pakiT has arrived!
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
pakiT has arrived!
More details later...build has velocity A23 rims and race hubs, sugino cranks, shimano 105 caliper brakes with tiagra levers.
Liked 374 Times
The bar in my Nitto upside down. The stem turned out much higher than I expected and I may get it cut down but if not, this works quite well. I've been using it right side up on my NWT for a couple years and shifting and braking are super easy. I actually had a tendency to sometimes accidentally shift when I had straight bars if I went over a bump since my hand was on the rubber shifter part - this never happens on the swept back bars.
That's sweet! I dig the color and the flipped 'path racer look' bars. Two thumbs up! 👍👍
Bikes: Dahon Curve D8 (Sturmey Archer X-RF8), Crius Smart 3.0 5 speed
Quoted: 113 Post(s)
Well kitted out bike. The swept back bars are unusual, but I like them. How does it ride?
Liked 374 Times
Aside from the wheels, the bike rides much like any road bike. The geometry is different from my NWT so I am still dialing in the perfect fit.
The good: bike is totally silent, shifts beautifully, brakes really well given they are calipers (I'm used to avid v brakes). The wheels are lovely and the hubs roll for days. I put Velo Orange touring pedals on and they are quite nice and grippy. Instead of moving my heavy brooks over, I bought a Fizik saddle and it is actually a revelation! My butt has never been so happy =).
I haven't pulled my burley travoy with it yet, but I did figure out how to clip the folded bike to the travoy so I can take the bike inside when I go grocery shopping.
Total weight including my bell is just a little under 20 lbs. Not sure I will keep the kickstand, I keep getting my pant caught on it, and it's 92 grams anyway. If I dump the kickstand and decide to cut down the stem (and put the bars right side up) that will drop the weight a little bit. But it's incredibly light and responsive.
Quoted: 317 Post(s)
I've only had a couple of hours on it so my thoughts are preliminary. I was absolutely unprepared for the difference between wide 20" wheels and very skinny 16" wheels with slicks. I'm adjusting to the twitchiness and narrow tires but I probaby won't feel comfortable until I've had a few more rides. Right now I am aware of them - eventually I hope not to be.
Liked 374 Times
My son would laugh to hear me and "speed monster" in the same sentence, lol. But, yes, it is quite easy to feel like you are moving fast on 16" wheels...probably a false perception (waiting on my new wireless speed and cadence sensors). But after all the angst of deciding, I'm happy. Early days yet but it seems to be exactly what I wanted and needed. And I'm glad I went with the orange...
Very nice, congrats!
Is that an Off Yer Bike carry handle? It looks similar to the Brompton, but the Brommie version is a different configuration - very wide strap at the back, narrow strap front.
Liked 374 Times
Similar - it's a Moving Grip by Bluesprite, comes with shoulder strap as well.
Nice looking rig, congrats... we need a folded pic!
Nice! How long do you think you can comfortably carry it around? Is the chain really, really close to the ground? Good to hear you like the ride. Good choice with the 8 speed derailleur? Tried any tough hills yet?
A little disconcerting that the handlebar came too long--even though BF has your measurements (from previous bike) and it still wasn't right. I have to say, the non-adjustable handlebar stem is the biggest wet blanket factor against the Pakit for me.
Liked 374 Times
It's just under 20 lbs with my handle thingy, bell, etc. But there's a shoulder strap that clips on the handle thingy if I am carrying it for a long time to share the weight. The handle is fine if I'm going up stairs or in and out of stores, etc. I've carried purses that weighed more, lol.
The rear der is a 4 inches off the ground to around 6 inches up depending on gear, but I've not had any issues even going off curbs. No hills yet (24 mph winds here today...eww).
Every day the ride gets better and better - today it felt like my NWT, only better in some ways. I didn't notice the small wheels or any wobbling today from them. I actually almost rode hands-free which I cannot do on my NWT at all. And - sacrilege - I like the Fizik saddle way better than the brooks.
the upside down handle bars is not so weird ,the Durstly Pedersen bikes were set up like that 100 years ago..
telescoping clamped handle bar mast, is on my tikit, so its adjustable in height . (It was offered, I suspect)
maybe they will swap for one functionally similar , credit the one you have
just sawlng it off can be done , though the cut edge will lose its powder coat ... so get touch up paint..
but dialing in the bar height... stem is not holding the headset down like a threadless headset fork,
so you are free to clamp it or many different ones anywhere on the steering mast.
Etc, etc.
Etc, etc.
Liked 374 Times
Etc, etc.
Etc, etc.
I figure it's safe enough to clamp lower for a few days while I dial in the exact position. After the lbs cuts and files it, I will touch it up with either some black paint or clear coat - thanks for that tip.
I do like the upside down bars in terms of looks and feel, but it's too hard to clip to the frame compared to the narrow straight bars.
You can replace the stem you have, with an angle adjustable one, and flip it over to angle in either direction...
I had Bike Friday Separable straight bars for my p. Llama, went with trekking bars , and the BF flat ones went on the Tikit..
On another bike I used Nitto's Mustache bars the brake lever , old, road, mounts in front .. whole thing taped .
[Old Bridgestone bike Specs]
trekking bars offer even more hand grip places,.. Have a grip shifter, & straight bar levers on them ..
Many after market options..
Liked 374 Times
The pakit is a different beast from the other BF bikes - the bars need to be a specific width and shape to properly clip in to the stem retention system when folding.
Likes special bikes
Bikes: Solio 1910, Colnago Sprint 1986, Nehan TT 1989, Bianchi Mercatone Uno 1999, Boreas Aër Roadbike 2003, Canondale six13 2004, Ghost SE7000 MTB 2009, Bike Friday Tikit Hyperfold 2011, PlanetX Excocet II 2014 White Fatbike 2021,
Quoted: 22 Post(s)
Liked 16 Times
How many gears on the cassette?
PS: Has nobody found an alternative to the Devils horns on the back? ;-).
Are they removable?
Are they removable?
Liked 374 Times
The kickstand is removable. The only thing I've come across so far is the click stand. Still deciding if I want to go that route. It IS nice to be able to just swing the wheel under and it stays put. Clickstand would require a little more effort. But I touch that "horn" with my foot/pants too much when I ride and I don't have big feet. I found what I think would be a brilliant solution but I don't think they make it anymore (kwikstand). It's a little stick that has an end that matches the hole of your specific crank bolt. Just pop in the crank bolt hole and done. The bike is so light that would be plenty to hold it up. But I think they are defunct. Another option is the upstand, which doesn't get rave reviews for anything loaded, but might be okay for a sub 20lb bike.
my other straight bar bikes are fine with Ergon Grips...
I may need a longer bolt to meet its bar mast catch, (on the Tikit) because the grip is not round.
But I fold the Brompton more easily, but the Tikit has a different hub, Sram i-9, I'll be waiting for spring to ride it..
Brommy has a hub Dynamo light set, .. I don't go far in my town..
good luck finding optimum comfort on the bike you bought.
Liked 374 Times
Not adjusting the numbers for the angled-back handlepost is a pretty serious mistake..I'm surprised they missed that. But it sounds like you've solved the problem.
After all my musings about Brompton, it turns out I'm joining you in Bike Friday World! I'm moving and my riding situation is changing a lot, so I sold the Brommie and picked up a used BF Haul-a-Day cargo bike. It's going to get a mid-drive electric kit. Whee!
