Lost freehub washer - ok to use?
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I was overhauling my Bitex RAR12 hub and accidentally lost the washer that goes between the two inner cartridge bearings. Is there any issue with using the freehub in the wheel without this brass washer?
Quoted: 4208 Post(s)
Liked 3,874 Times
Depending on the hyb/freehub/axle bearing design the bearings could become improperly preloaded and wear at a faster rate. Possibly the freehub body might migrate from it's intended location, along the axle, causing other issues like shifting or bearing wear and/or slop.
But we don't have the design in front of us so we can't really say what that washer was doing, thus what might happen if it's missing. Perhaps you might provide a link to a diagram for us to better help you? Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I would strong advise against using it til the washer is replaced. They put it in there for a reason.
Quoted: 581 Post(s)
Liked 921 Times
A precision washer, like one you would find inside a hub or other bearing system, is not free, and companies do not spend money on things that they don't have to. I would argue that the washer was there for a reason and you should replace it before you ride it.
Quoted: 1814 Post(s)
Liked 923 Times
I bought a used wheelset that had that problem. The freehub only spun with difficulty.
The LBS sold me a similar hub from the junk bin for $5 that had the right washer.
Quoted: 345 Post(s)
Liked 237 Times
bought a backup freehub with the washer. It is such a precise fit that it didn't work with the old freehub (it would rub slightly) so I just swapped the whole freehub. The good news is it freewheels much easier
I learned my lesson - be very careful (and think twice about wanting to) disassembling the hub.
