New Brompton Arrived and I rode it!
Old 05-01-18, 06:59 PM
dgodave
Behold my avatar:
dgodave's Avatar
Bikes: 2019 Gorilla Monsoon, 2013 Surly Krampus, Brompton folder
Quoted: 6941 Post(s)
Liked 444 Times in 289 Posts
Delivered last night.
Ridden this afternoon!
To be toured on starting the end of May.
dgodave is offline
Old 05-01-18, 08:23 PM
GTA
Quoted: 76 Post(s)
Liked 79 Times in 37 Posts
nice bike, congratulations~~
GTA is offline
Old 05-01-18, 08:47 PM
reppans
Bikes: Brompton M6R, Specialized Tricross Comp, Ellsworth Isis, Dahon Speed P8
Quoted: 325 Post(s)
Liked 19 Times in 16 Posts
Congrats! You intend on self-supported (camping) touring? Just curious since you didn't get a rack.
reppans is offline
Old 05-01-18, 09:07 PM
dgodave
Behold my avatar:
dgodave's Avatar
No, this will be credit card touring this time... tho I still want lower gears. The 6 speed reduced isnt low enough.
dgodave is offline
Old 05-02-18, 01:04 AM
tudorowen1
Bikes: Brompton S6L ,Bike Friday NWT, Phillips 8 speed folder, Trek 930, Thorn XTC
Quoted: 76 Post(s)
Liked 9 Times in 8 Posts
Fit a 39 tooth chainwheel..26 inch to 83 inch gear range...
tudorowen1 is offline
Old 05-02-18, 01:06 AM
glowrocks
glowrocks's Avatar
Bikes: Bianchi Infinito Celeste, Trek 7.5 FX, Felt Z6
Quoted: 18 Post(s)
Love the roads you ride on!
glowrocks is offline
Old 05-02-18, 07:21 AM
dgodave
Behold my avatar:
dgodave's Avatar
Thats more like it.
Tho I like the plastic pants guard on the stock chainring and dont want to give it up.
Wonder if I can swap out the 2 rear cogs for something slightly bigger?
dgodave is offline
Old 05-02-18, 10:32 AM
FolderBeholder
FolderBeholder's Avatar
Bikes: 1963 Schwinn, EuroMini Urbano, Magnum Premium 48, Brompton S6L, Tokyo Bike Mini-Velo
Quoted: 129 Post(s)
Liked 46 Times in 29 Posts
Color me....jealous!
(The -12% gearing isn't low enough?)
FolderBeholder is offline
Old 05-02-18, 10:57 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Count teeth, what is on there?
fietsbob is offline
Old 05-02-18, 11:47 AM
dgodave
Behold my avatar:
dgodave's Avatar
Nooo. I climb some really steep hills here, plus my knees are getting old.
dgodave is offline
Old 05-02-18, 12:11 PM
dgodave
Behold my avatar:
dgodave's Avatar
Originally Posted by fietsbob
count teeth, what is on there?
13t & 16t
dgodave is offline
Old 05-02-18, 03:01 PM
FolderBeholder
Quoted: 129 Post(s)
13t & 16t
Same amount of teeth my 3rd cousin has !
And my other 3rd cousin has 16....
LOL....keep us posted.
Old 05-02-18, 04:44 PM
Joost
Quoted: 5 Post(s)
Nice bike with a beautiful color! Enjoy!
Joost is offline
Old 05-03-18, 01:03 AM
badmother
badmother's Avatar
Quoted: 317 Post(s)
And they play the banjo?
Nice colour. Stylish.
badmother is offline
Old 05-03-18, 05:34 AM
berlinonaut
Quoted: 319 Post(s)
Liked 14 Times in 11 Posts
You can go up to 17t (instead of the stock 16t) w/o filing on the frame. You can go up to 18t with light filing on the rear frame/chainstay. For anything bigger on the BWR hub it needs courage.
berlinonaut is offline
Old 05-03-18, 06:24 AM
reppans
Quoted: 325 Post(s)
Think I want to try a -22% with the 39T chainring for the 26-78" gi range... Can anyone advise a good 39T ring to buy, and do I need a specific bolt pattern for it?
reppans is offline
Old 05-03-18, 06:48 AM
1nterceptor
LET'S ROLL
1nterceptor's Avatar
Bikes: 2014 BMC Gran Fondo, 2013 Brompton S6L-X
Quoted: 306 Post(s)
Liked 44 Times in 33 Posts
Been using a Shimano Dura Ace 39T chainting for a few years.
