52T Takagi lightweight crankset for fixed gear?
So I found this crankset online and planning to buy it as i think it would look awesome on my 1970s Centurion Le Mans. Just wondering if this would perform well on a fixed gear set-up? Seller says it's not cottered pin but I don't see any bolts which is the basis of my worries as I live in a quite hilly area. Thoughts?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
No, it is not a cottered crank. If you remove the dust covers, you can install a bolt to connect it to a square taper bottom bracket. The swaged chainring, however, is not removable, so you will not be able to change the gearing. It can certainly be used in a singlespeed or fixed gear setup.
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Quoted: 586 Post(s)
Liked 612 Times
Takagi was a popular manufacturer up until the mid 80s when it was purchased by Shimano. Many of their cranksets were marked Tourney and were swaged, like the ones in the OPs photo.
Quoted: 261 Post(s)
Liked 346 Times
I work with vintage road bikes a lot and these are very common. I think the 52 tooth is too big for hills unless you want to put a massive cog on the back. You cannot change the chainring as someone else said I'll said but I have seen a lot of low budget fixed gear conversions with these cranks. It's just a normal square taper crank.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Make sure your chainline is good. Those low-end, swagged chainrings are known to collapse if you have a really ****** chainline.
Likes For Dylansbob:
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Sure, I would use a cog on the 18-20 tooth range.
