Drive Side Bottom Bracket Removal
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
I’ve removed DS BB cups before. Even using my work bench vice.
I’ve convinced myself I’m spinning the whole deal the right way. See second pic.
Before I cook the paint with a torch, has anyone else has to resort to applying heat to break things loose? I’m thinking a small amount of heat just on the cup might not hurt too much.
I’ve been trying to soak with pb blaster and penetrating oil as well. No Joy.
Liked 2,971 Times
with a hefty metal chisel & a BFH, smack the flat using a downward [loosen] approach. Avoid hitting the frame at all cost.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 1438 Post(s)
Liked 1,092 Times
Heating the cup will make it tighter in its bore, you want to cool the cup and/or heat the bottom bracket shell to loosen the fit.
How about a hot air gun vs a torch? Or maybe cold spray on the cup?
Quoted: 539 Post(s)
Liked 416 Times
Don't waste time with the hot gun. Not enough.
Go straight with mapp gas torch. Put the flame inside the BB, not the outside which will burn the paint.
I've removed hundreds of stubborn cups like these.
If you don't want to save the old one and prefer to do things cold, cut it out with a sawzall or dremel
Likes For soyabean:
buy my bikes
Quoted: 519 Post(s)
Liked 428 Times
A heat gun is a good idea.
I don't want to put torch to the paint. The paints far from perfect, but I had no plans to paint. The whole deal was free, basically a bike with no seat, rusted chain, busted cranks.... https://www.bikeforums.net/22340362-post14509.html
I'm looking to make it my trail bike, as cheap as possible.
Quoted: 539 Post(s)
Liked 416 Times
Another cold uninvasive method is fill an automotive oil changing tray full of diesel fuel, drop the BB in that and let it sit for a week.
Believe it or not, a lot of penetrants have diesel as an ingredient.
Likes For soyabean:
Liked 1,092 Times
There's always the old Sheldon Brown fixed-cup tool method: https://www.sheldonbrown.com/tooltips/bbcups.html
or a supposedly improved version: https://arcady.genkin.ca/2016/03/an-...-removal-tool/
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Or this...leverage sometimes makes these things seem a LOT less tight.
Likes For cxwrench:
Quoted: 2338 Post(s)
Liked 2,822 Times
Quoted: 114 Post(s)
Liked 119 Times
Likes For MudPie:
Quoted: 539 Post(s)
Liked 416 Times
But unless you already have a bucket of misc fasterners to make that home made tool, the cost to grab them all will cost the same as the Park Tool.
How much do you think just one washer with a 5/8" hole costs today? It ain't 25-cents.
Really Old Senior Member
Lay the bike on its side, cup down.
Squirt some penetrating oil from the "top" and allow to run down the sides of the shell. It'll puddle at the cup/shell intersection and make kind of a reservoir.
Repeat multiple times every "so often". (during TV commercials etc.)
TAP the cup with the end of a box wrench and try to "ring" the cup. The vibrations help the PO to work its way in through capillary? action.
Use tools show in pics. Hasn't failed me yet,
Likes For Bill Kapaun:
Quoted: 114 Post(s)
Liked 119 Times
Well if you don't have the tools, the home made bolt-pipe-washer-nut tool can be used to clamp onto a stubborn BB cup, and you use a wrench+cheater to turn the home made bolt assembly that is clamped onto the BB.
A quick check at Home Depot lists flat steel washers for 5/8" screw at $1.28 for a pack of four.
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Is it just me or does that seem like a really big hole for a square taper spindle?
Quoted: 4205 Post(s)
Liked 3,864 Times
IIRC these cups has a "rubber" seal that rode on the cup's axle hole ID. You can see the relief that has been cut into the face. The missing seal would have taken up a couple of mms or more of the hole's diameter. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
buy my bikes
Quoted: 519 Post(s)
Liked 428 Times
got it
Used a narrow flame with my MAP torch.
Not sure if it helped
Smacked the flat with a chisel. Had a hard time getting a confident swing.
Gave up to go to church for a bit.
Remounted it in the Vice, but vertically using the edge of the jaws instead of the tops.
got it.
thanks everyone. I know there’s about 10,000 posts with this same question…
got it.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
For future reference, consider this post I made about a year ago. Taking the fixed cup off first makes a lot more sense since you can clamp and stabilize the cup better using the axle spindle than without it.
Stuart Black
Stuart Black
Quoted: 539 Post(s)
Liked 416 Times
MAP gas is much hotter than propane and that loosened everything for you.
Now you know what to do again next time. Don't pay attention to the haters.
Likes For soyabean:
SE Wis
Liked 3,395 Times
Likes For soyabean:
buy my bikes
Quoted: 519 Post(s)
Liked 428 Times
i didn't edit this quote at all!!
