Replacement Brake Levers
Hi All, I'm converting an old Norco to a single speed, and need to find replacement brake levers. Currently, the bike has drops, and grip brakes with DiaCompe "calipers" (for lack of better term). I want to keep the drops, but change the brakes to be normal levers on the flats. I learned that you need to find brake levers that are compatible with canti/road style brakes because they are short pull, while anything listed for V-brakes are long pull.
Any suggestions for levers that won't cost me a fortune? (In Canada)
the handlebars are 22.2mm diameter.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
Stuart Black
Stuart Black
Quoted: 645 Post(s)
Liked 797 Times
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I'll second Cyccommute's suggestions about what to look for, and Litespud's advice to not have your only brake levers up top. I'd either do interrupters or drop levers only.
If the tops are where you think you will be most of the time (enough to justify having your only levers there), I'd consider going with a flat bar.
Just my $0.02.
Just my $0.02.
