Setting F&R V-brakes to engage at the same lever-pull-distance.
You adjusted the cable to get the braking you want so all good as far as the question you wanted answered. But I will repeat from my earlier post that the rear locking up sooner isn't what you want, it wouldn't have prevented your toss over the bars. The best situation is full braking with no lockup..in your scenario the front is probably the one that locked and over you went. Sometimes this happens!
Quoted: 4408 Post(s)
Liked 1,562 Times
I appreciate you addressing that. However, my issue is not that the brake shoes are farther from the rim. My issue is that one rim is farther away from the V-brake pivots than it is on the other. In order for the brake shoes to line up with the rim, they have to be moved farther up the brake arms, which then changes the leverage of that brake.
Quoted: 4207 Post(s)
Liked 3,872 Times
Nineteen days ago I was riding downhill and had to make an emergency-stop. My rear tire lifted off the pavement and I went OTB.
Indeed it is a typical two brake, two lever system. The only thing unique about it is that brake pivots on the fork are a different distance from the rim, than they are are on the frame. This means that the brake shoes on one brake must be moved farther away from the brake pivots in order to properly contact the rim. This amounts to a leverage discrepancy between the two brakes. And this is pretty common, especially on lower cost bikes, as often the forks are made by one outfit and the frame by another. This is why the canti arms do have vertical pad adjustment capibility. This adjustability allows for design/manufacturing tolerances and also bets pad/rim placement.
Both brakes had the same amount of cable between the arms. Since my 2nd post though, I've pulled more cable out from between the rear brake arms. Now the rear engages first. It does tend to skid more now than before. The amount of cable running between the canti arm ends (the straddle cable) will influence the leverage the primary cable (what most call the brake cable) can exert onto the canti arms (and in turn the pads). Here's a link to the Sheldon Brown site with a very good description on this as well as a lot more info you could learn up with The Geometry of Cantilever Brakes (sheldonbrown.com) I figure though, during a downhill emergency-stop, if I were to skid it would be just minimal, because my front brake will take over the stopping function and prevent me from losing control
I'll end this with a general observation. Unless the part (your brakes or sub part of that system) actually broke during the application.(stopping attempt) the cause of the OTB incident is rider error. Sorry to be harsh but if your brakes are not kept in good condition (and we don't yet have self healing bike parts so this is for the rider to control) or if you go too fast or can't modulate the braking action well enough for the conditions it's not the bike's fault. Bill's posting of practice is the time proved way to learn how your bike reacts when stopping quickly. To disregard this advise and method of gaining skills is somewhat foolish IMO. Have you ever attended an Effective Cycling, Street Smarts or similar course? Having taught them I have seen novice riders gain both confidence and skills they were lacking before. Andy
AndrewRStewart
AndrewRStewart
Quoted: 5788 Post(s)
Liked 2,581 Times
So naturally you got answers related to matching brakes, including mine saying it didn't matter. So, I repeat that there's no safety issue there as originally asked.
However, now I can say that there is a safety issue, but it's not the brakes. It's your incorrect assumption that your OTB event was caused by a mechanical issue that's causing a safety issue, by keeping you from listening to good advice like that from BK that you should focus on your braking technique.
I know you're convinced, and though I could spend time trying to explain how to brake effectively, I know you won't listen because you're locked in by your assumptions. So, I suggest you reevaluate your assumptions by considering the following:
1- Knowing (I hope) that the front brake acts independently of the rear, how, EXACTLY, would any changes to the rear brake reduces the chances of an OTB because of excess front brake force?
2- What are the considerations that determine when and how one would have an OTB? ie. body position, downslope, etc?
3- What is the difference between stopping the bike vs. stopping the rider? Or more specifically, how do you stop the rider in an emergency stop.
4- Why is it that bicycles have had 2 independent (usually unmatched) brakes for well over a century, and nobody has ever cared? Do you believe that that so many people could be so ignorant and uncaring about such a safety issue? Have you thought about how simple it would be to alter the balance between front and rear braking, and given that wondered why nobody ever bothered?
So, it's your bike and your safety, and I now leave you to deal with it as you see fit.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 980 Post(s)
Liked 582 Times
Good technique for hard braking involves the rider straightening the arms and moving the body rearward off the saddle. This keeps the center of gravity behind the point where the bike will flip. On a downhill at high speed it's a good idea to be prepared for this maneuver. You may be able to find images of mountain bike racers on steep downhill stretches with their bodies so far back that they are literally resting their stomachs on the saddle. Now, this level of re-positioning is probably not necessary in most street riding, but a lesser shift *can* be practiced under controlled conditions. Once you have the technique in your skill set, you will be more comfortable with emergency stopping, even on descents.
I'm new to this particular section but not to Bike Forums and I'm a little surprised at the tone of some comments. Yes the OP could probably use some practice with braking, it's not a talent on the bicycle that's acquired overnight. I'm not sure being condescending with advice is going to get them there.
Likes For Joe Remi:
Liked 2,581 Times
I had originally planned on going that route, but changed course because of the OP's passing on the advice to practice braking and insisting that it was a mechanical problem. It's been my experience that when people stubbornly cling to wrong theories they don't let go easily, which is necessary as a prelude to considering alternate theories. I've also learned that people are most likely to change be open to changing their preconceptions when they "discover" new info for themselves.
So, I tried to make the OP think about things for himself, and was hoping that my third question would lead him the the answer that Sweeks posted, or at least open him up to considering it.
