Garage Door Opener... Seriously
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
I have one of those garage doors where you slide a lock-latch and then you try to grab onto something on the inside and manually lift it. Or I use the pedestrian door. It has a knob and a key-code.
Randomhead
Liked 3,698 Times
We have a chamberlain door opener so it would be cheaper to hook it back up to the internet. Wonder if I could convince the google assistant to open/close it for me
I took it off of the internet because I wasn't convinced the internet gateway couldn't be hacked. I was worried about something like the camera hack, where they used the cameras for denial of service attacks. I feel like the possibility that someone would break in using the internet is somewhat remote.
Google assistant gets snooty when you curse at it. I decided that's because they have people listening to you more often than they will admit.
Quoted: 6963 Post(s)
Liked 10,963 Times
Zaskar , that is pretty cool. If I had just one bike, I'd install it. Since I ride 3-4 bikes fairly regularly, I instead just use a digital keypad mounted next to my garage door. It takes a few moments to open or close the door, but it only cost about $25.
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
I'll bet that thing would be nice when making a mad dash up the drive in a rainstorm. Or an impending hygiene emergency.
Keep the chain tight!
Likes For Trsnrtr:
Quoted: 479 Post(s)
Liked 277 Times
Quoted: 3460 Post(s)
Liked 1,466 Times
I checked, my opener will work with a maximum of 8 remotes. I think the 9th one overwrites one of the others.
Quoted: 821 Post(s)
Liked 1,655 Times
I ordered one today, just to play around with the mounting system. Looking at it, (and with the help of my friend's machine shop) I think the unit mounting can be modified so that it can be removed from the bars with a 1/4 turn twist, leaving the 'end plug' mount intact (no retaping once installed). When it shows up I'll have a better idea. If it doesn't look like it will work I can always return it (pre-modified)
Super Modest
Liked 4,620 Times
I came home from a ride today and my garage keypad wouldn’t work. Dead batteries. I immediately wished that I had one of these gizmos.
Quoted: 479 Post(s)
Liked 277 Times
Quoted: 821 Post(s)
Liked 1,655 Times
If it works, I may send them pictures of the modification process. I think they would sell a lot more of these if you didn't have to retape your bars to change a battery. It's as if they really didn't think this out.
Quoted: 479 Post(s)
Liked 277 Times
BUT, the ability to quickly swap from bike to bike... yeah, they should jump on your idea. Plus, they'll sell some mounts - bonus!
Likes For Zaskar:
Randomhead
Liked 3,698 Times
This thread got me wondering if I could modify a keychain door remote to be smaller. Might be worth the $15 investment to find out.
Randomhead
Liked 3,698 Times
It's only $15 for two keychain garage door openers
Just need bigger handlebars, I guess
Liked 1,466 Times
Bikes: 76 Fuji Gran Tourer, 80 Gran Tourer SE
ive always had a mind to hide an opener similar to a hidden key but somewhere at shoulder level so you don't have to reach down.. this is so much cooler
Quoted: 821 Post(s)
Liked 1,655 Times
Mine arrived today. I did some measurements on the mount, and determined that there doesn't seem to be enough material to allow a quarter turn mounting. What I did instead was to cut back my bar tape about 1.5" from the end, install the unit, add some tape over the mounting pieces, and use colored electrical tape over the whole thing. That way I can just remove the tape on the very end if I have to replace the battery in the future.
I do have to admit, it works really well.
Likes For Bald Paul:
Liked 1,466 Times
Quoted: 821 Post(s)
Liked 1,655 Times
On my bikes with bar end shifters, I start the bar tape at the bar end, then work up. I am not suggesting that you should re-wrap your bars, but if at some future date your tape needs replacing, that is an option. If you do that, it might look best if you wrap both sides the same way, even though you only have one opener on one end.
Super Modest
Liked 4,620 Times
I got one today and either I'm an idiot (probably) or it won't work with my opener, a Genie series 1000, 3204 IntelliG. I've notified them but haven't heard back. Regardless, I got nothing.
Quoted: 821 Post(s)
Liked 1,655 Times
According to my directions that came with the unit, it will work with a Genie, either 315mhz or 390mhz. It would be either 5 or 6 button presses to program after you hit the LEARN button on your garage door opener. You may want to try both to see if it works.
Super Modest
Liked 4,620 Times
I also tried cloning An existing opener like one does with home link and that didn’t work, either.
Liked 2,971 Times
Worst garage opener unit to program. 1 star, do not recommend.
-Oh Hey!
-Oh Hey!
Liked 1,466 Times
If your opener is from 1992 or earlier, you might have problems. My opener (not a Genie) was installed in 1992, newer remotes do not play well with it.
In my case I installed one of these:
https://www.ebay.com/itm/264276096162
That is a radio receiver that can then be wired to the electric opener using the same wires that you would use for an indoor button to tell your opener to open or close the door when a modern remote (that was paired with it) tells it to open.
My electric opener (from 1992) uses dip switches for codes, no learn button. With that extra radio receiver I could add modern remotes to my vintage electric opener. I suspect that you could do something like that with your Genie too.
