Are Carbon Road frames really worth the extra cost?
#53
Just like me and my fishing rods
Do I need high composite graphite and titanium silicone carbonate guides to catch a fish with the brain the size of a pea? No
Do I like them? Yes
To each their own
I want a light weight bike. Graphite matches that want. But I'm still cheap, err, frugal and am holding off buying anything until I find a deal. Or a sale. If it happens, I'll buy it. If it doesn't, I'll ride what I have.
Do I like them? Yes
To each their own
Likes For HookUp:
#54
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
#55
Quoted: 236 Post(s)
Liked 196 Times
Yes, there are crappy engineers and crappy companies out there.
I did not read all of the posts in the thread but tire selection and pressure can make more of a difference than frame material. If money is a consideration, I would suggest OP get the aluminum but put supple, wider tires at lower pressure.
I am curious why one wouldn't choose the most suitable tire for one's riding conditions with either frame material?
Likes For gpburdell:
#56
Tragically Ignorant
Liked 9,098 Times
#57
Tragically Ignorant
Liked 9,098 Times
The OP was specifically asking whether the difference in cost of the frame material was worth it.
#58
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
The point, as I understand it, is that in all the hand-wringing and teeth-gnashing about frame material, tires often get neglected as an important ride-quality factor. IME, lots of folks just stick with the tires that came on the bike, especially when buying new.
To me, it's similar to acoustic guitars; those forums are full of arguments about "tone woods," but string material is every bit as influential to the sound. You'd be surprised at how many people think you should always use Martin strings on a Martin guitar.
Likes For Rolla:
#59
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Likes For Kapusta:
#60
Tragically Ignorant
Liked 9,098 Times
#61
Quoted: 236 Post(s)
Liked 196 Times
OP specifically asked: "I'm having a hard time trying to justify the extra cost of carbon over aluminum. For those that have a Trek with the ISO system does it really make a difference in aiding in a smoother ride?"
The aluminum Domane doesn't have rear isospeed, the carbon Domane does.
Therefor the OP was asking about those differences. There are also other differences between the aluminum & carbon models which factor into the price difference. We're on a discussion forum and whether or not you believe the OP was asking _only_ about carbon vs aluminum doesn't make the other differences between cited models irrelevant to the OP's decision process.
Because that's what Ghostrider wrote:
He suggested putting supple, wider tires at lower pressure on an aluminum frame bike as a more economical option to the carbon frame model.
Thus my question why one wouldn't do the same on the carbon frame version as well?
Why would you assume that was implied? They didn't say anything about offset. I took it they were saying that if you put good tires on either, there isn't much difference in the feel of the ride, and not assuming OP would put crappy tires on the more expensive frame.
#62
Advanced Slacker
Liked 2,537 Times
Some folks need to lighten up.
Likes For Kapusta:
#63
Quoted: 2333 Post(s)
Liked 2,097 Times
My custom Mg frame and fork were almost $5k and it is easy to spend that or more on a custom steel frame.
Welded aluminum frames are dirt cheap to make. I personally find them too harsh. Tire selection is not an independent choice in my mind. If you have a plush frame and fork, you can get away with different tires from a comfort point plus there are other things to do to make a ride more comfortable without a new frame.
#64
Liked 2,097 Times
I am fixing to go out on my fast carbon bike right now. Why? I feel like going fast today. I have been riding my comfortable big tired upright steel bike.
It's all a compromise. Me? Just never been fond of aluminum, it is either too flexible or bone jarring stiff from my experience.
#65
Guest
Liked 3,270 Times
I think the conventional thinking is that one doesn't need as much tire suppleness on a carbon bike, so perhaps other factors (like weight, tread, and longevity) could supersede comfort as the primary consideration.
#66
Tragically Ignorant
Liked 9,098 Times
The aluminum Domane doesn't have isospeed, the carbon Domane does.
Because that's what you wrote:
You suggested putting supple, wider tires at lower pressure on an aluminum frame bike as a more economical option to the carbon frame model.
He's asking for an apples to apples comparison.
I didn't suggest the tire thing, you're quoting GhostRider62 responding to my post. And yes, I understand he was suggesting that the OP would get more "bang for the buck" by upgrading the tires on the aluminum bike rather than paying more for the carbon frame. It's a complete mystery to me why you think that implies that he's assuming that the hypothetical carbon bike wouldn't have comparable tires.
#67
Quoted: 236 Post(s)
Liked 196 Times
He's saying he can't tell the difference between the aluminum bike and the carbon bike with ISO, so you're faulting him for deducing from that that the carbon isn't making a noticeable difference? Are you suggesting that he's implying that the ISO is making the carbon worse?
have you considered the possibility he was asking for people who road an aluminum frame with ISO if they noticed a difference when they tried the carbon with ISO?
#68
Quoted: 18415 Post(s)
Liked 15,546 Times
Likes For indyfabz:
#69
Tragically Ignorant
Liked 9,098 Times
Sorry for the misquote.
I've not faulted the OP in any way, and am in no way suggesting what you seem to think.
You've apparently missed my initial reply to the OP. Maybe go back and read that before you go off on someone trying to help.
Maybe actually check about the Isospeed on the aluminum bike before you chime in on the other differences besides material. I'll remind you that you quoted me originally (post 56) to make some point about the OP including other differences. I didn't "go off" on you until you decided to "correct me" incorrectly about what the OP said and to misquote me.
#71
Tragically Ignorant
Liked 9,098 Times
Who friggin cares, it's a silly point anyway. He didn't make the "front only, rear and front" distinction, you did. What's the damn relevance to his basic question about the value of carbon?
#72
Quoted: 236 Post(s)
Liked 196 Times
That's makes very clear his question is broader than just the title.
Though if that is all you wish to focus on, that's fine. Though any meaningful discussion of the value of carbon frame being worth its cost, you must first identify what portion of the price differential that is specific to the frame material.
With the AL5 & SL5 Domane, just to keep it simple, the $1200 difference not only covers the carbon vs aluminum frame but also includes different wheels, tires, seatposts, handlebars, front isospeed decoupler vs front isospeed fork, isospeed rear decoupler, and I believe the 2022 SL5 comes already tubeless.
How much of the $1200 is all those vs the cost of the carbon? Need that before we can really discuss its value.
I'll let you go figure out the cost differentials of those items and what you arrive at as the remainder which we can then attribute to the cost of the carbon vs the aluminum. (I believe bottom brackets are also different, but not sure those go into ride feel differences so you can skip that.)
#73
Tragically Ignorant
Liked 9,098 Times
TBH, I think the Isospeed on the AL 5 is in the fork only, but I still have no idea what this has to do with the stated topic of the thread.
#74
Quoted: 20810 Post(s)
Liked 9,456 Times
AL has rear Iso, not front.
edit: in doing more looking, it seems as if Trek recently changed and is no longer doing rear Iso on the AL Domane. Funny thing is that they're not really doing front Iso, either, at least not in the sense of the traditional Front IsoSpeed with the upper headset bearings in a cradle that allows the front steerer to flex. From the info that I can find on their new "IsoSpeed Fork," it appears as if it's not really doing anything different than any other carbon fork that's allowed to flex a bit, It looks as if it's "IsoSpeed" in name, only.
Likes For WhyFi:
#75
Tragically Ignorant
Liked 9,098 Times