As it's said, you can lead a horse to water...... but, getting it to drink sometimes takes a bit of attitude.
FB
Chain-L site
FB
Chain-L site
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I don't think mismatched braking force is the same thing as mismatched bite point which is what the first post was about. I liked my brakes to bite early as possible so I followed the normal procedure to get them both to bite as early as possible without rubbing the rim.
My last few bikes have had middling hydraulic brakes and they all bite the same unless something is wrong because that is how they work.
Funny thing about left/right. I had my bikes set up backward to match my motorcycle when I was single, but with a family and a fleet and no motorcycle I leave them all set up regular
Genesis 49:16-17
Genesis 49:16-17
Quoted: 514 Post(s)
Liked 448 Times
You could cut your front cable and housing to match the length of the rear cable. Just loop the excess a couple of times and attach it to the fork with a couple of zip-ties.
Likes For oldbobcat:
One reason I like a later or "softer" bite on the rear is I have a steep, short drop into my neighborhood that I like to do a little drag-braking on. I come sailing around to the right and down at a decent clip, grab both brakes to get 'er slowed up, then mostly release the front and pull pretty hard on the rear lever to keep things slow and stable as I near the bottom.
Too much brake on the front can get hairy at the bottom juncture to flat road, too much rear can skid and send me off course.
Quoted: 501 Post(s)
Liked 627 Times
I got from the original post that it was operator error and not the brakes that were an issue. See folks fly over the bars when they get their brakes adjusted "properly" when they had been running them with hardly any stopping from the get go, it's a thing.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Liked 2,581 Times
While he originally described it as related to shoe to rim distance, or possibly delayed engagement, he's now making it clear that his issue is the geometry yields lower leverage in the rear (compared to the front).
He's correct on that point.
However, he's wrong to believe it matters. Bikes have typically had poorer leverage on rear brakes about as long as they had two brakes. Some have argued that it's intentional, to better proportion brake force (like in cars) but it's actually an inadvertent consequence of fork and seat stay geometry.
In any case, the OP has to make the shift from obsessing about meaningless brake design non-issues and focus on learning how to make short stops safely.
Likes For FBinNY:
Liked 1,562 Times
Sorry, but you're missing the point.
However, he's wrong to believe it matters. Bikes have typically had poorer leverage or rear brakes about as long as they had two brakes. Some have agreed that it's intentional to better proportion brake force (like in cars) but it's actually an inadvertent consequence of fork and seat stay geometry.
In any case, it doesn't matter.
Liked 2,581 Times
What EXACTLY is not correct in my post.
FB
Chain-L site
FB
Chain-L site
Liked 3,872 Times
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Maybe pick up an old brake modulator...These were supposed to prevent stoppies.
Liked 1,562 Times
Liked 2,581 Times
I never said "inherent", simply acknowledged that the OP's brake and issue were as described. Nor did I discuss whether or not it could be "fixed", since I didn't and don't consider it an problem.
In any case, this is simply a case of you being you, and posting for the sake of "proving" that someone else is somehow wrong, or to start a pointless argument.
That's why I generally avoid responding to your "corrections"
FWIW just for grins, I'd love to see how you'd adjust the geometry of a V-brake to materially increase the leverage.
FB
Chain-L site
FB
Chain-L site
Likes For Joe Remi:
Liked 3,872 Times
This point, racers need speed control more than stopping power, is lost on many. Andy
AndrewRStewart
AndrewRStewart
Quoted: 514 Post(s)
Liked 448 Times
And drill the tires, sand the rims, and pound a 1 1/8" stem onto the 1 1/4" steerer, it all works better together as a set...
Liked 1,562 Times
By setting the pad spacing up to put the cable as close to 90 degree to the lever arm when the pad is in contact with the rim. That puts the pad force directly into the rim rater than acting at an away from or toward the hub.
Liked 2,581 Times
Given the geometry of V-brakes, the near vertical rms in a typical setup, and the typical sweep between 11 & 1 o'clock, I argue that the maximum possible change in leverage is very MARGINAL, and therefore not relevant.
However, there's no point in arguing. The knowledgeable readers here can draw their own conclusions, others can try for themselves.
FB
Chain-L site
FB
Chain-L site
Liked 2,581 Times
The reality is that the front brake alone is the issue, with the rear being at most a marginal player.
Unfortunately. There's no practical fix.
50 years ago the CPSC devoted significant energy to the issue,* and ultimately concluded that, given the variables, preventing headers could only be achieved at significant loss of normal and emergency braking power.
Shimano later tried with their brake limiter that was mentioned earlier on, but the results only verified the CPSC's conclusions.
So, while absolute prevention isn't practical, practicing hard stops does imprint what's needed on our brains and addresses the issue very effectively. Every experienced rider has had to make emergency stops, and yet managed (for the most part) to avoid the dreaded header.
So, despite your claim otherwise, practice does make (nearly) perfect. That's why musicians do it, why the FAA puts pilots through simulators, why divers, the military, police, and just about anyone who may face predictable emergencies drills on a regular basis.
Simply put, in an emergency, you rely 100% on your training.
After 50+ years and well over 200k miles, I still periodically do hard stop drills, especially on an unfamiliar bike.
So, it's your bike and your choice and feel free to tinker with the brakes, but DO NOT reject the notion of emergency stop practice.
* back then helmets were not in use, and the traumatic results of headers, especially in children, was one of the highest a reas of concern.
