brake caliper suggestions?
feros ferio
Quoted: 1393 Post(s)
Liked 1,328 Times
I have started riding the Bianchi more frequently again, and I love everything about it except the stopping power offered by the brake calipers (early-generation Campag. sidepulls). I am specifically looking for (recessed) bolt-in replacements that feature greater leverage. I already have KoolStop salmon pads, Shimano aero brake levers, and good cables and housings, so the calipers are all that is left. Recommendations? Safety takes precedence over "correctness," since the bike is a rider, not a collection piece.
Original equipment matched 1982 Campione d'Italia specs. Frame date is late 1981. "Charcoal" color not found in catalog listing.
Quoted: 3811 Post(s)
Liked 6,711 Times
What reach do you need?
I have been very happy with various models of Tektro recessed-mount, dual-pivot calipers. Very good value for the price. On one more modern bike, I have TRP medium-reach calipers, and they're excellent stoppers (though much more pricey than the Tektros).
Likes For nlerner:
Quoted: 3513 Post(s)
Liked 2,927 Times
Dura Ace dual-pivots, of course! I prefer the 7700s, but I hear later versions are stiffer.
Likes For smd4:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,405 Times
There are bunches of excellent low mileage Shimano dual pivot calipers out there. 5500,5700,6500 and 6600 are at the low end of the price spectrum, under $50 a pair.
They’ll work as well as anything out there.
Likes For rccardr:
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Shimano dual pivots for sure. If you are not hung up on brand, Tektro makes calipers that would fit the bill. You can always remove the logo.
Likes For CV-6:
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times
I’m happy with the performance of Tektros (have a couple sets of R539s), other than that the finish on the small hardware bits is awful and rusts very easily. I haven’t had this problem with multiple generations of Ultegra calipers.
Likes For C9H13N:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I'll third tektro dual pivots. If they don't stop u I don't know what will.
Likes For 52telecaster:
Likes For bamboobike4:
feros ferio
Liked 1,328 Times
Thank you, everyone. It looks like we have consensus. I'm going brake caliper shopping. I had a scary experience with Shimano pads on the Campag. calipers (actually keep creeping forward with brakes full-on during a descent under foggy conditions), but KoolStop pads on Shimano calipers should be a much different story.
feros ferio
Liked 1,328 Times
Thanks for the oxidation warning, since I live a km downwind of the Pacific Ocean.
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
+1 polished shimano dual pivots
the grey tricolor ones are always appropriate too imo
small note, there's a blip for shimano brakes were they didn't have much clearance. I don't know if this matters with your bianchi but 5500/6500 (and 5600/6600?) can struggle to fit 28s/30s or wider rims, after and before that it's more generous.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Just about any dual-pivot caliper will have greater mechanical advantage than a single-pivot side-pull caliper. Tektro makes a variety of dual-pivot calipers in a range of price points and reaches. Nothing wrong with Shimano calipers, either.
Likes For JohnDThompson:
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,927 Times
I must be the only person in the world to have removed dual pivot brakes and put singles on.
BTW I am looking for a good condition red calipers, recessed.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
feros ferio
Liked 1,328 Times
The Bianchi frame is pretty close-coupled. I can fit 700Cx28 Continentals, which actually run about an inch, or a bit under 26mm, but not 700Cx28 Specialized, which run closer to callout size. Even with the Contis I have to deflate the rear tire completely to remove the wheel. This differs significantly from my same-era PKN-10, now my son's bike, which can take 700Cx32 and some 700Cx35 tires.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I learned a lot about stuff building, re-building and upgrading that bike.
1986 Trek 400 Elance by Dave The Golden Boy, on Flickr
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
ambulatory senior
Liked 3,661 Times
Quoted: 4806 Post(s)
Liked 3,931 Times
Any good dual pivot will give you a lot more power. I have Shimanos I picked up used (2000?) that are real stoppers.
