Best integrated brake lever/shifter for a 9 speed bike
Hi all,
Long time reader, first time poster....(nervous chuckle).
Ok, in an attempt to improve my bike mechanic-ery I asked my neighbor if he wanted me to fix up 2 of his bikes (since I have fixed all my bikes now). I need a recommendation for a good integrated brake lever/shifter set for a 9 speed. Currently it has Shimano 105 flight deck levers. I am fine with replacing the levers with a new set of these, but on a preliminary google search they don't seem super......available?
I am trying to keep the levers under $100 if possible, but still want to stick with Shimano. I have never replaced integrated levers, so if you have any suggestions about what I should be looking out for, what normally goes wrong?
Help me knowledgeably and masterful bikeforum!
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
Can we assume that the definitely need to be replaced, and not fixed? Lots of advice on this forum about how to flush ones that are sticky and recalcitrant.
If replacement is in order, look at Microshift. Shimano compatible, well reviewed, available new.
You can also still find Shimano Sora 9 speed shifters -either new or lightly used- that will work just fine for around $100.
Thanks for responding!
I would say they definitely don't need to be replaced, the hood covers need to be replaced and there is a piece missing on one lever. I asked him what he wanted to do, I said that bike would be fine with just a tune up and he wants to replace the brake levers. I think they could be spruced up and plan on keeping them, since he said he wanted them to be replaced. Maybe when he sees how expensive a replacement is he will change his mind?
By the way, I guess I didn't mention, its a 3 x 9 speed
I also did see the Sora for the 3 x 9, I assume they are pretty good for Shimano's mid-tier? In further searching I am definitely not able to find 105's for anything smaller than 11 speed :'(
I did see microshifters listed on some articles of recommendations. I had never heard of the brand so I wasn't sure about them. I thought it might be the best idea to keep everything Shimano, but now I am not so sure.
Likes For alcjphil:
Constant tinkerer
I don't have any brifter recommendations. But down-tube, bar-end, and Gevenalle shifters (they're almost brifters) are other options that will work with 3x9 and last the life of the bike.
Quoted: 1438 Post(s)
Liked 1,092 Times
I like the Gevenalle brake/shifters for their simplicity and ruggedness, and they offer an economical repair service if you do manage to break them. Remember they were developed for 'cross racing.
Likes For dsbrantjr:
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
You are unlikely to find anything of quality in 9 speed these days in integrated brakes and shifters. However you will find the lower end stuff which is an option but dsbrantjr 's suggestion of Gevenalle is the best idea. Very reliable and easy to replace stuff and way better shifting.
Keep in mind 9 speed is rather old equipment so that is why finding more quality stuff is hard to get unless used or some NOS stuff someone has hidden away.
Yeah, it's unfortunate. I don't like when things become obsolete via the market. I did find a nice set of shimano sora for 9 speed on ebay.
I wonder if it would be worth replacing the cassette? But that is a lot more effort than I think he or I are committed to
Clark W. Griswold
Liked 4,000 Times
Keep in mind the Shimano Heirarchy for their road group sets from the bottom of the dumpster on up is Tourney, Claris, Sora, Tiagra, 105, Ultegra and Dura Ace at the top and for Mountain Bikes it is Tourney, Altus, Acera, Alivio, Deore, SLX, Deore XT, XTR and at the top.
Constant tinkerer
To Replace Cassette and chain you would need a new derailleur as well as new shifters assuming we are talking about an upgrade in speeds. 9 speed was the last bastion of road and mountain working together and everything being easy to deal with once we hit 10 and 11 things splintered off so the older tech isn't going to work very well and the new tech has to match up.
Of course, the shifter/cassette/chain are all speed-specific.
Clark W. Griswold
Liked 4,000 Times
Quoted: 1944 Post(s)
Liked 2,164 Times
If you need shifters, just buy Microshift 9 speed integrated shifters.
I would like to try Gevenalle one day, but you’ll not find any for less than $100. And, the shift levers are Microshift, which you’ll have to buy.
Basically you are buying the most expensive downtube shifter mounts ever produced and inexpensive Tektro brake levers with a hole in them.
John
John
Likes For 70sSanO:
Constant tinkerer
But, as I said before, a Shimano 10S road rear derailer is the same as 7/8/9. No it's not literally the same part, they change the appearance every time... But it's exactly the same shift ratio. Meaning you could upgrade your 9S road bike to 10S by changing the shifter, cassette, and chain, but keeping the rear derailer.
Likes For FastJake:
Quoted: 1109 Post(s)
Liked 1,200 Times
If your "customer" wants new shift/brake levers, get Microshift and be done with it. There will then be no need to replace the rear derailleur unless it is broken. Replace the chain and/or cassette only if you think they need it. When you're working on a friend's bike, you probably want to make sure the braking system is good.
