8500 miles in a year hard to believe.
Quoted: 680 Post(s)
Liked 949 Times
Hard to believe I have ridden that much. Bought my first bike on the 23rd of November last year. I started out just commuting 20 miles a day then some longer rides on the weekends. But when the pandemic hit and there was nothing else to do I Started riding longer on the weekends. But then the wife and I got our e tandem and once she got sured to it we started riding everyday once I got home from work. So I went from 20 miles day to 30 to at my peak 35 to 40 a day. I peaked out at 252 miles in a week. I really rode too much and wore myself out. Now with it getting dark earlier and lots of rain we down ride very night. This week it was a paltry 198 (G) I did not sure strava till later in January so its does not have all my riding.
Quoted: 680 Post(s)
Liked 949 Times
the pandemic helped there was nothing else to do. 5 days a week I would ride to work run some errands ride home eat ride the tandem then go to bed and repeat. I was pushing out on my commute to see how mocha power I could sustain. my best was 189 watt average for 9.5 miles. but I was just riding too much and working 6 days week and it wore me out. Now its better.
Quoted: 668 Post(s)
Liked 529 Times
Man I love it. I'm about to get a hip replacement. I would be ecstatic, and more than a little sore, if I hit 250 miles in a month.
Next spring I should be healed up and ready to roll again.
Likes For Pop N Wood:
Ride more, eat less
Quoted: 715 Post(s)
Liked 736 Times
Do you keep track of maintenance and wear & tear cost?
How many tires, inner tubes, chain, brake pads, etc.. have you had to replace?
How much maintenance, chain lube, tire inflation, etc, have you had to do?
Quoted: 680 Post(s)
Liked 949 Times
Was a bit off it was 9000 miles. I used my odometer to keep track fo chain wear. first chain only lasted 1200 miles second 2500 and 3rd 3000. so far the front tire is original. I screwed up the back tire When I had a strap get wedge between the fender and the tire and locked the back wheel up at 30mph. on the second set of brake pads so far. but I bled the brakes a month ago they were getting a little mushy. I lube the chain once week in summer if I ride around 100 miles twice if I go more I use a dry lube so it stays pretty clean but it does not last long. in winter the same ore after a rain ride or two. my headset bearings were rising around April all those rain rides so I had them replaced with better bearings. got the bike tuned up a few months ago by a Mobile service. the tandem has only needed a chain replacement and pad replacement. but only has about 2600 miles on it. the tandem had some cheap below deore brakes that needed bleeding at 2000 miles we replaced them with 4 piston deore with 1 finger levers so much nicer and more powerful.
Ride more, eat less
Quoted: 715 Post(s)
Liked 736 Times
Seems like the chain does take a beating.
Do you think it's from the extra torque of the electric motor?
Are different chains used after replacements? better chains?
Any significant wear & tear on the chain since 3000 miles?
Quoted: 680 Post(s)
Liked 949 Times
there are a lot of factors. when I first started riding I was pretty sick and my energy was low s oI rode in turbo mode thats 300% assist. plus it rained a lot and I used a wet lube so lots of gunk only 1200 miles on the kmc chain second chain a lot drier and a Shimano e chain and drier lube and I was using less assist. so I got 2500 miles last chain I was using even less assist and I got 3000 miles. I am trying a KMC chain again to see what happens. yes chains are abused on mid drives for sure. but the feel of the bike is so much better.
Ride more, eat less
Quoted: 715 Post(s)
Liked 736 Times
Can you elaborate a little more on "the feel of the bike is so much better"; as in feel of new chain once replaced?
or
feel of mid-drive motor between Shimano chain vs KMC chain?
or
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
That is hard to believe. but if you've already done almost 1,000 rides this year...
I did something like that on year- commuting 20miles every day, then another 100 miles doing "training" then on Sunday, I would ride another hundred miles with friends. Kinda added up!
you are an example of why they say that people with ebikes often get more exercise. It makes it fun and easy to get out.
Quoted: 680 Post(s)
Liked 949 Times
the mid drive feels like a normal bike making you feel stronger. no difference the chains. but it seems I use a bit less battery when I go over to a new chain. the first chain was a .75 wear in the 1200 miles and when I changed I got better battery milage it was noticeable.
Quoted: 680 Post(s)
Liked 949 Times
Likes For fooferdoggie:
Ride more, eat less
Quoted: 715 Post(s)
Liked 736 Times
I'm pretty sure your physical condition has a lot to do with how well you feel on any given bike, regardless of what type of bike you ride.
Good to hear that you are riding so well and enjoying your different rides.
Quoted: 680 Post(s)
Liked 949 Times
The e bike made it possible to ride without stressing my body I could go fast enough to make it fun and worth while. I can travel at 20 to 22mph at any level of effort I can sustain. Now between my commute and the tandem we never walk anywhere or ride public transportation now. (well my wife does some as she is blind and has to get to work) if I strictly control my food I do pretty well. its a daily struggle to eat like I have to but I don't have a choice about it. no doc or al the tests have helped at all. I cant do 50 miles on a ride hope to do much more when weather and such permit. but my e bike has been a life saver. I would never have the energy I have now if I did not ride. plus it keeps me off public transportation right now and thats a really good thing. its actually faster then riding the bus and about as fast as my friends can make the drive. I ride more then they drive.
Congrats on your first year success! Were you biking at all before this? Is the data you showed from an app? Thank you!
Quoted: 680 Post(s)
Liked 949 Times
not for maybe 5 years. I was too sick to do it. the e bike let me start with little effort. I don't know if I will ever be really healthy but riding as made me far more then I was. things have slowed down because its dark when I get home and rides at night are not really fun but for errands. but we ride longer on weekends. rain or shine.
Quoted: 680 Post(s)
Liked 949 Times
its a lot better overall. but my problems with food I think are lifetime. but its a lot of riding on protein only. I was pushing my effort too much at my peak when I was riding 30+ miles a day. it wore me out. so I had to use a lot more assist but I am coming back again. I am not going to try to see how hard I can ride on my commutes. my wife health has improved with the tandem rides. one of the things I really like is when I carry stuff it does not slow me down. I used to hate hauling groceries on my bent but on my e bike no big deal. with the pandemic having the bike has been great no riding the bus and since my wife is blind now she can get around too. I never walk anywhere now.
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
Fooferdoggie have you ever been checked for celiac disease. My son suffers from this disease. In his case it appears to be genetic from his grandfather on his mother's side. Generally celiac disease means you cannot eat any form of gluten. Gluten is found in wheat and some wheat relatives. Besides the usual wheat products such as bread wheat gluten ends up in everything because wheat is used as a filler in processed food. This disease needs some doctor time to test you but if you have it the "cure" is relatively simple. No gluten at all. I am no doctor but your descriptions of your health issues mirrored my sons so just a suggestion.
Quoted: 680 Post(s)
Liked 949 Times
