What is this tool for?
Bought a super-cheap set of "Bike Tools" some years back. Nice roll-up pouch, allen wrenches, tire spoons, etc. Certainly not "Top Quality" but "good enough" for a casual rider like me and I can add to the pouch more stuff.
But it also came with this other tool, and I can't for the life of me figure out what it might be for except that because the opening is somewhat wider than my tires it might have something to do with tires or brakes? And it's probably some el-cheapo imitation of a real tool. I'm tempted to keep the useful parts of the kit and toss this piece in the recycling bin... except that the laws of nature dictate that the day AFTER I do that I'll suddenly need it and realize what its for.
Any ideas??? The thing circled in red...
Quoted: 6199 Post(s)
Liked 4,816 Times
Might be a roach clip for that really big doobie that Cheech & Chong rolled up in "Up in Smoke".
Likes For davidad:
Quoted: 3514 Post(s)
Liked 2,927 Times
Cheapie "fourth hand" for adjusting brakes.
Likes For smd4:
Likes For Ross200:
Liked 2,927 Times
Yes--"third hand" is probably a more accurate name (I'm used to calling any brake adjusting tool a "fourth hand").
Quoted: 839 Post(s)
Liked 1,064 Times
+3 for holding brake pads against the rim when attaching the brake cable or adjusting pads. I bought one about 30 yrs. ago and haven't used it in the last 29 yrs. Might be useful to some but most don't need it.
Liked 2,981 Times
the reacharound rim brakie handi tool.
Cheap, but adds some value if you're trying to work a touchy setup.
-Oh Hey!
-Oh Hey!
Liked 2,927 Times
If you want to make working on your rim brakes really easy, get a Hozan Fourth Hand. You can find them on eBay for cheaper, but even at full price, well worth the money.
This is a shop-quality tool that is far superior than the Park or Pedro's version. Works great on zip ties, too!
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1950 Post(s)
Liked 1,475 Times
Is this thing or another third hand tool really necessary? I just installed new carbon wheels and new rim brake blocks using these steps:
1. Remove the old wheel.
2. Install new brake shoes with new brake blocks in roughly the same spot as before. Loosely tighten the mounting bolts.
3. Loosen the brake caliper pinch bolt and let the brake caliper spring open all the way.
4. Tighten the cable adjustment nut all the way down, then loosen it by one full turn.
5. Install the new wheel.
6. Close the quick release lever of the brake caliper.
7. Squeeze and hold the brake caliper tightly against the wheel with my right hand, leaving no space between the brake blocks and the rim.
8. Firmly pull the brake cable taut with my left hand, pinching cable with my left thumb and index finger while wedging both digits under the metal block in which the pinch bolt is screwed.
9. Grab the hex key with my right hand and loosely tighten the pinch bolt.
10. Adjust the brake shoes so that the brake blocks sit 2 mm below the edge of the rim and flush against the brake track. (I don't toe in the brake blocks.) Tighten the mounting bolts.
11. Loosen the pinch bolt and let the brake caliper open slightly. Loosely tighten the pinch bolt.
12. Check the gap between each brake block and the wheel.
13. Further adjust the brake cable and/or the cable adjustment nut if necessary.
14. Fully tighten the pinch bolt.
Liked 2,927 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
No, it's a "third hand tool". It clamps the pads of caliper brakes against the rim while you align them and pull the slack out of the brake cable. A "fourth hand tool" is a plier-like tool that clamps onto the brake cable (or shift cable) and pulls out the slack. I have both and have never really needed the third hand tool but the fourth hand tool (a Hozan C-356, btw) is super useful for taking the slack out of shift cables and for pulling zip ties really tight.
Liked 2,927 Times
Liked 1,475 Times
Walking through the steps I listed above in post #10 above, I would say that a fourth hand tool (or cable puller) would be more useful than a third hand tool (or brake caliper clamp).
Likes For SoSmellyAir:
Liked 1,096 Times
Liked 2,927 Times
Palmer
Quoted: 1671 Post(s)
Liked 1,827 Times
I was given a third hand and fourth hand years ago, so I guess I got them second hand.
Likes For tcs:
Liked 2,927 Times
Give that man a hand!
Likes For smd4:
Liked 4,816 Times
At least it's not a third leg!
Liked 2,927 Times
Why would you use a fourth hand on shift cables? It’s just not necessary. With rim brakes you need to tighten the cable while at the same time compressing the calipers. Thus the need for the fourth hand.
Liked 1,096 Times
Getting all of the slack out of shift cables before tightening the clamp bolt can be difficult, particularly if not wanting to use a lot of the adjustment barrel's travel. The fourth hand tool lets you get it just snug enough. Actually tightening rim brake cables by hand is easier than shift cables as the acceptable range is wider.
Liked 2,927 Times
You don’t need a fourth hand for shift cables. A needle nose pliers to pull the cable taught will suffice. Using a fourth hand will run the risk of moving the derailleur.
Liked 1,096 Times
Not if you use it properly. I said it's to remove all the slack, not to tension the cable. The fourth hand is a subtle and controllable version of needle nose pliers. It's certainly not an essential tool but, since I already have it, why not use it?
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
Swing and a miss! Dude, really?
The origin of the name you used is the key... this tool is the THIRD HAND brake tool! It's the predecessor of the, you guessed it, FOURTH HAND!
The Fourth Hand tool completely eilminated any and all need for the THIRD HAND. It was a godsend. Still enjoying my 35 year old Fourth Hand tool! It's great for getting zip ties REALLY tight too. And snapping them as well!!!
