Tire Deterioration
Bikes: 1987 Schwinn Mirada, 1989 Trek 420, 1995 GT Timberline, 1979 Schwinn Super Le Tour, Co-Op DRT 1.3
Quoted: 103 Post(s)
Liked 85 Times
Tire Deterioration
Ok, not the greatest photo but best I could do so bear with me. The tires on my road bike have developed a sort of separation along a seam near the rim. Look close and you can see how the screwdriver head is folding back an edge. Is this a sign they're giving up the ghost? Tread and everything else is still fine. They're Bontrager T2 tires, about 2.5 years old. Thanks!
Quoted: 6193 Post(s)
Liked 4,809 Times
I've seen others with the same issue. It might cause you to have a failure sooner than not. But the others I've seen were much worse looking and they lasted their owners many rides.
I've wondered if it's caused by the rim cutting through the soft rubber sidewall covering when riding with too low a air pressure or riding on a flatted tire for a time or if it's just sometimes a tire shows up that wasn't the best built off the production line.
It'll probably last a lot longer than you think it will.
Likes For Iride01:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Looks like the edge of the chafer strip to me. That's an extra layer of fabric bonded around the bead to protect it from abrasion. Totally normal for it to start to peel away at the edge after some use.
Likes For ThermionicScott:
Quoted: 3511 Post(s)
Liked 2,926 Times
Likes For smd4:
Quoted: 103 Post(s)
Liked 85 Times
Quoted: 4204 Post(s)
Liked 3,862 Times
Agree with the chaff strip often becoming separated just above the rim. This by itself hasn't been a problem for many before you, use to be real common with sew ups then when wired ons became so lightweight we began to see it with non race tires too.
Nice photo showing the question spot BTW.
smd4- Yea, usually its other issues at that high a tire pressure Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Liked 2,926 Times
Quoted: 837 Post(s)
Liked 1,061 Times
Agree with the chaff strip thing in posts #3 & #6. Have had plenty of those and never an issue. I cut away the threads as they come loose to avoid triggering my loose thread OCD.
Likes For Crankycrank:
