Bikes go flat suddenly, Texas, U.S.
This could be a combination of several issues. Low quality tires with beads not firmly sitting in the rim. Combined with too little pressure they can "slide" on the rims when breaking and rub against the inner tube. Add some cheap inner tubes and you will see scratch marks on inner tubes. Inner tube quality just isn't what it used to be.
Than the sun in Texas. Everything gets beaten to death. Especially rubber and plastic.
And one thing you also have to watch out for in South and Central Texas when you ride on dirt trails or across grass: Goat's heads. These little thorny seeds (about 1cm wide) are nasty buggers and punch normal bikes tires like butter. Oh and when you step in them it is even worse.
https://en.wikipedia.org/wiki/Tribulus_terrestris
Will keep in mind these Goat's heads.
Finally, I was able to upload both picture in the very first post of this thread, for completeness. Thank you guys for your support.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 741 Times
Auto Junk yards are required to use barriers to obscure the view of the cars...
Ask the apt. Manager what they prefer. A blue tarp or a sheet of plywood. Paint the plywood to match the Building. how many rusty Barbques are sitting around?
