New bike build log
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
Beautifully done! Gads, seeing your wire fishing brought me back to my electrical wiring fiasco on one of old harley’s but great perseverance! I think this should also get you hankering for a proper bike stand that can rotate and clamp lol! I love assembling my bikes and wouldn’t have it any other way.
Cant wait to see the build, it’s all easy peasy from here!
Let's have a discussion about that. I built what I did because I thought it was better than a clamp style setup. Clamping onto a frame is not ideal, and clamping onto a carbon areo seatpost I don't think is any better. It would put a lot of stress unnecessarily in the seatpost clamp area when the bike isn't oriented in it's upright position. With mine I can flip the bike around in seconds - granted I know I'm pretty much limited to only 3 natural positions - but upright is the position of choice the vast majority of the time except for the very rare circumstance. I'm not trying to be argumentative, I'd just like to hear your point of view to the contrary. Maybe it gives me some ideas or convinces me otherwise.
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
It's a neat looking frame from the outside.
Unhelpful comment- external cabling wont actually make recreational riders slower and it takes 2 min to route the cables and hoses.
Quoted: 429 Post(s)
Liked 248 Times
My only fear were I to use a setup like yours is that I would mistakenly jump the frame out of the cradle and have it drop to the floor while working. I do find it pretty handy to have 360 deg rotation with internal routing as well (my most recent bike didn’t have guides)
Bikes: Road bike
I bought the same frame, the ICAN A22 and plan to build it with a mechanical transmission and full length housing.
My problem is that I don't see any housing stops for the front derailleur. How did you deal with that ?
The housing is continuous from the shifter right to the FD. The FD has the housing stop built into it, at least mine did. Which FD do you have?
Sunshine
Liked 7,490 Times
Right! I'll be the first to admit I have the attention span of a toddler so I thought I'd already posted the rest of the stuff - but not so lol.
So the rest of the build went not bad since all the hard stuff was done. Setting up the FD was the worst to say the least. Shimano doesn't have any documentation on the pages with the FD for some reason. They have links to dealer documentation for everything else. Whatever it's a FD, the easiest of all parts to adjust.... no, no it wasn't! These new road FDs work a lot different. I mounted the derailleur, tensioned the cable, and tried to set the limit screws like any other mech but with no success. I couldn't get the derailleur to go low enough, the chain rubbed the cage in the two largest cogs when in the smallest chain ring. I removed the cable and backed out the L limit screw until it almost fell out and still no change. I was cursing the frame at this point and was trying to figure out if I could modify the bracket to make it work.
Frustrated I took to the internet, and I was able to google the Shimano documents. They didn't seem to make a lot of sense so I ended up on you tube vids. These helped a lot to make me realize these don't set up like any other FD I've dealt with in the past 30 years. Following along I backed out all the setting, well there still was no cable attached and the L screw was about to fall out so I only had to back out the H screw. After I did that I turned the crank and the chain dropped on the inside and chipped the paint! Grr! How TF does the H screw affect the low side? Anyway I followed along and got it set up pretty easily. It's not that difficult, just a lot different. I really need to examine the mechanism more closely but the screws can't really be considered limit screws, in fact the H screw is used to push the FD out farther and not limit travel.
A problem I did have with ICAN though was the screws in their seat post. They have the usual 2 screw arrangement but the front screw is way too short. t could be my saddle, I have a Fizik Arione VS that has elongated carbon rails. Luckily I had some hardware that worked. It works fine but it's that imperial crap (1/4-20) so I might change it out at some point only to satisfy my OCD.
The build is done now. Here it it is ready to go. I was able to get it out today and boot around the subdivision here but only did ~13km. Definitely feels different than any hybrids I've been riding for the last few decades. Not knocking the bike, I'm sure it's just something I need to learn and get used to... more aggressive riding position and handling. It felt a bit twitchy but we also had 65km winds today and with the wider rims that required some attention. It feels quick and snappy though!
Likes For Ryan_M:
Quoted: 10236 Post(s)
Liked 5,184 Times
Nicely Done!
Bikes: Road bike
So I ordered an Ultegra FD and I'll be ready to build the bike in a couple of days.