Early generation Campys were poor stoppers unless you have big strong hands. I have the size but not the strength. I rode a pair of NRs for about 18 months on my commuter (a former racing bike. There were several times in the wet when I wondered if I could actually stop at the stop sign at the bottom of the hill, starting mid descent. When I raced mid-'70s I had far more stopping power with Grand Compe sidepulls. I kept in mind that none of the bikes around me had my stopping power. The SunTour Superbes on one of my setups are also far better. Still, both pale compared to the dual pivots.
Quoted: 502 Post(s)
Liked 466 Times
Another strong vote for dual pivots with Kool Stop salmon pads.
I’ve been using a variety of Tektro dual pivots, probably four different sets of different reach, as well as plenty of experience with Shimano DP’s. Both are excellent when set up with the same pads and I always use KS salmons.
FWIW, I live in the PNW about 2 miles from salt water, no stranger to rust, and I haven't noticed that the Tektros are any different than other components with chromed fasteners. The Nitto stem bolt hex recess seems to be the only spot that show rust. The high polish of the Tektro calipers goes well with the full chrome rear triangle of the Marinoni. These days I’m using R556 (R559 predecessor) long-reach with the 650B conversion.
One weird negative for Shimano: The rear Dura-Ace 7403 (and I do like these otherwise) on the Marinoni developed an incurable squeal last year after having been trouble free for years, strong enough to send quite a vibration right up the seat post. (Front 7403 continues to be fine.) No change of toe-in or different pads, pivot or bolt tightness would solve it. I replaced that caliper with a used Tektro R540 and the same KS salmon pads - problem solved!
I would recommend against Campy dual pivot calipers for the simple reason that they don’t include a caliper-located QR. Having a QR on the caliper, plus one on the brake lever (Sachs Ergos in my case) allows the brake to open wide for fat tires (700x32 or 28, 650Bx38).
Anecdote about pad effectiveness: When my son was coming down the a steep hill leaving our Seattle neighborhood on his first drop bar bike, equipped with Shimano DP’s and Shimano pads, all in good condition, he was barely ably to stop at the base of the hill. Yes, he was squeezing from the drops. That evening I replaced the pads with KS salmons. Next day, same hill - no stopping problems whatsoever!
Quoted: 604 Post(s)
Liked 1,064 Times
Lots of dual pivot Campagnolo calipers, new and used, on eBay, they would fit the all Italian theme of your bike a bit better. Of course the pic is fuzzy so maybe it’s not.
Tim
Tim
I just don't understand this at all.
I've never had trouble with Campagnolo Nuovo Record brakes. They stop the bike. They are easy to modulate if you want to slow or decrease your rate of acceleration. I can operate them from the drops or the tops.
Go back to the original Campagnolo levers and ditch the aero cable routing and levers.
P.S. - that rear cable routing does not look right.
Bianchi Goddess
Liked 2,927 Times
My brakes will skid the tires if I wanted to do so. Not just the rear but they can probably skid the front tire, as well. Certainly they are strong enough to throw you over the handlebars, if you wanted to do that for some reason.
The thing is, they are easily modulated to NOT do those things. You can take them right to the point and hold them there as you slow down. It's true on the flats. It's true on high speed descents.
Well, like I said, I don't get it.
Liked 2,927 Times
I don't know. I had Dura Ace 7400 single pivot brakes. Top of the line, and maybe even better than Campy. I was a shop mechanic then, and could adjust brakes to within an inch of their lives.
Did they work? Sure. But never with the positive action I always thought top-end brakes should have. They always had a certain amount of mushiness.
I never got the kind of braking I always wanted until I got DA 7700 dual-pivots, and then I upped that game considerably using compressionless cable housing. Now I could probably stop the bike from the hoods using my pinky fingers.
I thought my 7400 calipers were the best looking brakes ever created. They were never the stoppers I thought they should be. I don't believe Campy brakes at the time were any better.
Old fart
Liked 3,401 Times
If you're accustomed to the mechanical advantage of dual-pivot calipers, braking with a single-pivot side pull can be disconcerting. Like you, I have no problem stopping my bike with Campagnolo Record side-pulls and their various clones from SunTour, Gran Compe, etc. But it does take decidedly more effort than a dual-pivot caliper.
