Terminate bar wrap
Terminate bar wrap
What tape are you pros using to terminate handlebar wraps? The tape that comes with a the bar tape is awful. Usually unwraps before the first ride. I've been using electrical tape but that's not much better. I just did bar tape last night on a recently purchased used bike that looks to have been bike shop maintained the tape was unbelievable. I had to cut it off.
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 882 Post(s)
Liked 1,226 Times
Self Fusing Silicon Tape Great stuff.
Barry
EDIT: Just noticed that the Black in my link is only in a large quantity. There are many others available if you search on Self Fusing Tape.
Barry
Likes For Barry2:
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 171 Post(s)
Liked 282 Times
I use waxed cotton or waxed leather lace for either book binding or sewing leather.
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 378 Post(s)
Liked 476 Times
3M electrical tape. Comes in many colors. Handy for all sorts of projects. Avoid the cheap stuff.
Likes For roadcrankr:
Quoted: 6290 Post(s)
Liked 4,882 Times
Self fusing silicone tape is available at the big box building supply stores and other hardware stores in many colors. When used correctly it's wonderful. But like learning how to wrap your bars, it takes a few attempts and some understanding to get it right.
I still mostly go for 3m electrical tape which also comes in many colors. 3m tape seems to stay put and the adhesive doesn't seem to get gummy like some of the cheap brands do.
If you plan ahead and remember to put it on before you put the STI's, bar tape and everything else on your handlebars, heat shrinkable tubing works very well. And it also comes in many colors, but you'll have to look online to find them for anything but black and maybe red which I have seen in big enough diameter at my local big box building supply. Amazon might be great for this in small quantity and free shipping for the few times you might wrap bars and need it. Or McMasterCarr, Grainger and etc.
Likes For Iride01:
Likes For wheelreason:
Cantilever believer
Quoted: 554 Post(s)
Liked 1,919 Times
The Minnesota Mining & Manufacturing Super 33 black and colored 35 tape is good stuff. Ah, for the days when I thought paying $2.79 per roll was highway robbery. After an unfortunate incident 14 years ago involving a rear bike carrier failure at 65 mph and a strong chain, I ended up wrapping an entire frame in 3M 35 tape.
Likes For RCMoeur:
Quoted: 3572 Post(s)
Liked 2,997 Times
Electrical tape is perfectly fine, but next time I wrap the bars I’m gonna try the self fusing silicone.
Clark W. Griswold
Quoted: 4436 Post(s)
Liked 4,085 Times
I use electrical tape and haven't had an issue. Silcone tape would also work well.
Quoted: 984 Post(s)
Liked 589 Times
Self-fusing silicone tape is very nice. I used regular electrical tape to hold the bar wrap in place, giving me time to properly deploy the silicone tape.
Self-fusing silicone tape to finish the ends of the wrap.
Likes For sweeks:
Quoted: 4530 Post(s)
Liked 1,673 Times
With modern bar tape, you can also skip end tape altogether.
Likes For Kontact:
Sr Member on Sr bikes
Personally, I almost always wrap top-down. No adhesive tape needed. Ends get trimmed with excess stuffed into the bar ends, and held by the bar end plugs.
Dan
Dan
Likes For _ForceD_:
Cantilever believer
Quoted: 554 Post(s)
Liked 1,919 Times
Back in the days of Benotto or Hunt-Wilde transparent tape, or Velox cloth tape, that was the way we all did it, as the overlap pattern didn't matter. And my first few padded-tape wraps were like this, until someone pointed out that starting at the stem results in the open side being "against the grain" for someone using the "top of the hoods" hand position. Depending on the tape, this can result in the tape flipping up or disintegrating prematurely. So I switched to starting at bar ends, which resolved the pattern, but then had to deal with the "how to you finish it?" issue noted above.
Habitual User
Quoted: 5039 Post(s)
Liked 8,273 Times
Electrical tape. Stretch it good on the first wrap, slightly looser on the second, and just enough tension to conform to the tape-bar transition on the third. Terminate under the bar.
However, I’m open to something better. I’m going to check out the silicone stuff.
Likes For Eric F:
Liked 1,673 Times
Even cheap tape will last awhile if you do it that way.
I use heat shrink tubing (comes in different colors). You just have to remember to put the pieces on the bars before installing the brake levers.
Quoted: 1954 Post(s)
Liked 2,194 Times
I bought some 1/2” wide multi-color electrical tape at Home Depot. I like the narrower look. So far it has worked well. Might use a different color next wrap.
John
John
don't try this at home.
Quoted: 986 Post(s)
Liked 526 Times
I cut a half inch wide strip of Gorilla Tape to secure the cut end, extending halfway around the bars. Then a full wrap 3M electrical tape, with a very slight stretch so the sides of the 3M tape look good. That's easy and effective for me. Gorilla tape doesn't creep like regular electrical tape. And I use a small piece of Gorilla tape to secure the starting end at the handlebar plug area, then I can start pulling on the bar tape tension right away -- easy.
(looking at the bar tops with a flashlight now, I can make out the texture of the gorilla tape through the 3M wrap. But I never notice that in "real life".)
It's the thicker, better 3M "Super 33+" tape. And the mini sized "Gorilla Tape To Go", 1 inch by 10 yards. I cut a strip in half lengthwise for this.
Bikes: Primary bike - late 70's gold ALAN Competition; mostly Campy with Huret Jubilee deraiileurs;When I joined that was my primary. Now back to my 1979/80 Shogun 600 since I can change everything and not feel like I'm committing sacrilege...
Quoted: 34 Post(s)
Liked 228 Times
I second the self fusing. Although you might have to run a couple times to get your "stretching" down so you see a nice wrap and ending.
I hate wrapping bars. So, 90% of the time I'm rewrapping bars is because I need to rebuild the ergo levers. Yes, I have the filthiest bar wrap on the planet.
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times
I’m guessing those sticking (no pun ending) with electrical tape have yet to try the silicone self fusing tape. Best to secure the wrap with one turn of any type of tape then use the silicone tape as a finishing tape.
Bikes: old ones
Quoted: 26464 Post(s)
Liked 10,424 Times