Shimano Ultegra chain; both 10 speed. Stock rear sprockets/cogs:
1nterceptor is offline
Old 05-03-18, 07:39 AM
dgodave
Behold my avatar:
dgodave's Avatar
Thanks for the compliments everybody!
I should have no problem finding a 130 BCD 40t chainring. But I really wanted to keep the "pants guard" thing.
dgodave is offline
Old 05-03-18, 08:21 AM
dgodave
Behold my avatar:
dgodave's Avatar
Interesting. I sure wont be filing the frame. Do you happen to know what brand/spec cogs I would need?
dgodave is offline
Old 05-03-18, 08:25 AM
L Arnold
**thusi*st
Bikes: Specialized Touring Expedition '1984, Volagi Liscio, Dahon Visc D18, Dahon Visc SL, Schwinn Moab
Quoted: 81 Post(s)
Liked 5 Times in 5 Posts
My Velo Pant Guard (Nomadic built, Boulder, CO)
I'll send you a Pants Guard if you need. I'm with you generally on wearing pants not tights. This is actually mesh so it is very comfortable to wear.
Also, if you are interested, I've modified a Dahon to have a 17 to 96 Gear Inch range. Perhaps some angles like that for your Brompton.
Nice looking bike you have.
L Arnold is offline
Old 05-03-18, 08:32 AM
dgodave
Behold my avatar:
dgodave's Avatar
Wow that is very generous of you. But first I'm going to try for a solution that keeps the pants guard on the bike, as I'd rather not add things to my bring-it-riding checklist.
dgodave is offline
Old 05-03-18, 08:48 AM
L Arnold
**thusi*st
Quoted: 81 Post(s)
One method,
and definitely lighter than anything attached with bolts (Local crop too)
I also have some 46 or 42 Tchain ring protectors (I need to count). They can normally work for smaller chain rings too. I've been pulling these from bikes (below) to build the wide range version I mentioned.
L Arnold is offline
Old 05-03-18, 09:38 AM
reppans
Quoted: 325 Post(s)
https://www.youtube.com/watch?v=5AT6...6zPoymgKaIoDLA
Thanks interceptor... saw your video before too - very helpful. Can I assume the Dura Ace 39T come in one standard bolt pattern (that matches the Brompton)? Also assume using a thinner chainring (for 10 speed rig) should be no problem with the wider(?) Brompton chain?
reppans is offline
Old 05-03-18, 09:59 AM
1nterceptor
LET'S ROLL
Quoted: 306 Post(s)
Brompton uses the common 130 BCD. A lot of brands/models will also fit; SRAM, FSA, etc. Not sure how a 10
speed ring will behave w/ a stock B'ton chain. I'd go with a 8 or 9 speed ring if you want to stick w/ the stock chain.
2013 Brompton DA chainring Ultegra chain by 1nterceptor, on Flickr
To the Op; and others who want to change rings but still have a protector. I've seen mods where owners put a smaller ring(38T, 39T, 40T);
which were designed to be inner rings. At the same time, they install the outer ring(53T, 52T, etc); but they file the teeth off. Presto, guard.
Old 05-03-18, 10:06 AM
fietsbob
Bikes: 8
A Surly Stainless steel chainring https://surlybikes.com/parts/drivetr...eel_chainrings
would be my go to .. longer wearing , and flat , so you can flip it over & extend it's use-life ( still go 130 39t )
I have had a Surly 110-38t on my Rohloff bike for many years..
'2.1mm thick' so works with 8 speed / 3/32" chain..
But in addition to the Ultegra-Dura ace 130-39t, you can find a lot of others of that size ,
using the same 7075-T6 aluminum alloy to machine into that part..
fietsbob is offline
