cheap bike rear shock type identification
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
What kind of read shock have this bike equipped?
Likes For alcjphil:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
No idea what kind of shock that is but you better raise that seatpost before you start breaking stuff.
Quoted: 514 Post(s)
Liked 448 Times
Equipment like this doesn't have a brand. It just comes from secret sources known only in China.
Likes For oldbobcat:
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
It is a Black Blob, best shock you can get for $0.30. More quality than using a toilet paper roll but less quality than a hard dog doo.
Likes For veganbikes:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Quoted: 333 Post(s)
Liked 168 Times
Update:
Maybe that's an useless information but i'm going to post it anyways in case anyone need it.
The shock looks like both air suspension and coil , but in fact is just a coil shock with a sort of protection (maybe againsts mud and water). I Assembled the bike from zero and i had to admit that protection was worth since is the first time i found a still working cheap-coil shock for those types of bikes.
Even the fork had to be disassebled and cleared vut this shock was still fresh.
Quoted: 333 Post(s)
Liked 168 Times
yea i know thanks.but the photo in the first message was from the seller. basically the bike came in a box fully disassembled.
Quoted: 194 Post(s)
Liked 204 Times
I can offer no advice other than to cruise the aliexpress / auction site pages. what actually is wrong with it?
Anyway, I love the bike rack in terms of originality, although I not sure how they used it in practice
BTW - how heavy is it? I was given a similar kind of bike and it weighs a ton...
I've scraped out hundreds of bsos with "shocks" and taken a bunch apart to see what is inside. They aren't shock absorbers in the automobile use of the word. The black blob version has a plastic cover over the coil spring. Other wise it's the same as all the other bso "shocks". Just a shaft inside a couple of plastic sliders to keep it aligned with a rubber washer to dull the slamming at the end of the travel. There is no dampening effect like a real shock absorber. The outer body is threaded with a large nut to adjust the preload on the spring. They are mounted with plastic spacers, a through bolt and nut. It takes two 5mm hex wrenches to remove.
A real shock will have air compression with oil dampening through calibrated or adjustable valves and cost more than the op's bike.
Shocks come in different lengths and those with coil springs, the springs come in different weight ratings. Because of the angles in the various suspension designs, the coil weight ratings don't correspond to body weight.
Likes For rickpaulos:
Quoted: 514 Post(s)
Liked 448 Times
Bolt in a couple pieces of angle iron and a bushing and make it a hardtail. It might even handle better in corners that way.
Quoted: 184 Post(s)
Liked 67 Times
Yes the photo I posted is a correctly attached rotor.
I mentioned the orientation of the rotor because the OP said 'I Assembled the bike from zero' and the rotor is incorrectly attached in the OP's photo in the first post.
Quoted: 514 Post(s)
Liked 448 Times
Misunderstood. Yes, the rotor is correctly oriented. No, OP did not make a mistake mounting the rotor. Sorry.
I once got a Cannondale Super V that had a piece of pipe in place of the shock. A more elegant method. Used the same shock mounting bolts. No sharp edges sticking out. Cut and drill to get the height of the bike where you want it. it took a while to find a suitable shock and flip the bike.
