Open but sealed Dot 5.1 fluid - useable???
Bikes: Canyon Ultimate CF SL Disc, Canyon Spectral
Quoted: 73 Post(s)
Liked 24 Times
I have 2 containers of opened but tightly closed Dot 5.1 fluid. They've been sitting around for 3 years. Can I use them to bleed my brakes (SRAM Guide RSC)? I know Dot 5.1 fluid cost $10 on amazon, but I'd like to use what I have on stock if possible.
Thanks.
Thanks.
Quoted: 803 Post(s)
Liked 2,984 Times
tool to test/
only way to know for sure if its safe is to check it for moisture.I wouldn't discard it without knowing.
https://www.amazon.com/Profession-Au...a-910158490942 a good read;https://rxmechanic.com/best-brake-fluid-tester/
Likes For '02 nrs:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
DOT 5.1 is hygroscopic, if that answers your question. I always buy fresh containers for my cars, it's cheap enough for what it does.
Likes For ThermionicScott:
Quoted: 254 Post(s)
Liked 182 Times
If it wasn't left open for a long time and the seal is tight, I wouldn't worry too much. The amount of moisture in the air that was trapped in when you closed should be minimal. You just want to avoid leaving it open for extended periods in a humid environment.
Likes For AeroGut:
