Presta Valve Problem
I have a real problem pumping up tires with a Presta valve, I just can't get the hang of it.
I've tried using a vertical pump with an opening for both Presta and Schrader valves, when I use the Presta opening the first time I push down on the pump, air seems to go into the tire but then the pump seems to block itself as if the tire is fully pumped even though it's not.
I've tried using the vertical pump with a Presta valve adapter and it just deflates before I can get any air into the tire.
I've tried using a small hand pump with the Presta valve adapter, which works to a point, but still doesn't get enough air into the tire for me to ride the bike.
I've had the problem on different bikes with Presta valves, the vertical pump also works absolutely fine on bikes with Schrader valves.
I just don't know where I'm going wrong, I always open up the valve and touch the top to let out a bit of air, I've watched YouTube videos and they don't seem to do anything different.
The tires on my bike are Continental Grand Prix Season 700 X 23, would they be compatible with Schrader valves? Would I get enough air into them to avoid pinch flats?
Would appreciate any suggestions.
Thanks
Thanks
The technique can be a little tricky until it finally "clicks" in your mind, and suddenly it is easier for the duration. Get some help from someone who knows how to do it. Perhaps Youtube has some videos.
Saul
Saul
Quoted: 1084 Post(s)
Liked 688 Times
Thanks
Thanks
Advocatus Diaboli
Quoted: 4750 Post(s)
Liked 1,536 Times
Typically, just in case this could be the issue, with most pump heads, you are not supposed to actually install it so far down on the valve stem that you're pushing down on the top of the valve at all. You just put the pump down far enough where the seal will mate with the side of the valve stem.
Likes For Sy Reene:
NotaNewbie
Pressa troubles
Sometimes my valves stick. Use your finger to give it a quick push down, then it will take air easily.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2600 Post(s)
Liked 5,680 Times
Like what Jim has stated, after I fully unscrew the ‘nut’, then I give the valve a quick push to release a tiny bit of air to make sure the valve isn’t stuck. If you try pumping and no air seems to enter the tube/valve, give the valve a little shake and sometimes that’s enough to loosen the valve so you can get air in. you may hear a subtle click.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Advocatus Diaboli
Liked 1,536 Times
"I just don't know where I'm going wrong, I always open up the valve and touch the top to let out a bit of air, I've watched YouTube videos and they don't seem to do anything different."
Quoted: 3538 Post(s)
Liked 2,949 Times
Absent a video of the OP using the valve, or someone on-site who can accurately describe what’s happening, I doubt we can give the OP any meaningful advice.
Expired Member
Quoted: 3696 Post(s)
Liked 5,503 Times
This is just the pump and hose being pressurized and indicates the valve is not open. Probably you just need the release more air than a tap once you've unscrewed the valve. Try releasing air until the tire is flat or almost flat, then try your floor pump. That will give you an idea of how it should operate. You'll get the hang of it.
Quoted: 4227 Post(s)
Liked 2,488 Times
Almost sounds like the air chuck on the pump isn't installed correctly on the valve and is blocking the air flow when trying to use the pump. Get a pump that has an air hose and an air chuck with a lever that locks and holds it in place while pumping or even better get a pump with an air hose that screws on the valve.
Here are my mistakes and their remedies.
1) the handpump had a direct solid connection with the chuck. I would break a lot of valve stems that way. Get a pump, hand pump or floor pump with a flexible hose and let it flex as you pump.
2) I used to thread the adapter onto only the top set of threads. Those threads are actually for the dust cap. So when I pumped, some of the air would go in but most would leak out. Thread the adapter to the bottom set of threads but not too far. You want the internal stem to reach its fully extended position when you're drawing back or releasing the chuck. When you're unscrewing the adapter, be careful not to have anything touch the valve core or you'll be releasing air. It's very sensitive to lateral movement.
Quoted: 509 Post(s)
Liked 643 Times
My guess as well. One other possibility (if this is just one valve causing problems) is that the valve is sticking. A little bit of silicone oil down the valve stem will fix this. Note not to use petroleum oil as that can rot the inner tube.
Quoted: 2499 Post(s)
Liked 2,978 Times
Go to your favorite local bike shop. (Might be best to call ahead to ask when they're likely to be less busy. Or just go on soon after they open.) Almost anyone who works there will be able to show you proper Presta valve technique.
Likes For Trakhak:
Thanks for the replies, I'm still struggling to get the hang of pumping up the tires.
I'll have to take the bike to a bike shop and see if they can give me a demonstration.
Likes For jonb5:
Quoted: 790 Post(s)
Liked 348 Times
I just drilled a bikes rims out and put the nice fat Schrader tubes in it, problem solved. I have done this to every bike I possible could for years. The easier cycling is and the more BS free it is the more fun it is and the more you want to ride. That is the reason I built my single-speed coaster-braked Schrader-valved, flat-pedaled road bike. I am free......
Likes For beng1:
Quoted: 4273 Post(s)
Liked 1,370 Times
Quoted: 6233 Post(s)
Liked 4,836 Times
Hard to tell you what you might be doing wrong trying to inflate your tires. I think that's probably because few of us have ever really had any issues inflating them.
Presta and Schrader don't work the same. You don't need to push the air chuck down very far at all on the valve stem with presta's. But even if you were doing that, I can't think why they'd act like you describe.
Perhaps you'd be better off demonstrating it in front of someone at a bike shop and then seeing if they experience the same thing when they try to pump up your tires or if they do something just a tad differently than you.
Quoted: 8307 Post(s)
Liked 9,100 Times
You said you are using a Presta "adapter". This might be the problem. Use a pump head designed for Presta valves. If it is worn out it won't stay on. Don't drill your rims.
Quoted: 551 Post(s)
Liked 419 Times
Always fill PV's directly with a PV specific chuck.
No crappy "adapters". This is a hack that always never works.
No crappy Walmart pumps that claim to be PV/SV compatible. Most of them try to grip on by ballooning rubber around the PV.
Do things half-arsed and improper, don't expect things to work.
Liked 1,370 Times
People have already given him the standard advice.
He should go to a shop (like he said) or have some one knowledgeable look at what he is doing.
Quoted: 5227 Post(s)
Liked 3,598 Times
these are mine
like I said, the conversion isn't for everyone, but if you lose your patience, even w/ personal guidance at a shop, ask them what they think about converting yours
Liked 2,949 Times
Thread Killer
Quoted: 3165 Post(s)
Liked 1,723 Times
I think the best thing you can do is to take your wheel and your pump to someone who knows what they’re doing and have them show you. Ideally it’s your local bike shop, but maybe it’s an experienced friend. There’s really no special skills or tricks which need employed to inflate a presta tube, so it may be your pumps are rubbish, so it will be best if the person you go to is a pro or at least an experienced amateur tech with specific experience with bicycles and presta valves.
aged to perfection
Quoted: 840 Post(s)
Liked 1,271 Times
what I'm thinking is that the rubber grommet in the pump head is worn or not gripping the valve stem.
so you're always going to have air leaking out of the pump head.
on quality pumps this part is replaceable, on cheap ones, forget it
Sometimes you can tighten the collar on the pump head to give the pump head a little more "bite"
/markp
/markp