Good job, thanks for your feedbacks
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Looks good. I just did a buildup of my Habanero using Ultegra R8000 and I can confirm that the FD (and to some extent, the RD) setup is different, and the documentation that Shimano gives sucks. They say they have a QR code to get the "full" documentation but at least for me, scanning this gave me the same crap-o one page useless garbage.
I found a couple YouTube videos that walked me through cable installation and derailleur setup, and once done it rides and shifts like a dream. If you are not happy with the shifting it's worth looking at these.
So I'll be the weight weenie... what does it weigh now that it's built up?
I'm looking at a similar build (ican A22, 50mm wheels, ultegra mech).
The build looks great!
I'm not exactly sure but when I was trying to compare with other builds it was messy waters. So many ways to measure but it seems the most popular way to measure is bare bike - not including pedals, bottle cages, Garmin mounts, etc... IIRC with all those other bits added in it was ~7.9kg but don't quote me. Lemme know how you'd like me to measure and I'll get you the #'s. However, you have two choices; my large scale can only measure to the nearest 0.1kg and my next lower scale can only measure 5kg max. Neither is ideal. I could use the smaller scale and measure front + back to get total weight with better accuracy. Happy to do either way.
Also that little headset problem I mentioned early became a bigger problem. It's fixed now, it wasn't really difficult and cost me $0. Still not something that you want to have to do to a new build but I expected some ****ery with a $700USD frame and I can do it (borderline really enjoy working out the kinks) so not a biggie in my particular situation. If I spent $3-4k on the frame I'd be much more passionate about it.
[edit] I'm working on a follow up post for the headset thing, and how I fixed it. To be fair to the manufacturer, I have not yet contacted them about it but I will when I get my ducks in a row. It could very easily be an oversight because their bearing supplier missed a digit in the part # so I'm not quick to blame them. We'll see. [/edit]
Likes For Ryan_M:
No worries, use the larger scale when it's convenient. The pedals usually add on ~200g/pedal, cages are ~20gm, garmin mount ~30g.
Great build and I'm glad you are out enjoying it!
Thanks!
Thanks!
So on the scale is:
- ICAN A22 54cm frame with all the bits and (IIRC) 44cm x 11cm one piece handle bars
- ICAN Aero 45 wheels
- Pirelli P-one 700x28 tires with 60mm Muc-Off valve stems and ~50ml of Orange Seal per tire
- Shimano R8020 groupset w/170mm cranks, 50-34 rings, and 11-34 HG800 cassette (so long cage RD)
- R8000 Pedals
- 2x MT800 140mm CL rotors
- AL garmin mount
- Fizik Arione VS saddle
- SRAM bar tape
- 2x carbon bottle cages
The scale was fluttering between 8.0kg and 8.1kg depending on how I breathed so likely very close to 8.05kg. Hope that helps!
Other than very minor deductions for excessive stem spacers, your bike absolutely rocks. The fact that your rig was assembled per your predilections, makes you a maestro in my humble estimation. Bravo.
Likes For zatopek:
Sunshine
Liked 7,490 Times
Headset Bearing?
Thanks for this tread!
What was the issue with the frame / fork and the resolution? I’m guessing the lower headset bearing was off by one number and then the wrong size? That’s why I like a parts diagram with part #s listed, torque values, etc. ICAN, and others, could easily add this info with a frame set or online.
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
Excellent work! May I ask how much you spent for parts total?
I haven't done a more thorough investigation. I've read there are 7mm and 8mm thick versions of these headset bearings which would be a tidy explanation as to what happened. Maybe their supplier f'd up, or someone missed a digit in a part number, who knows. I really should get to the bottom of this, but again it's low priority and I'm busy.
Accounting for all the little extra bits like pedals, bottle cages, garmin mount, tire sealant, yada yada... I spent ~$4,800CAD after all taxes and shipping costs.
Without looking to hard the closest commercially available equivalent I could find was the Giant TCR Advanced Pro Disc 1 which would have cost me $6,550CAD after taxes. Then I would have to buy pedals and all the extras etc,, etc.. which would have put the final total to nearly $6,900CAD. However, my bike has presumably better wheels, tires, and saddle, plus carbon handle bars. I'll take those savings!!!
Likes For Ryan_M:
