How many gears is too many?
#126
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
#127
Klaatu..Verata..Necktie?
Quoted: 10471 Post(s)
Liked 11,982 Times
And even that can change with mood. Sometimes, I want to ride my bikes with 2x6 gearing. Sometimes 2x11.
#128
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,045 Times
That might be a bit harsh. It depends on the kinds of numbers you prefer.
60 is composite, colossally abundant and superabundant, so it’s a fairly special number.
59 (and 61) are both sexy primes (53 and 67 are also prime) so they are also special.
42 may be the answer to the ultimate question of life, the Universe and everything, but 43 is both a sexy prime and part of a prime triplet (37 and 41 are also prime), so it’s pretty cool, too.
Still, even 42 is too many, IMO. 😊
Otto
Otto
#129
Quoted: 18456 Post(s)
Liked 15,695 Times
Can’t see much overlap.
#130
Quoted: 590 Post(s)
Liked 445 Times
TWO gears is the right answer. One for the flats at 80 rpm (at endurance output of 80% of FTP), and one for steepest uphill YOU will encounter at 80rpm (at endurance output). Anything more than TWO is just for ease or speed. If there's no hills (aka Florida), then ONE is the right answer.
#131
Quoted: 7663 Post(s)
Liked 3,520 Times
Likes For Maelochs:
#132
Liked 15,695 Times
Likes For indyfabz:
#133
Quoted: 4471 Post(s)
Liked 4,945 Times
#134
Liked 15,695 Times
#135
Quoted: 590 Post(s)
Liked 445 Times
Now I can't imagine life without my 2x11 Di2, spinning up 9% grades with a 1:1 ratio, and flying down with a 1:4.55, and dumping the whole cassette with a single press and hold of a button. So I've learned to embrace ease and speed, but I'd survive without them in my life.
#136
Quoted: 830 Post(s)
Liked 1,678 Times
All you have to do is to look at a snowmobile driveline, and envision something lighter that was calibrated to the torque and speed of a rider and bicycle.
Likes For Bald Paul:
#137
I am potato.
Quoted: 1795 Post(s)
Liked 1,640 Times
I think his point is that any ratios ~1 gear inch different (or ~2% or so) are meaninglessly different. They are effictively duplicates.
Here: Same data viewed in a different format.
Car dependency is a tax.
#138
Liked 3,520 Times
The biggest issue I see with indyfabz' chart is big jumps, particularly at the ends. The chart indicates why 3x11 would be a superior touring/randonneurring set-up.
Likes For Maelochs:
#139
Palmer
Quoted: 1674 Post(s)
Liked 1,837 Times
Likes For tcs:
#140
Liked 15,695 Times
#141
Palmer
Liked 1,837 Times
#142
Liked 15,695 Times
I got the cog numbers from Shimano cassettes I found on line since I am not at home to count mine. I am assuming they are what I actually have. I would definitely like to tighten it up at the low end, especially since I have gotten older and don't train (as) much. Don't really care about the very high end. Even when touring or commuting on flat roads I am not concerned about the high end. On steep descents I am almost always coasting anyway.
#143
Palmer
Liked 1,837 Times
252 gears, 3000% range, couple of years back, off the shelf parts:
#144
I am potato.
Liked 1,640 Times
yeah, but as we all know, it is a combination of available ratios and ease of access. The bugaboo of "overlap" matters when you have a 2x6 .... a 2x11 or 3x9, not so much. In fact, as I have said too wordily elsewhere, I have always liked knowing where near duplicates were so i could pre-shift---get into teh top of the small ring from the middle of the big ring at the base of a tough climb, for instance, or go from the middle of the small ring to the bottom of the big ring when i was coming to a corner so i could maximize ease of acceleration out of it.
If it were me, & I too were bound by minimalism I'd do away with the middle ring altogether & live with regular double shifts if there was that one "magic" ratio I needed. The environment in practice is such that most times, by the time you find it, or can get to that magical ratio needed, the goal posts have moved. Long steady climbs, with heavy loads & lots of time to figure it all out (like a mountain pass) being the exception for the bulk of the miles rode by bicycle buying public. Such is life.
Cross-chaining be damned, (shamefully, myself included) people often tend to operate their bicycle as a 1x high range & 1x low range, & in the case of a triple a 1x midrange anyway. It's no wonder the middle ring has fallen out of favor as a redundent production cost, on a marginal gain, most customers don't know how to use properly anyway.
I'm seriously tempted. Just so that I have it around for a future project.
#145
Liked 15,695 Times
Very true, which is why I think my situation is out of the ordinary when it comes to my view on triples for the type of touring I sometimes do. Road bike-wise, I have no desire for a triple.
#146
Quoted: 3972 Post(s)
Liked 7,395 Times
Likes For tomato coupe:
#147
Quoted: 3247 Post(s)
Liked 2,533 Times
And, except for the very outer range each way, you can get around through your range with a lot less physical shifting. That's important for all day riding. Most importantly, you have options to match the grade or wind when enduring the slogs you are talking about. Half the time, I might not even know which cog I'm on in back. I have to look down/back to see which cog I'm on and which way I want to go. But, I have options, That's all that matters to me.
Likes For seypat:
#148
Liked 7,395 Times
#149
Liked 4,945 Times
Think of it like this. On your small chainring you have only 3 gears that are significantly lower than the lowest gear on your middle ring. Then on your large chainring you only have 2 gears higher than the highest gear on your middle ring. The rest are all overlapping even though they are not identical duplicates, except for the 32.8.
#150
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Likes For livedarklions:
