I've been crashing a lot since getting a gravel bike
Quoted: 336 Post(s)
Liked 309 Times
Like I mentioned I'm guessing a skilled rider would be fine on these little jumps and stairs without suspension, but I have 50,000 miles on a road bike and 200 on a gravel bike lol. Probably a few hundred trail miles on the Cervelo, but the really rocky stuff is no fun on 23s.
I consider myself a good bike handler, and I have more miles on the road than anywhere else, but that is not where I got my skills. They came from years riding BMX and freestyle bikes in my youth, riding MTB and ten seasons of cyclocross, and even off-road unicycle. I was riding gravel before it was cool.
I’m sure that you are a great wheel on the road, but the more time that you spend on loose surfaces, you more you will realize that your road riding skills are only “base miles” and the cyclocross, MTB and trials experience are the “intervals” of bike handling.
Randomhead
Liked 3,698 Times
I ride my gravel bike on MTB trails all the time. As a very experienced mountain biker, I find it more challenging to tackle trail features on a drop bar bike, but that is part of the fun for me. With you being road rider with little MTB experience, I would expect you to have more trouble dealing with those trail features.
I've found that setting up my bars so that they are higher and closer to me, than I would use on my road bike, helps a lot. You need to be in the drops for trail riding, so that you can keep a finger on the brake levers. It helps a lot to have the bike set up so that you are comfortable being in the drops and can still keep your head up to look far enough down the trail to see the next obstacle and prepare for it.
Quoted: 6965 Post(s)
Liked 10,964 Times
I think that's the bottom line, drop bar bikes are not really made for mountain biking and it takes a pretty good mountain biker to use them well in ways most appropriately ridden on a mountain bike. I'm planning on putting a dropper post on my gravel bike, it's pretty scary on a lot of the double track around here, and forget it on singletrack. The main trail down out of the mountains near here takes me less than an hour on my mountain bike, and I have never done it in less than 2 hours on my gravel bike.
I think we are in the same neck of the woods...And I've done a couple "gravel races" that included terrain that would be challenging for MTBs. I don't appreciate confronting that on a drop bar bike with 42mm wide tires.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If nothing else, it seems that you're not afraid of crashing.
Sometimes I wonder if I don't crash enough to be comfortable pushing my bike-handling limits. So I rarely try new things.
Well I don't particularly like crashing, and I am afraid of it if I think about it, but I don't usually think about it. Back when I started road riding, I took a corner too fast (or wrong line too fast more likely) on my first big mountain descent trying to keep up with the fastest guy on the college race team. I feel like that helped me learn my cornering limits quick and I've been one of the faster guys at descending ever since. I'm hoping something good comes from a few beginner crashes on trail features. At least these are all low speed.
I think it's a learning curve as you try to flex a bike made for one genre into another. If you have a bike optimally set up for gravel it's not going to be optimal for more technical terrain - you would do things differently for that.
If the seat is set for speed on gravel roads it will be too high for control on single track where you want it lower. A good argument for a dropper on a gravel bike I suppose. When I started riding my FG more on gravel I had some problems with the old school narrow drops. The hand position was too close together to negotiate some detours that go around gates and loose gravel on descents.
So I swapped them out for flipped utility bars, like very shallow dirt drops. Wider grip and angled for better control.
I still can't do wheelies with it either.
I have the dropper post. I used it on a mild single track descent in the city just to try it out and I like it. When I'd take my road bike on dirt I often had to push my butt back as far as possible on the descents, and the dropper makes that easier and keeps my weight lower. Sometimes I find myself wanting to use it but I'm already descending so I can't get the seat down
I actually sized down from my road bike to get the bars closer, and left them in the highest position. it's only annoying when I'm trying to speed home on pavement but I can still get in invisible aerobars.
Quoted: 590 Post(s)
Liked 445 Times
If you like pushing the limits of your skill level, and don't mind falling 2-3 times per ride, get a full suspension MTB and ride in the woods on some steep technical single track. Learning to fall gracefully is just part of the fun. If you don't come home bleeding on every ride, you weren't trying hard enough.
Quoted: 2236 Post(s)
Liked 1,314 Times
Quoted: 1218 Post(s)
Liked 298 Times
I had a pretty spectacular wipe out while riding my gravel bike on the gravel Denali Hiway. Riding 700x40c Schwalbe marathon tires, pumped up to too much tire pressure for the conditions. I decided to change my line to the other tire track. Wheels went sideways and my bike and I got horizontal with the gravel. It was during an up and down, but probably the down, when I was going 12-15 mph. Probably due to maxing out the tire pressure, due to lack of experience. The surface doesn't cause the crash; it's your failure to adjust to the conditions.
Likes For DeadGrandpa:
I bought a gravel bike as my first bike mostly ride road,rail trail and some gravel road only been over the bar once and happened because of inexperience and a bit of panic mode. Loving fact I have two options for rides. Cheers
I crash every so often on my gravel bike. As I like to take it on trails and single track and in general get out into the wild.
Just takes time to know when to be cautious and when to go for it full steam.
At 53, it’s been quite some years since I road dirt bikes so those skills are long gone, but I still know what I’m supposed to do... even though I don’t really trust myself all the time to execute properly.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I'm surprised at how poor bike handling skills roadies have (don't know if that is you or not).
and
I'm surprised at how erratic and unpredictable mountain bikers can be.
Ideally, you'd learn on BMX as a kid, when falling isn't so far and it doesn't hurt so much.
Failing that, crashing mountain biking (within reason) will teach you the limits of you, your bike, and the laws of physics - at speeds that are typically a lot slower than say road riding.
For that type of riding, you learn by crashing - that teaches you where the limits are. Of course, learning how to fall helps a lot.
