Schwinn Collegiate Cable Housings
I am in the process of restoring my first vintage bicycle, a 1966 Schwinn Ladies Collegiate. I am bit new to the space and after searching the forum have not been able to locate a posting on how to source NOS or similar looking shifter and brake cables and so am humbling asking for some help from the community.
The two shifter cable housings are grey in color, 4mm in diameter, and have a waffle pattern on the outside. The shorter rear one is in most urgent need of replacement as the outer casing has started to disintegrate.
The brake cable housings are white in color (now yellowed with age) and are 5mm in diameter. Here I would be interested in replacing both the cable housings as well as the plastic ferrules at the hand brake levers as these have started to crack.
Thank you all for your time and advise.
Quoted: 3811 Post(s)
Liked 6,709 Times
Pork Chop BMX is often a good source: https://www.porkchopbmx.com/search/Cable+housing/
Likes For nlerner:
Quoted: 604 Post(s)
Liked 1,064 Times
I restored a 73 Collegiate recently, got the cable housing from Yokozunausa.com, they have a pretty good selection of new vintage style cable housing. Also nos vintage Schwinn cables and housing do show up on eBay occasionally.
Tim
Tim
Quoted: 811 Post(s)
Liked 1,024 Times
I like Jagwire Ice Grey for Schwinn bikes. It is close to the original silver/grey, at least in my mind. And it has the lined housing and smooth cable, so friction is as low as it reasonably could be. No greasing required.
Here is a link for it, however, it is widely available from other sources: BikeTiresDirect Jagwire Ice Grey brake cable kit
I like the brake kit for all the ferrules and do-dads that come with it. This should also be available for the shift cables. Make sure that you get the kit with the cable end with the correct end for your brake and shift levers.
I see it is backordered until the end of August. But at least you can see what I like. It could be available from other suppliers.
One other good thing about the ice grey is that it goes well with most colors.
The small bend of rear derailleur housing between the downtube and driveside chainstay can be incredibly difficult to replace on old schwinns, even with the cranks removed. Leave it there if you can. If you can't, use 4mm housing, cut the plastic ferrules short so they fit easily between the housing stop and the housing guide of the brazeons, grease the ends of the housing and the section of the brazeons the housing has to slip through, and expect to spend fifteen or twenty minutes getting it into place.
