 32" inseam (81cm) and I think I have the same problem (short torso - long legs). I also have the same bike (CAAD). I ride a 52, should I have gone for the 50???
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
I don't think so, but no way to know without photos.
Results matter
Results matter
Bikes: 2013 Specialized Crossroads Sport, 2018 Specialized Women's Rockhopper Pro
Quoted: 24 Post(s)
I am an athletic 65-year female with very much the same physiology. My arms are in proportion with my long legs which I impacts fit as well. I am currently riding a Specialized Crossroads Sport with a size M step-through frame which I believe is proportioned for women riders (correct me if I'm wrong). I feel like a 52 frame should be right for me; I have always had a better fit with a women's frame. Curious to hear what others have to say, from experience, as I am looking to upgrade my bike.
I like the versatility of my CR, but am not happy with the performance of the rim brakes. I would also prefer a bike with 2x gearing instead of the 3x8 on my bike; I rarely use the large chain ring and 2x chain ring would be much simpler. Consequently, I am looking for a road/trail bike with disc brakes, flat handlebars, a semi-upright riding position, and women's geometry (not necessarily step-through). So far, I have not been successful. I want to purchase from my favorite LBS which sells Specialized, so I have not looked outside that brand. I rode a Sirrus and like the ride, but it isn't suitable for off-road with 700x30 tires; would like at least 38 wide and a less high pressure tire. I also prefer no fork suspension, which leaves out the Cross Trail and Ariel models. I've almost decided I'll have to choose another frame model and convert from drop bars, a costly modification since shifter/brake levers would also have to be replaced. If only the Sirrus frame would accommodate wider tires. The best we could come up with it is to run a wider, off road, lower pressure tire on the front, since the forks have more tire clearance; the chain stays are strictly 30mm. I like the Specialized Trigger tire for multi-purpose. Any ideas???
Liked 1,562 Times
The CAADs are relatively low bikes, meaning that the head tube is short and the handlebar on the low side. The ideal bike for you would be the opposite - a bike with a tall head tube for its size. That allows you to buy a bike with an appropriately short top tube but still have the handlebars high enough.
Quoted: 12 Post(s)
After examining stack & reach from geometry tables, I think that a Cervelo R or a Ridley Helium would have been wiser choices. I guess that having a long saddle like an Arione only makes things worse? I always find myself moving my b*** backwards in order to find a comfortable place to sit.
Liked 1,562 Times
Thanks for the advice Kontakt.
